Question about Hoover F6020-900 SteamVac Upright Vacuum
I can't find my manual for my Hoover F6060-900 steam vac; therefore I can't figure out how to turn off the tool feature and water is pouring out of the hose. Can you help me please? Sincerely, Bob damron
    President:
  • 389 Answers
Manuals can be downloaded from the Hoover website
Posted on Sep 26, 2009
  • no-manuals Sep 18, 2011
    Manual for f6020-900 isn't there....
Hoover steam vac maxx 77 motor suddenly not running?? its almost new
Should still be in warranty. Read the warranty and get in touch with Hoover.
May 07, 2015 | Hoover Vacuums
Can not get my steam vac to suck up water everything else works.done half floor empty water to do other half of floor and it just stopped sucking up water
  • There a twist lever on the side to change from floor to tools. If "everything else works" then you have it on tools. Twist it back to floor and it will work.
Sep 11, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
How much soap and water to mix for steam vac
Hi! To fill the solution and clean water tank, turn tank upside down and unscrew cap. Pour Hoover cleaning solution into tank to detergent fill line. Then fill tank completely with hot tap water. Hope this helps!
Jul 10, 2014 | Hoover F5505 SteamVac Spot Vacuum
Hoover max extract V clean water leaking
get a new clean water tank or a seal to put on it from hoover.com/vacuumparts
Mar 16, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
Repair hoover steam vac F7210
Fixya does not make servicing recommendations.
Jul 23, 2017 | Vacuums
No manual. where does the solution go and the water
hi yuo should be able to pull off the front cover and fill it up with the solution and water then you pour it in the front on bottom after you take out the plastic front you will see the place to pour it. then the piece you pulled out will fill up with the dirty water and simply pull out and empty
May 14, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Spin brush removal
Brush Disassembly Hoover STEAM VAC Owners Manual F9514-900 (F9514900) does not
explain how to take the brush assembly apart. The instructions are as
follows:
Figure 1 shows the key
features. There are two
clear plastic outer pieces
which are held onto the
white inner piece with 3
tabs each. The clear
plastic tabs go underneath
the corresponding white
extended tabs on the white
plastic inner piece.
Figure 2 shows where the
screwdriver is inserted
(flat blade) and gently
pushed down while pulling
the clear plastic outer
piece away from the inner
white piece.
Figure 3 shows assembled
unit. Note extended brush
axle goes in center, which
fits into the female drive
unit on the shampooer.
I used the hose nozzle out
on the lawn to direct high
velocity water stream
trying to get the hair out
of the brushes. Hair and
fuzz remarkably entrained
in brushes, but I got 90% of it out.
Oct 19, 2008 | Hoover SteamVac F5914-900 SpinScrub...
HOOVER STEAN VAC 2 DEEP CLEANER
If you used any other cleaning solution other than Hoover, your Steam Cleaner will develop deposits in the turbine that drives the brushes. What happens is this:
Users pour other store bought brand cleaners in the reservoir to clean. Then they store the Hoover Steam Vac. While sitting in storage, the residue dries in the turbine and develops hard deposites, which ruins it. It will cost you about $100 to have the Hoover Store repair.
Cleaning Solution:
http://www.amazon.com/dp/B0002B8L26?smid=ATVPDKIKX0DER&tag=yahoo-kitchen-20&linkCode=asn
Oct 14, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover Steam Vac Wide Path
Don't have one yet, but your problem might have solved mine. Bought this cleaner used and now will go to vacuum store to buy spring. Water just pouring out like a faucet.
Mar 27, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hoover F6020-900 SteamVac Upright Vacuum Logo
504 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
