Unlocking iPod
You can unlock iPod in one of two ways:
Enter the combination on iPod using the same controls you used to set the combination. If you do not enter the correct combination, the digits onscreen flash red. When you enter the combination correctly, iPod will unlock and return you to the last viewed screen.
Connect iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock iPod using either of these methods, you can restore your iPod to factory settings. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to iPod.
If you want to change the primary computer that your iPod is associated with, do this:
Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data.
Connect your iPod to the computer that you want to be the primary computer.
i've just got an ipod nano 5th gen and when i play something the music is coming from the actual...
(More)
i've just got an ipod nano 5th gen and when i play something the music is coming from the actual ipod. and when i insert the headphones they only sometimes work. why is the sound coming from the ipod itself?
i gb nano frozen in connected eject before disconnecting stage. windows does not recognize the usb...
(More)
i gb nano frozen in connected eject before disconnecting stage. windows does not recognize the usb port
My ipod wont show up in itunes and when I turn it on it says connected but immediatly after it says...
(More)
My ipod wont show up in itunes and when I turn it on it says connected but immediatly after it says ejecting you may now disconnect.
