Question about GE Washing Machines
I have a 1998 Hotpoint top load washer & I need to get to the belt to see if it is loose or bad. How do I get back-bottom off to get to it?
  • GE Master
  • 2,605 Answers
Access to that era machine should be thru the front. Locate clips at top of front panel between the front panel & top "seam" on either side. Use a flat screw driver or a puddy knife, while applying a forward force to these clips (one at a time of course) pull gently towards you on the front panel, it should come free and ready to remove from the bottom hangers/clips. Now you ahould see the motor, belt, tranny, pump, tube etc. If you witness alot of oil splattered all over the inside, well that can cause belt to slip, burn and ultimately break...but more importantly; trans is toast :( Hope that helps, Good luck
Posted on Sep 26, 2009
What makes the drum spin?
There is a motor on the bottom. You can see it if you lay the machine down. The motor has a belt that attaches to a transmission. The belt could be loose or off. The transmission could be bad, or the spindle into the drum is stripped.
Jun 12, 2014 | Kenmore 22422 Top Load Washer
How do I change the belt on my hotpoint top load washing machine?
turn it back to you, there is an opening at the back, just remove the screw, you will see the inside of the body, at the bottom you will where is your driven belt located, loosen the foot bracket of the motor holding the belt so that you can remove it, just remeber the part number of the belt or much better bring it with so that you ca have an actual comparisson, different brands and model of washing machine have different types of belt
just to make it sure. bring it with you
when you put it back don't make it to tight, just enough that i won't slip once you turn it on.
Nov 01, 2009 | Hotpoint VVSR1070D Top Load Washer
My Hotpoint VBXR1070 washer tub will not spin. The motor seems fine and spins, but the belt seems loose and has apparently been rubbing on the metal support housing. Is it possible that the belt has...
yes, the rubbing could definately have damaged the belt, so I would begin by replacing the belt first. you may also have a problem with the clutch pulley which sits on top of the motor. if you remove the clutch you must replace the clutch clip as the old one will not hold again. hope this helps.
Oct 13, 2009 | Hotpoint VBXR1090D Top Load Washer
HOTPOINT WASHING MACHINE - BELT IS RUBBING AGAINST BACK OF DRUM & WEARING BELT + INTO PLASTIC DRUM CASING. I HAVE TRIED MOVING THE BELT TO THE FRONT EDGE OF THE MOTOR PULLEY DRIVE, BUT AFTER A FEW...
if you have gotten that far your good
now try to look at the motor it sounds like your belt might be a lil off track on the mortor shaft
there is a adjustment srew on the top left of the motro its hidden under things but its there
you can looses this and swing the motor
make sure you have it lined up on the motor shaft and it should stay aligned on the pully
Oct 08, 2009 | Hotpoint Aquarius WD63 Front Load...
GE washer will NOT spin, but does all other functions.
You need to have the fan belt checked. It must have been loose or broken.
Jul 22, 2009 | GE WSXH208A Front Load Washer
I have a wd440 washer dryer and the belt has come off how do i put it back on
It should not have come off in the first place
The belt is either badly stretched or the motor needs adjusting or the drum bearing has worn or the pulley has worked loose
Check the belt to see if it is fraying
Next ,take hold of the main pulley at the top and bottom and see if you can rock it in and out from the backplate, if there is a lot of play then the pulley is loose or the bearings are worn
If that is secure
Put the belt onto the motor shaft first the onto one side of the Drum pulley use the pulley to drive the belt into positions by turning it so if you put the belt on the left hand side of the big pulley then turn the pulley clockwise
Once it is in position go to the longest piece of the belt which is shown and see if yoy can move it left to right or right to left
You should only be able to move the belt about 15mm any more than that and you will need to loosen the bolts on the motor and re-apply some tension
Jul 09, 2009 | Hotpoint Aquarius WD63 Front Load...
How do i fit a drive belt on a hotpoint tumble drier
Hi, To fit the belt to your dryer you will need to remove the top of the appliance by removing the screws at the rear. Pull of the timer/control knob. Look inside the top of the t/dryer behind the control panel you will see little plastic stems which are attached to the facia panel. You need to knock these out to remove the facia. Once this is off then you can remove the the top 3 screws and the bottom 3 screws the front panel will now come off for you to place the belt on the drum and over the motor spindle. Becareful as the t/dryer will be very loose and will twist. it is easier to lay the appilance down on its back to stop everything falling about. Now you can put it back together in the reverse order....
Good luck.............
Jan 26, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint washing machine belt come off
To refit belt, remove top cover and rear lower panel at bottom of washer.
Tilt the m/c towards you.,you may need assistance to hold m/c.
Put the belt round the motor pulley first, and then fit it on drum pulley, slowly turn the pulley feeding the belt round as you go, it will be very tight, so be careful not to trap fingers., just keep going until belt is on, there is no adjustment needed as belt is self tensioning.
The belt needs to sit in the middle of the pulley.
Plz rate my solution.
Thanks.
Jan 10, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Getting inside my washer
remove 3 screws back on the top remove top but all you need to do is remove all the rear screws holing back panel on roll on the new belt to the pulleys
Mar 01, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Hotpoint wma 34 front loader will not spin
Open the rear panel and check for a broken belt and whether the motor spins. In case both are OK it could be a bad capacitor issue as well. Good luck!
Nov 28, 2006 | Hotpoint WMA33 Front Load Washer
Washing Machines Logo
29 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
