Modem problems have to reinstall it every so often cause if I don
Modem problems have to reinstall it every so often why is this happening? It's a Lifebook C Series 2330
    Sergeant:
    Champion:
  • 232 Answers
You have a driver problem .
all computer parts have a driver system which helps to run .Depending on the health of your pc , which needs to be cleaned up on regular basis ( delete temp. memory , defrag ) drivers needs to be updated to keep them running . Upgrade your drivers and your problem will dissapear .
Posted on Sep 26, 2009
My computer is not responding
tried to use your computer as stand alone, don't connect other pc to the modem. just to know if only in the modem or internet connection is the cause.or your pc desktop has a problem.
Jul 22, 2012 | Dell Computers & Internet
Cannot connect to my Internet. On my 2Wire modem at home, The Power LED light is solid green, the Ethernet LED light is green, the DSL LED light is continually flashing, and there is NO Internet LED...
With the DSL light always flashing, it means that either the ADSL signal (synchronization) does not reach your modem, or your modem cannot 'read' the signal.
You need to determine if the problem is from one of the following places :
  • outside of your house (your land line or ISP equipment) or from the modem;
  • your telephone-cable inside your house or
  • one of your equipment;
Try the following manipulations to determine from where the default comes :
  1. Determine if the problem is in your house or on the land line
    • Unplug each and every equipment which is connected to your telephonic installation (Fax, phones, answering machines etc);
    • Using the shortest telephone cable (RJ11) you possess, plug only your modem to the main telephone jack of your house.
    • If the DSL LED still flashes continuously, the problem is somewhere between your ISP's equipment and your house. You should call them and expose the situation. At this stage, you can't do much else.
  2. Determine if the problem is in your house installation
    If the DSL LED lights up when it is plugged to the main telephone jack, then it is either one of your equipment which is at fault, or the house installation. To pinpoint the problem, do the following :
    • With all the other equipment still unplugged, try the modem on all the other telephone jacks you have around the house.
    • If the DSL flashes continuously on one of the jacks, you will have found the source of your miseries. Depending on your ISP's terms and conditions, you will either have to call them of call for the services of a third-party technician to solve the problem.
    • If the DSL lights up correctly on all the telephone jacks, then your house telephone installation is good. Proceed to the next series of tests.
  3. Determine which equipment is at fault
    • Plus your modem to one telephone jack and wait for the DSL line to light solid.
    • Use a splitter (ADSL filter) to plug the equipments you possess (telephone, fax etc) one by one. Verify each time if the DSL LED is still lit or flashes continuously.
    • If one of the equipment causes the DSL LED to flash, it is that equipment which causes your problem.
    • If every equipment causes the DSL LED to flash, the it is the splitter (ADSL filter) which is causing the problem. You can confirm this hypothesis by testing each and every ADSL filter you have in your possession.
    • Replace any faulty equipment and you should have eliminated the problem.
If nothing of this solves your problem, you won't have any choice but call you ISP. Don't hesitate to tell them all tests you will have done.
May I also make some recommendations :
  1. Use a power surge protector (not a UPS though) to plug your modem to the electric outlet BUT plug it directly to the telephone jack;
  2. Make sure your modem is plugged in as far as possible from UPS, television, etc.;
  3. If possible, don't plug the modem in the same electric outlet as other equipments;
  4. Don't use any telephone extension cable to plug your modem to the telephone jack.
Hope this helps you. Let me know what happens next.
May 11, 2011 | 2wire (1000-000057-000) Modem
The wire less connection to computers are functioning very fragmented or not. By connecting a cable tothe router DIR -615 there is no probleme. What happens if I reset. Do I have to reinstall...
When you reset your router, it will return all settings to their factory defaults. I advise you not do reset your modem - the cause of the problem is unlikely to be solved by doing this. Try a simple reboot, by unplugging the power supply and restarting the router. If that doesn't solve your shady connection, try changing the wireless channel your modem broadcasts on. You can find information on how to do this by viewing your modem's manual.
Mar 12, 2011 | D-Link Computers & Internet
I'm having a problem with my playstation 3 when i'm playing mbl10 the show. when i paulse to go into the bull pin it freezes up, and usually happens in the 7th & 9th inning with between 55 sec - 3 min...
Check to make sure the blu-ray disc is really clean.
If the problem persists I would delete the game data under GAMES and reinstall.
Let me know if that solves your issue.
Sep 25, 2010 | Sony Video Game Consoles & Games
Resource conflict pci in slot 03 bus 06 device 04 acer aspire 5100
The conflicts happens when a two hardwares shares the same IRQ (Information reqiest). You will nto be able to use those devices. The best way to remove a confliction is to uninstall and reinstall that hrdware. Normally, it can be sound card and modem. At this point I suggest to unisntall Modem and Sound card drivers from the computer and reinstall it. To do so, go to Control panel>Add remove programs> search for sound and modem software and click unistall or remove.
To reinstall it> Click Start Menu> All Programs> Acer erecovery management> Restore> Reinstall Application & Drivers> Select the appropriate sound driver (Realtek) & modem. Install it one by one. (install the sound card first)
May 22, 2010 | Acer Aspire 5100 Notebook
Hello! I got a problem with my modem on Portege 2000
Well as a work around, you could buy & use a USB Modem. You simply must find, the exact modem driver, or what you have happening, will happen. Are you sure you are looking for the correct driver. Get a program called Everest, this will tell you exactly what it is, also, sometimes you need an Installer, not just the driver..go to MODEM manufacturers website to get the driver, the PC manufacturer, often has many different ones used.
Mar 24, 2010 | Toshiba Portege 2000 Notebook
USb SXC -1080 modem of tataindicom causes problem with vista
the usb modem you are using is compatible with windows vista but for that u need to install the driver software ie sxc 1080 vista dialer 32 bits . you can download this software from the tataindicom site which is www.tataindicom.com. windows 98 and vista have different software compatibility.
Oct 01, 2009 | Microsoft Windows Vista Ultimate Edition
I use a D-Link 200 modem for my broadband connection. For the past two days I have been able to establish a connection to my ISP but can't get onto the net. I called my ISP who had me uninstall and...
*check for the connections are properly connected
*check the modem in other machine (install modem driver also)
*replace new modem to see wheather it is working fine
Jun 30, 2008 | Computers & Internet
Dropping internet connection
This can be caused by a number of problems.
  • Power level fluctuations (ie surge or brownouts caused by storms)
  • Interference with other devices that use the same radio frequency (ie microwave, cordless phone, or another WIFI access point in the neighborhood)
  • Interference caused by motors' RF shielding failing. (Vacuum Cleaner, Refrigerator)
  • A bad physical connection to the Modem.
  • Badly written firmware.
  • DSL connection issues.
Ask yourself when you first noticed the problem and what has changed since then.
If you haven't already, you may want to check out D-link's web site.
Nov 20, 2007 | D-Link DI 514 Wireless Router (DI-514)
Computers & Internet Logo
David Payne
David Payne
