Question about Kenmore Elite HE4 Electric Dryer
Dryer won't start
The dryer was installed today. I follow the steps to start, press in and hold the start button for longer then the 5 seconds stated and it still doesn't start. I've checked all the steps in the manual and read through the troubleshooting part as well. What can it be?
  • Kenmore Master
  • 2,605 Answers
Does the drum light come on if the door is opened ? Those doors can be tricky, they have 2 latches, one top and one bottom. Close the door, give a slight push at the top of the door and on the bottom, the latches will become easier to close with use. Try it for now though. Other than that, I've seen loose wires from transportation, poor outlet wiring, and even breakers not "on" in my travels of service. Good luck
Posted on Sep 26, 2009
How to turn off demo mode?
Good Morning Friend,
I understand you want to turn the demo mode off of your Electrolux dryer, model# EWED65H. To deactivate the demo mode in your appliance, please try the following:
    1)Turn the cycle knob to the last cycle on the right.
    2)Press the start button and immediately afterwards press the cancel button.
    3)Within 10 seconds, wake up your appliance by pressing the start button once.
    4)Immediately, press and hold cancel and the right most key under the display, together for a minimum of 6 seconds. DEMO MODE will no longer show in the display.
    5)If a 3 prong power cord (120V cord) is attached, remove it and attach normal 240 V cord.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
Jul 03, 2014 | Electrolux EWED65H Dryer
Whirlpool duet dryer model number gga9200lw2 says control lock how to fix problem
follow this steps and fix it. God bless you
The processes below will get most controls unlocked.
Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 15 seconds.
Some Models- Press and hold the control lock button for 15 seconds.
If none of these work try unplugging for 5 minutes
Oct 05, 2012 | Washing Machines
The dryer just stopped and now wont turn on
WAKE THE WASHER BY PRESSING ANY BUTTON.
WAIT 5 SECONDS.
PRESS AND HOLD THE START AND PAUSE/CANCEL BUTTONS SIMULTANEOUSLY.
ALL LED'S WILL GO BLANK AND AFTER A FEW SECONDS THE CONTROL WILL SIGNAL THE STORED CODE USING AUDIBLE BEEPS AND BLINKING LED'S. THE CONTROL WILL REPEATEDLY SIGNAL THE CODE, AS LONG AS THE START AND PAUSE/CANCEL BUTTONS ARE PRESSED. A TWO-SECOND PAUSE BETWEEN REPEATS AFFORDS YOU THE ABILITY TO MAKE ACCURATE COUNTS TO IDENTIFY THE CORRECT ERROR CODES.
PLEASE NOTE THE FOLLOWING: ON A SMALL NUMBER OF WASHERS WITH SERIAL
NUMBER PREFIX XC4, IF THE PREVIOUS PROCEDURE DOES NOT PREFORM AS
SPECIFIED, FOLLOW THE OPTION BELOW:
* FOLLOW ALL PREVIOUS STEPS BUT INSTEAD OF PRESSING START AND PAUSE/CANCEL BUTTONS, PRESS AND HOLD OPTIONS AND PAUSE/CANCEL BUTTONS."
*THE CONTROL WILL PAUSE FOR 2 SECONDS, THEN REPEAT THE CODE AS LONG AS THE TWO BUTTONS ARE PRESSED AND HELD."
NOTE: A LETTER APPEARING IN THE CODE STANDS FOR A NUMBER HIGHER THAN NINE: A=10 B=11 C=12 D=13 E=14 F=15 "
"EXAMPLE CODE F1: THE FIRST DIGIT WOULD BE 15 AND THE SECOND WOULD BE 1. IF THIS CODE WOULD APPEAR ON A WASHER IN THE GOOD MODEL LINE, THE FIVE INDICATOR LIGHTS WOULD BLINK FIFTEEN TIMES AND THE START INDICATOR LIGHT WOULD
Jul 28, 2012 | Frigidaire GLET1031FS Top Load Stacked...
I'VE HAD MY DRYER 3 YEARS. POWER COMES ON BUT WHEN YOU PUSH START BUTTON THERE'S JUST A PAUSE AND THE ERROR CODE " F". PLEASE HELP!!
Select any one button (except POWER, START, and STOP) and follow
the steps below, using the same button (remember the button):
Press/hold
3 seconds
➔ Release for
3 seconds
➔ Press/hold
3 seconds
➔Release for
3 seconds
➔ Press/hold
3 seconds
All indicators on the console will
momentarily turn off, then turn back on with 88 displayed. After
5 seconds, the Automatic test begins.
Use the tech sheet info on page 2 as a starting point
Note to get the exact tech sheet or manual for your machine go to ServiceMatters and post your model number.
May 03, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Electrolux dryer stuck in demo mode
To deactivate the demo mode:
Turn cycle knob to last cycle on right. Press start to save cycle position.
Press cancel to turn machine off.
Within 10 seconds, wake unit by pressing start once, immediately press and hold cancel and right most key under the display together for a minimum 6 seconds.
“DEMO MODE” will no longer be shown in the display.
May 24, 2009 | Electrolux EWED65H Dryer
2015 network printer
Please perform the following:
Unplug the network Cable:
Cold reset A cold reset changes most system parameters in NVRAM to the factory defaults. However, unlike NVRAM initialization, a cold reset does not reset the page count, the paper tray sizes, language, or formatter number.
A cold reset also resets all the HP Jetdirect settings as well as the printer settings. Use the following procedure to perform a cold reset.
  1. Turn off the printer.
  2. Press and hold the Go button.
  3. Turn the printer on, and continue to hold the Go button for at least 5 seconds, but not longer than 15 seconds. During this process, the Attention LED turns on.
  4. Release the Go button.
    If both the Attention and the Ready LEDs turn on before you release the Go button, you must start the procedure again with step 1.
The printer's LEDs begin cycling. The cold-reset process runs until completion, and the printer returns to the ready state.
Network reset A network reset changes all network system parameters in NVRAM to the factory defaults. During the network-reset process, all button presses are ignored.
Use the following procedure to perform a network reset.
  2. Simultaneously Press and hold the Go and Job Cancel buttons.
  3. Turn on the printer and continue to hold the Go and Job Cancel buttons for approximately 10 seconds, but no longer than 20 seconds. During this process, the Attention light turns on.
  4. Release the Go and Job Cancel buttons. The Attention , Ready , and Go lights begin cycling from front to back. After the network-reset process is complete, the device returns to the ready state.
    If the Attention and Ready lights illuminate before you release the Job Cancel button, start again at step 1.
Now plug in the network cable and then wait for 5 mins.
Then print a configuration page and check the IP Address.
Jul 29, 2008 | HP LaserJet P2015dn Printer
Metwork card
Your printer is a dn model, which means it is duplex + network. Please unplug the network cable and perform the following:
Now connect the netowrk cable and wait for 5-mins. After that print a configuration page and confirm the IP address.
- Nikhil
Jul 09, 2008 | HP LaserJet P2015dn Printer
Dryer won;t work
Remove the top cover and take a hair-dryer to the PC boards on the back of the main control panel.. (3 screws take the top cover off from the back) Mine has done it a total of 5 times now.. what it needs is all new buttons installed.. or a new control panel if this works..
Feb 22, 2008 | Kenmore 82822 Electric Dryer
Brand new dryer
try holding door switch down with your finger while pressing start button.if dryer starts then your door needs adjusting.
May 20, 2007 | Whirlpool GGW9200L Gas Dryer
Kenmore Elite HE4 Electric Dryer Logo
82 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
