Question about Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive
Seagate Baracuda 7200.7 in a RAID0 array has failed. On Drive diagnostics Drive test get error message "Drive Failed! Return Code 7". What is the drive error?
    Genius:
  • 1,112 Answers
Hello mmincalgary:
This drive error code 7 means the controller board that controls the drive has failed, the board is located on the harddrive itself, Replacing this drive will solve your problem, unfortunely Segate has had many issues with this drive especially the SATA ver .7, 160GB versions..
Posted on Sep 26, 2009
During upgrade of windows 32 bit vista to win 7 32 bit compatibility test advised to update device drivers storage controllers SCSI/RAID host hd type seagate baracuda 7200-10 how do i find suitable...
The drivers for vista and windows 7 are probably the same. As long as you performed an upgrade and all your original programs and data are still there. there is no point in updating drivers unless you are expieriencing problems.
Jul 22, 2011 | Computers & Internet
I did many times to install os windows xp tablet many times but a message pos about that say, no hardik found, swith on your hard drive...My hdd sata is very new...How could it be pls. help
I would suggest running a diagnostic test of the hard drive in your tablet. While the majority of hard drives fail after 3-5 years, they can occasionally fail early on as well.
If you are unsure of the manufacture of your drive, I would suggest running the seagate diagnostic as it is not brand exclusive.
http://www.seagate.com/www/en-us/support/downloads/seatools
If your hard drive has in fact failed, it may be covered under a manufactures warranty.
It is also possible that the drive has become disconnected within the tablet or that the sata connector on the motherboard has failed.
Apr 29, 2011 | Computers & Internet
Sudden Blue screen display on my Dell Inspiron 1545 with MS XP OS-Then I ran diagnostics and got this result- "DST short Test-Failed-Error code-2000-0151 Error message: Hard Drive 1-incorrect staus...
Hard Drive 1-incorrect staus 3E. Please help fix this problem. Thanks
Nov 03, 2010 | Computers & Internet
Dell studio windows failed to start. error code 2000-0146
the Error code was sited below as the (Disk Self Test) DST Log contains previous error(s)
in case of your error DST log contains previous error(s) doing a
chkdsk /r or a repair reinstall of xp might resolve the issue.
to resolve issue...
Error Code Error Message 1000-0141
or
2000-0141 No Drive Detected 1000-0142
or
2000-0142 Drive Self Test Failed Status Byte=XXh 1000-0143
or
2000-0143 Drive Smart Read Command Failed 1000-0144
or
2000-0144 No Support for Drive Self Test Error Code Error Message 1000-0145
or
2000-0145 Timeout waiting for Drive Self Test to complete 1000-0146
or
2000-0146 DST Log contains previous error(s) 1000-0147
or
2000-0147 Unit (x): IDE status failed. Status byte = (x) Control Code = (x) Msg = (s) 1000-0148
or
2000-0148 IDE ERROR: status (x) (s)
Aug 07, 2010 | Dell Studio 17 Laptop
D610 DST Short Status Test Fail
It appears your hard disk has died and it may not be possible for you to retrieve your data.
Remove your hard drive from the laptop and insert it into an USB harddrive adapter, (they are not expensive and you can use it later as a external hard drive). Then plug it into the USB port of a working computer. The computer should/may see it as an external drive, if you are lucky you will be able to copy your data, if not, you are out of luck.
There are companies that can recover data from faulty hard drives, but it will cost you an arm and a leg for their service.
Feb 17, 2009 | Dell Latitude D610 Notebook
I got a system form my school with no HDD. I got a standard IDE interface seagate baracuda 7200 rpm 160 GB HDD. I tried booting the system with a boot CD. But the error it is showing is CDBOOT: Memory...
If you have both a CD drive & a DVD drive, make sure you are using the 1st physical device (according to physical hookup).
Or if you do have both, then try booting with CD in other drive
Dec 27, 2008 | Computers & Internet
Computer will not boot.
Form the info you provided, you have a RAID (Redundant Array of Independent Disks) disk array. RAID 0 (striped disks) distributes data across several disks in a way that gives improved speed and full capacity, but all data on all disks will be lost if any one disk fails. Apparently Diagnostics has determined that “Drive 2” is defective. You will have to replace the defective hard drive and reload the Windows operating system.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 21, 2008 | Computers & Internet
I have a maxtor 6L080M0 hard drive that has crashed The return code is 7 Is there any way to fix this problem.
If the following determines you have hard drive failure then you may have to purchase a new HD. Follow what is recommended from the manufacturer below. READ EVERYTHING.
According to Seagate the makers of Maxtor, you have a DiamondMax 10 (6L080M0). See below or click here
My internal hard drive may be defective, how can I test it?
Question
My internal hard disk drive may be defective, how can I test it?
How can I determine if the problem is with my system or with the hard drive?
It is necessary to run the SeaTools, SeaTools Enterprise, or SCSIMax diagnostic before contacting Technical Support 1.800.SEAGATE (1.800.732.4283) on an internal drive that may be defective.
Answer
For Seagate or Maxtor (or Quantum) ATA drives:
If this is a Seagate or Maxtor (or Quantum) ATA or SATA drive, please download the SeaTools for DOS diagnostic to test it. If the drive is failing, the tests in SeaTools for DOS will indicate as such.
If the BIOS does not recognize the drive or the drive does not spin please reference Answer ID: 48
The operating system will not recognize a drive that is not formatted and partitioned. If you need help with formatting:
  • Windows 9x and ME reference Answer ID: 3076
  • Windows 2000 Answer ID: 880
  • Windows XP Answer ID: 3361
  • Windows Vista Answer ID: 3844
  • Macintosh Answer ID: 492
    For Seagate SCSI drives:
    Please download the SeaTools Enterprise Edition diagnostic.
    For Maxtor (or Quantum) SCSI drives:
    Please download the SCSIMax diagnostic.
    SeaTools, SeaTools Enterprise, and SCSIMax will test your S.M.A.R.T-compliant ATA, SATA, or SCSI disk drive for media defects, perform a read test, physical head test and ensure the hard drive is functioning correctly.
    If all the tests pass (no trouble found), the problem remains elsewhere in your system. Reconfirm all settings for hard drive jumpers, cables, and ATA, SATA, or SCSI controllers, and disk operating system. Consult your host controller documentation or system manufacturer for assistance with SCSI termination or ATA / SATA controller capabilities.
  • Jul 04, 2008 | Computers & Internet
    Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive Logo
    378 people viewed this question
    Top Seagate Computers & Internet Experts
    Arora Singh
    Arora Singh
    Alun Cox
    pankaj rautela
    pankaj rautela
    Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
