Question about Power Voice System Optics
AN/PVS-7 I'm seeing double vision, vertically. Can this be adjusted or fixed and how?
3 Suggested Answers
aipl564
SOURCE: put it together myself now wont focus past 5 ft and has double vision i tryed using the adjustment knobs and stillno luck
You are having a problem with parallax. This is a common problem with Gen 1 equipment. Be sure to use a FRESH and high quality battery. Do not expect a picture perfect image with GEN 1 equipment. Be sure to follow the instructions that come with the unit.
Posted on May 11, 2009
stewbison
  • 577 Answers
SOURCE: I am having trouble with my pvs 7 night vision. I
OK, is the IR luminator working with a red glow. Don't look at it. Some these IR luminator have a adjustable lens that one can screw out or screw it in. If the IR isn't igniting then the LED could be bad , broken wire, or bad switch. stewbison
Posted on Aug 13, 2011
I have a mitsubishi model # WD73C9 television it is displaying vertical lines and double vision, what may be the problem?
double vision ( ghosting) sometimes indicates an antenna misalignment/ bad connections or reflection of the signal from something like a roof or building wall
Feb 15, 2016 | Mitsubishi WD Televison & Video
Unit simply does nothing when its turned on. the IR assist still works. (AN/PVS-7B/D
Letto, This PVS-7B has a generation II image intensifier tube in it. The image tube is manufactured by ITT liton company. The only way to fix this wonderful NV devise is to send to ITT Night Vision Company. They are listed in the internet. Unless you can find someone to work on it, but the really need to know what they are doing. stewbison
Mar 01, 2011 | US Night Vision Ultra PVS-7B Goggles
My pvs7 wont stay on thay shut of after 30 seconds and then start to shut of ever few seconds
Hello, have you or someone else pointed this night vision devise at bright lights, street lights, head lights. If so, maybe the damage has/hasn't alread been done. STOP. This PVS-7 goggles with ITT image tube with generation 2 or 2+ or possibly generation 3 tube. The devise is an American made unit, and the best in the world. Nobody can compete with the USA on NV. They sat the standards on Night Vision.
Have you replace the 6 volt battery? Get the goggle in a darken room then turn the switch on.
see if the 25mm plate will turn green and stay on. But first replace that battery.
Therefore, if this test works, then never and I mean never shine NV devises into bright lights, it will destroy them every time.
PS. send me another message and let see what happen. stewbison
Feb 26, 2011 | US Night Vision Ultra PVS-7B Goggles
I am having trouble with my pvs 7 night vision. I can see clearly for about 60 yards. The IR illuminator is not working. What do I need to do?
Feb 09, 2011 | Night Optics USA AN-PVS-7-3A Goggles
Looking to buy a used pair of pvs 7 nightvision goggles and owner says there are a couple of small black spots when you view is this a cause for concern and what else should i look for ?
Hello, that is normally to have some black spots. Now, if tries to tell that this Military spec. He wrong. Two black spot on any image tubes used by the US Military is rejected, they only allow one black spot and that if everything else is OK. How fuzzy is around the outer circle of the image tube. If there is a uniformed green pattern through out the scope. I would say it was OK. But remember "Buy be Aware". GB...stewbison
Dec 30, 2010 | US Night Vision Ultra PVS-7B Goggles
I recently accuired a pair of an/pvs-7b night vision goggles. When trying them out they didnt work. I checked the batteries already in them, there was no old crusty battery acid. I replaced them and still...
Hello, there two things that can bad. One is the oscilator with voltage multiplier or the image intensifier tube. Send to Morrison Optics Co. GB....stewbison
Nov 22, 2010 | US Night Vision Ultra PVS-7B Goggles
Put it together myself now wont focus past 5 ft and has double vision i tryed using the adjustment knobs and stillno luck
loosen the the thingy behind the lens adjustment, you can turn it clockwise or anti-clockwise which it will go down or up, thats it..problem solve for your 5ft focus problem..in the double vision, you gotta line up the eyepiece center to your both eyes..problem solve again
Apr 29, 2009 | Optics
Double vision..
Adjust the convergence in the menu. If it will not adjust then solder connections on convergence ics or ics themselves need replaced.
Apr 26, 2009 | Televison & Video
Double- Vision
More than likely your akai has defective stk392-040 Convergence chips . it also may have open resistors generally 3.9 ohm flame proff. this board is attached to the top left looking from the back of the set it is screwed on by 1 screw black in the center . after installation this will probably half to be converged dinamically. which means you will half to get to the grid this is done by using the remote press mute 183 quicly to enter numbers on thew remote 2 to adjust red 4 to adjust blue horizonta 6 to adjustred vertical and 8 to adjust red vertical using center button to go up and down
Feb 20, 2008 | Akai PT4298HD Rear Projection Television
Optics Logo
90 people viewed this question
Top Power Voice System Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Power Voice System Optic Expert? Answer questions, earn points and help others
