Question about Whirlpool ED2FHGX Side by Side Refrigerator
Fridge not cooling/frezer overworking
I have a Whirlpool side by side, model#ed20pkxaw01. the freezer is overworking and is forming ice crystals on everything, but the refrigerator side is not cooling at all, even with it turned up to 5. it sounds like it is constantly running also. what could be causing this? any and all help would be appreciated.
  • 146 Answers
It is constantly running because the thermostat in your refrigerator registers a warm temperature that never reaches target. Your refrigerator's cooling is dependant on your freezer - obviously your evaporator fan is working since your freezer is cooling, however that cool air is, for some reason not reaching your fridge - Make sure the vents are not blocked or plugged with ice - If applicable also check the damper, maybe the flap is not opening at all, letting cool air in.
Also check door seals and make sure te light switches off by pressing the door contact button.
Posted on Sep 26, 2009
Whirlpool ffw400wh cools nicely for 3 days then form ice on the freezer & does not cool at the fridge compartment
Sounds like your defrost timer is not functioning , it will need to be replaced. Some times the frost free fan can also cause this but I think it will be the defrost timer.
Located under the fridge usually on one of the rear corners.
Pit has like I white round dial on it .
Jan 09, 2014 | Whirlpool Refrigerators
Freezer works, but has some ice forming and refrigerator not cooling.
The refrigerator half of a refrigerator/freezer does not produce any cold! The refrigerator is cooled by transferring air from the freezer to the fridge. The fridge temperature setting controls a flapper between the freezer and the fridge. There should be a fan which blows air from the freezer into the fridge (through the damper).
If the ice forming in the freezer is concealing the cooling coil and air can not move through the coils, then the overall result will be a warm freezer (even though there may be ice in one location) and a warmer yet fridge. This can be tested by unplugging the fridge and allowing a complete thaw. If the ice is the cause of the problem, then it should work for a short while until it freezes up improperly again
:o).
Jun 04, 2011 | Whirlpool GB2FHDXWS (63 cu ft) Top Freezer...
Whirlpool 6th sense side by side fridge/freezer 25rid4 model,freezer working fine but fridge part does not cool
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 30, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Why does ice keep forming in the bottom of the freezer and how do we fix the problem?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Oct 15, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator and freezer not cold also inside of freezer wall ice is formed. What could be the problem ? Please help.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Oct 04, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Vent flows cold air through frezer to right side when door open, but no flow when freezer door is closed. Temp drop in fridge side. Vent is cleared of ice build up.
Good day,
There are 2 vents. The one on the top to allow air from the freezer into the fridge. There is a second one, a return on the bottom left that allows the air to return to the freezer.
The return vent is the one that is blocked. (iced up).
On your model, it is very difficult to melt the ice out especially using heat due to all the plastic and foam.
Although ugly, it is best to unplug the machine, and leaving both doors open fo 24 hours.
Sep 22, 2010 | Whirlpool Refrigerators
Frezer keeps frezzing
If the freezer is icing up your defrost timer or the heating element may be bad. If the fridge doesnt go into defrost mode you will get frost on the back of th freezer and ice will freeze up on the coils eventually it will not cool the fridge side very well at all. If there is an ice block let me know also is the fan in the freezer running?
Aug 15, 2010 | GE Refrigerators
Stop cooling every 5 days I defrost manual GSS201ETCBB
Does the freezer / fridge door close good? Check the hinges. Also check the seal and the amount of food stuff you may have close to the door. If you have an ice maker make sure you have it secured inside the freezer section.
It sounds like something is keeping the freezer door open or from closing good.
Mar 20, 2010 | GE GSS20IEP Side by Side Refrigerator
Ice forming in freezer refrigerator not getting cold
Replace your heater and thermostat behind the back wall of the freezer. the air will not flow from the freezer to the fridge because of all the forming ice. Also replace the defrost timer. take your model number into a local parts store and they can get you the parts. This is very common!!!!! But pretty easy to do.
Nov 20, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool ED2FHGX Side by Side Refrigerator Logo
310 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
