Question about LG Studioworks 700S 17" CRT Monitor
Display problem Display in my monitors appears in the Half portion of Screen for 15-20 Mins from the start of the PC and it become normal after 20 Mins itself. I have already cleared the dryness of the PCB. But problem still persist. Pls help.
  • Lats Mar 22, 2008
    Display in my monitors appears in the Half portion of Screen. Pls help.
Pls check all the electrolytic cap after the secondry power and electrolytic cap to in/output the vertical ic and at horizontal cct.
thanks.
Posted on Feb 04, 2008
One inch white line when booting slowly becomes solid
If you'r not expert fixing laptops send it to repair shop to check screen cable it might be screen data cable problem like it loose or need replacement if this not the problem then Ohhh time to change the screen...Good Luck
Feb 03, 2013 | HP Pavilion zd8000 Notebook
My moneter sceen picture has become large and out of focus
i  think there was  a problem with system monitor resolution setting,please follow the given steps and check the monitor setting-
1-Right click and go to property option
2-chose setting option
3-check screen resolution,standard size is 1024 by 786 pixels and color quality is highest 32 bits
  and also check advanced option under setting DPI setting is normal size 96 DPI ,choose all option than apply and ok.
Thats helpful to you.
Thanks,
Dec 13, 2009 | Computers & Internet
Samsung SyncMaster 213T - DIM DISPLAY
I would follow the self-test below. If you see the same issue in the test screen then your monitor has lost it's sync and would need a board replaced.
If it dosn't appear during the test, then you might want to test it on another PC.
Self-Test Feature Check
1. Turn off both your computer and the monitor.
2. Unplug the video cable from the back of the computer.
3. Turn on the monitor.
If the monitor is functioning properly, you will see a box in the illustration below.
This box appears during normal operation if the video cable becomes disconnected or damaged.
4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
If your monitor screen remains blank after using the previous procedure, check your video controller and computer system; your monitor is functioning properly.
I’m happy to assist further over the phone at https://www.6ya.com/expert/marnin_498840f315fe3361
Jul 22, 2009 | Samsung SyncMaster 712N 17" Flat Panel LCD...
COMPAQ PRESARIO DESKTOP PC SR1215IL. When switched on, cpu boots normal but no display on monitor. instead a sharp and bright blue vertical line appears for few seconds on the middle of screen. led of the...
tricky!! oh hi im Dyanne.. a totally unresponsive black screen can be th result of failure of th LCD or LCD inverter.( a specialized piece of electronics that energize th screen) to rule out th failure of th video display adapter or circuitry, try plugging in an external monitor..a standard pc monitor.. attached direct to th lappy. if it works, (as i susopect) th motherboard and video display are both working ok and its th LCD which is at fault. this can sometimes be repaired by a competent specialist. good luck xx
Dec 25, 2008 | Compaq Evo D300 PC Desktop
Touch screen half loading only
Try uninstalling the TS from the control panel-system-devices (hardware).
Reboot and reinstall the drivers when asked.
The driver must match the OS.
The TS may be defective, does it operate proper on another Pc?
Mar 14, 2008 | Computers & Internet
Monitor display problem
there is a problem in the vertical , change the ic please
Dec 17, 2007 | Philips SoHo 105E 15" CRT Monitor
Problem LG XNOTE 229QA2
Please try and external monitor if the picture is OK then you are having LCD problems. I dont know for you but over in the States here: http://lcdrepair.net They maybe, are able to help you.
Sep 29, 2007 | Computers & Internet
LG Studioworks 700S 17" CRT Monitor Logo
79 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
