Question about Epson Stylus RX580 InkJet Photo Printer
10 to 15 sheets of paper jammed in printer rollers.
    Problem Solver:
  • 12 Answers
You will have to partially disassemble the printer. There are probably some bad rollers or springs and that is why it drew in so many pieces of paper to begin with. I normally only see three or four pieces drawn in at any one time.
Thanks,
rich
Posted on Sep 26, 2009
My oki c3400n continual paper jam's at the fuser. Paper comes out of the printer about 2 inches then jam's. I clear it and it happens again. Don't see any contamination on the fuser roller.
There are paper path cleaner sheets that you can get at supply stores or on line. They are sticky on both sides. They pick up paper dust from the rollers as it passes through the printer.
Feb 17, 2016 | OKI Office Equipment & Supplies
How do I fix the machine jamming?
There are sticky cleaning sheets of paper that clean paper dust off the rollers and the paper pathway in the printer. You can obtain these cleaning sheets from a paper supply outlet. Also inspect the rollers for a torn corner of a paper that is stuck in the paper pathway that may cause a new sheet of paper to feed in crooked.
Nov 15, 2015 | HP Office Equipment & Supplies
Hi Canon LBP 1120 paper feed and paper jam problem: My Printer mostly take in multiple paper sheets instead of taking just one sheet. Sometimes the extra sheets are taken in while the printing sheet...
You need new pickup rollers
google search "LPB1120 pickup rollers" and find your nearest dealer. usualy quite easy to replace as long as your a "can do" person
Mar 18, 2011 | Canon LBP 1120 Laser Printer
Paper jams after first sheet prints. Tried adding more paper and then taking paper out. Nothing is working. No other sheets are jammed in the printer.
Poor quality paper can cause feed problems as the edge may be poorly sheared causing the sheets to stick together and often leaves fibers on the rollers which reduces their grip. Always 'fan' paper when replenishing to loosen the sheets.
Also, printers with heavy usage will occasionally needs the rubber pickup rollers cleaned. Don't use alcohol since this can dry out the rubbers surface complicating the problem. I have used naphtha to remove the built up paper fibers successfully.
Dec 03, 2010 | Brother HL 5250DN Laser Printer
My laserjet 1020 develops a paper jam after printing the first page of a multipage print instruction .I have deleted the printer and re-installed it including all drivers but problem still...
Reinstalling the printer is related the Software.
If the paper gets physically jammed than its the driver setting issue or hardware issue.
Check if two sheets get jammed or only one sheet.
If it is two sheets than printer is picking up multiple sheets and paper gets jammed.
If the printer is jamming a single sheet than remove the Tray and look there is rubber roller inside if there are marks or lines on that rubber roller or if the roller roller is worn out than that rubber roller called as paper pickup roller need to be replaced.
If that looks fine than try to priny using manual feed and if the problem persists from manual feed too than try another toner cartridge
If the problem is not from Manual feed Tray that Replace the main Tray with known good Tray and check if the issue resolved.
Jul 01, 2009 | HP LaserJet 1010 Printer
Roller drags several sheets of paper and results in a paper jam
Open your printer and release jam paper then solve problem.
Apr 09, 2009 | Lexmark E322 Laser Printer
Hp photosmart 2410xi - paper won't feed properly through, jam
Go to an office supply store and pickup printer cleaning sheets. They are sticky on both sides. You run a sheet through it a couple of times to remove paper dust from the rollers. The pickup roller is so slick it is drawing in more that one sheet of paper. Cleaning the rollers and the paper path will solve your problem.
Mar 18, 2017 | HP PSC 2410 All-In-One InkJet Printer
HP paper jam
That is usually caused by the paper feed rollers being cover with paper dust. Take a clean cotton pad and alcohol and clean the rollers :turninig each roller as you clean it. if it has a rear dor, open it to get better access to the rollers.
Please remember to rate all users who assist you for free :)
Sep 03, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
'paper jam' error on canon pixma ip4300
Hi guys, I eventually found a solution to the problem for my printer. With the top cover open, I pushed a sheet of 120 micron thickness A4 clear plastic binding cover through the exit tray as far as it would go to rest against the bottom row of rollers. I switched the printer off then back on again and as the rollers lifted momentarily, I pushed the sheet of plastic as far up through the machine as I could before the rollers went down again - it went in a fair distance. The printer then ejected the plastic sheet. I then put the plastic sheet into the paper tray and tried to print a blank document page. The plastic fed through cleanly and my printer has been working since without any error messages. I hope this works for you.
Aug 22, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Epson Stylus RX580 InkJet Photo Printer Logo
220 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
