My 2 years old son removed the protective cloth from my B&W 602 speaker and pressed on the metal "gold" color twitter dome and deformed it. Is there anyway that i can bring it back to the original position?
    Problem Solver:
  • 12 Answers
I'm sorry but I don't know of any way to pull the dome back out. A speaker specialist might be able to but I know they aren't going to guarantee it. If the dome only has a small dent in it and your ears aren't specially trained you probably won't notice the slight drop in high frequency response. If you do notice the difference I would recommend that you climb into the yellow pages and look for an audio speciality store. You may have to replace the speaker and if the speakers are matched pairs in each cabinet you will have to replace them in pairs to maintain the proper balance.
Thanks,
rich
Posted on Sep 26, 2009
Blown resistors
Both resistors are: 1/4w 100 ohm with 5% tolerance (brown, black, brown & gold colors). Best to use the "Metal Film" type because they're more durable than the "Carbon Film" type.
Feb 24, 2014 | Jensen JHT525 System
Only works on speaker
Speaker may have popped, which would require a new speaker, or could be a simple wire fault.
Aug 01, 2012 | Samsung Gravity SGH-T459 Cell Phone
Goes straight to protect mode, detached speakers, still same problem
HI, if the unit is in protect mode then there may be the possibility that the speaker wires may have a short circuit in them or that the amplifier section may be damaged....you can remove the radio from it's sleeve and check the wiring behind the unit...this also would have to be done to see the model number and serial number...it should be on either the top or bottom of the unit...the speaker wires for this unit are the white, gray, green, and violet...each with another of the same color but has a black stripe in it...the black stripe is the negative side of the speaker wire....you can disconnect these wires, then turn on the unit to see if it comes out of protect mode...if it does, then there is either a bad wire somewhere in the car or a bad speaker...if the unit stays in the protect mode, then you will have to take the unit in for repair, as this indicates a circuit failure
One of the more confusing car stereo problems can be when an amplifier goes into protection mode. One minute it's working and the next minute it's not, usually with the green power LED on the amp turning to red or orange. Here's a brief troubleshooting method that will hopefully help you if your amplifiers ever go into protection.
1. Try to determine the cause. Amplifiers can go into protection mode for several reasons. Knowing what happened before it quit working can help determine how to fix it. Did the amp malfunction as soon as it was turned on? Did it happen after blasting for hours (may be thermal overload and it needs to cool)? Did it cut out after you hit a bump (a wire connection may have come loose)?
2. Tear it down. Get the amp down to it's most basic state. Remove all of the speaker wiring and RCA wiring and leave only the power, ground and remote leads connected. If you still have a problem in this state then either your amp is defective or you may have an installation problem such as the amplifier touching metal.
Remember that an amplifier should only be connected to the vehicle through the power and ground terminals. Mounting the amplifier to the metal of the vehicle, including putting the mounting screws into metal, can cause problems for your amplifier. Always mount the amplifier to a non-conductive surface. An easy way to accomplish this is to mount the amplifier to a wood board and then mount the board to the vehicle. Don't let the amp touch the screws used to moun the wood board and don't use screws so long to mount the amp that they go through the board and touch the vehicle.
3. If the amp is OK in this torn down state start reconnecting wires until you find what causes the problem. Add the RCA cables first. Then add the speaker wires one at a time. If the speaker wires cause the problem then they are probably touching metal. Check to make sure that a speaker wire isn't being pinched somewhere between the amp and the speaker. Also check that the speaker wire or speaker terminals aren't touching the vehicle metal near the speaker opening. Rear decks and door panels can easily touch unprotected speaker terminals if not properly installed.
If you believe your amplifier is defective contact the manufacturer first. Many have flat repair rates that are very affordable and cover parts and labor as well as return shipping. However local repair shops may be cheaper if it is just a small repair. Compare the manufacturer's repair rate to that of a local shop. If you don't know the reputation of the local shop it may be better to send it to the manufacturer who will have working knowledge of the amp and parts readily available.
Hope it helps..
Aug 10, 2011 | Sony STR-DE698 Receiver
I've just replaced both my ink cartridges, but the printer say to Remove and check color cartridge. I've taken it out and put it back many times.
Seems like you didn't removed the protective plastic film on the new cartridges . Wipe the gold colour area with a clean cloth and try again
Nov 18, 2010 | HP PhotoSmart C4180 All-in-One Color...
My phoenix gold x200.4 amp turns on but the protect light keep on flashing
  • What does it mean when the LEDs flash on my amplifier?
    With most recently produced Phoenix Gold amplifiers, a flashing/blinking LED is an indication that the unit is in protect mode, usually due to an overcurrent condition caused by an internal short, external short (speakers), or low impedance. Overheating will also cause the amplifier to shut down temporarily.
    If amplifier remains in protect mode, power down the amplifier, disconnect the speakers, and power up again. If LEDs continue to flash, there is probably an internal problem with the amplifier that will require service attention to fix.
  • Sep 23, 2010 | Phoenix Gold ZX600ti Car Audio Amplifier
    Blue light flashes
    Hello www_wallyeva,
    The most likely causes for an amp to go into protection, is a short or ground on the output terminals.
    Remove the speaker wires and see if the amp powers up normally. Check the speaker wires and voice coils with a multimeter to locate a short or ground.
    Hope this helps.
    Aug 17, 2009 | Phoenix Gold Car Audio & Video
    The fault light immediately comes on my Crown XLS 602 power amp immediately upon turning it on. It will not go out?
    Hi try disconnecting the speaker outs and turn off bridge (if its on) If it doesnt work still, then suggest direct to a crown agent. The amp has a 3 year no fault warranty. Hopefully its still in!
    All the best
    Aug 04, 2009 | Crown XLS 602 2-Channel Amplifier
    Surround Sound Pioneer Amp # VSX-604S 10 to 15 years old- All functions work well EXcept Left channel produces frequent crackeling noise. Sometimes it is intermittent--Sometimes it's clear for an hour or...
    Try swapping everything external to the amp with another channel to see if it follows. Could be the speaker wire or the speaker. If it stays on the same output then it's time for a new amp.
    Nov 20, 2017 | Pioneer Audio Players & Recorders
    79 people viewed this question
     Grubhead
    Grubhead
