Question about Maytag Atlantis MDE6400AY Electric Dryer
Maytag atlantis gas dryer
It works fine except it won't shut off by the timer. I have already replaced the control device on top of the machine.
  • beachratgang Jan 06, 2008
    My dryer never stops running, even when the door is opened. I have to turn the knob to an 'off' position to get it to turn off. I have to use an egg time in case I forget about the dryer running! It would run forever if I let it. We replace the timer unit but I think my husband shorted out something b/c I think that was the part that would have fixed it. Don't want to spend the $100 again if that's not the part needed. Also, the light is only on when the dryer is running. It's not on when you open the door, but it used to come on when the door was opened.
  • Anonymous Nov 06, 2008
    We have the same problem with the Atlantis...The dryer timer is not working and therefore will not shut off unless we turn it off. Seems awefully dangerous! Has Maytag addressed this issue?? Recall of the faulty part?
Had the same problem. Replaced the timer and it shorted out the dryness sensor. After 6 visits from the repair man, Maytag said they had put the wrong timers in the boxes. At one time I had 14 timers at my house and they were all wrong. Maytag sent another repair man and he couldn't fix it either.
Posted on Mar 04, 2008
  • 833 Answers
Timeout...I'm guessing you mean that the timer on off doesn't turn anything off. If this is a mechanical timer unit, the contacts are welded. If electronic, your relay is probably welded. Replace the item. If you do go inside, unplug the unit, and then find the relay or contact set and see if they are actually welded. Most units have a diagram on the back. Follow it through with a multitester.
Posted on Dec 18, 2007
My Maytag MDG640AWW gas dryer timer does not advance and auto shut off. What part number do I need to replace this part?
my best guess is a restricted vent, disconnect dryer vent hose and run dryer, it should work if not then there a few other things, here is a link that will help you:
http://www.hometips.com/repair-fix/laundry-dryer-timer.html
Mar 13, 2011 | Maytag Atlantis MDG6400AW Gas Dryer
I have a Maytag dryer MDG6200AWW and at first the machine dried the clothes fine but never shut off. The second load got hot but not long enough to dry whole load. The timer does not advance at all. ...
Remove the front panel to get to the gas valve. To remove the panel remove both screws holding the door hinges and the screws on the opposite side from the hinges across the door opening.
Remove the metal bracket holding gas valve coils.
Replace both gas valve coils, part number 279834.
Good luck,
Vlad
First Choice Appliance
Aug 21, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag Atlantis MDG6400AWW, timer stopped working
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 20, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
My maytag gas dryer timer does not turn, does not get hot, does not shut off unless I shut it, why?
HI. This will occur when the timer mechanism(timer motor assembly), becomes fused, or the motor itself has failed. The timer mech is the main initiator of all the selected cycles. If the timer is unable to rotate properly, the unit will not heat or stop as well. Replacing this defective timer module will correct this issue.
Sep 24, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
My Maytag Atlantis MDG6400AWW will not heat up. The drum spins but the clothes don't dry!
my dryer timer is not turning off and it does not get hot,I check glow coil.its working but it does not fire up.I smell gas some time
Apr 16, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag atlantis dryer model # mde6400ayw
sounds like the timer is not completing the cycle in this mode will the dryer shut off if you manuelly advance timer in that mode
Oct 21, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Dryer
hi thanks for the question i would check the venting on this dryer make sure its clean if you can vacuum the entire dryer this will solve your problem thanks the appliance doc
Aug 14, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Atlantis MDE6400AY Electric Dryer Logo
162 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
