Question about Miller Welding Tools
How to connect wire feeder with UWI-400? - Miller Welding Tools
  • aasariya Sep 27, 2009
    Dear, I dont have any Miller Wire feeder, I want to use other company wire feeder and want to connect with this machine
  • 986 Answers
Here is a download of the manual...http://www.millerwelds.com/service/locate_om.php
The manual has generic info on hooking up accesories.
It would also help to know about the wire feed you are trying to hook up.
Posted on Sep 27, 2009
    Brigadier General:
  • 5,158 Answers
What is the part number of the wire feed unit ?
Posted on Sep 26, 2009
  • Roberta Smith
    Roberta Smith Sep 26, 2009
    basically you mount the wire spool onto the holder
    feed the end of the wire between the two wheels and it will feed it to the tig/mig end of the welder.
    robert
Miller welder problem
the current setting is not working correctly
indicates that the amp setting for the wire is too low or if it is an inverter , the volts setting is far too low
Jul 26, 2017 | Welding Tools
Do the carbs on the 1983 vf400 come off one by one or all together and any tips i should know to get them off thanks josh....
The carburetor rack comes off as an assembly. All four at the same time. You need to take extra care with Honda v-4 carburetors, if you twist or flex the rack you can break the feeder connections between the carburetors. Often the tiny orings have broken or started leaking by now. A major problem with all Honda v-4's. If you take the rack out try not to separate the carburetors or you will have problems with the feeder pipes and o-rings (they will leak when you put them back together.)
Oct 23, 2010 | 1983 Honda VF 400 F
I have a Copystar CS-2020 and it is showing error code A-O 410 on the screen what does this mean
Document Processor communication problem. This is due to a faulty ground connection.
Open the doc feeder lid, check the left hinge. There are two versions of grounding tab: a small one and a bigger and better one. Both attached by a screw.
Twist the small metallic tab that grounds the hinge with doc feeder metal frame in order to create better contact. Worst scenario, the doc feeder cable has a broken ground wire at the holding strap (inside the back rear cover of the feeder, which is hold in place by plastic clasps. If you are handy you can solder the wire ..
Feb 17, 2009 | Copystar CS-2020 Copier
I have a kyocera 1810 copier. it has a error a 400
Does this machine have an ADF ( document feeder) on it? If so, check the connect cable from the document feeder to the machine. Also check the connectors from the scanner PWB to the document driver PWB. ( these are the 2 boards that do the communicating , the machine and the document feeder). If this machine does not have a ADF the check the side covers/ doors and make sure that they are closed securely.
Jan 05, 2009 | Kyocera KM-1510 Copier
Im tryint to conect my wire feeder
ask weld tech at a welding supply store and ask if your components are compatible (since most wire feeders are 24 volts).
Dec 19, 2008 | Welding Tools
Miller axcess 40v wire feeder
give me a day or so and i will have the solution for you
Sep 11, 2008 | Welding Tools
Hp officejet 7310 document feeder cover
no my friend.. just opened back cover the wire connected in pcb just remove then reconnect. thats all..
Aug 18, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Hp officejet 7310
better u disconect ur document feeder wire connection. and than try that.
How to connect the paper feeder to a AR-5316E copier
the feeder should have two hinges
1- remove the plastic covers where they should go on hte machine
2-two types of connectors
a)a plug in in the back of the machine
b) hard wire : in this case remove the back cover of machine
there should be a ground and two plugs. in the machine there should be two wires next to the location of the plug
Aug 07, 2008 | Sharp AR-5316 Advanced Digital Imager...
Document feeder
Try clean with alchorol those rols what feed those sheets. I'm sorry my English . But try clean. or some think stuck the paper on tray Aleixo
Sep 05, 2007 | Canon imageCLASS D780 All-In-One Laser...
Welding Tools Logo
114 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
hubiam
hubiam
Level 1 Expert
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
