Question about Canon EOS 40D Digital Camera
I have same problem with my 40D. Push the shutter button and it switches off. Have to remove the bettery for it to switch on again several times but still doesn't working. When I put battery back in the camera the access lamp blinks even though power switch is off. Any ideas??
2 Suggested Answers
  • 125 Answers
SOURCE: canon EOS D40
The link below might be of help:
http://www.fixya.com/support/r5100611-canon_d_slr_error_99
Posted on Jun 16, 2010
How can I put my Cannon $40D camera to IR mode to use a wireless remote control
The IR mode is the timer mode.. On top the camera press the AF button while rotating the selection dial. You see the icon on top the camera switch from a single square, to several stacked squares, then to a clock with a been. That's the IR mode. if you press the shutter button you active the 10 second timer, air you have a IR trigger the camera will receive in in this mode.
Apr 15, 2013 | Canon EOS 550D Rebel T2i Digital Camera
Canon 40d will not take pictures
1) CF card in camera? Won't shoot without one
2) Does mirror go up?
3) Canon had a run of bad motors for this model - if mirror does not go up, then it is the mirror motor. If mirror goes up, shutter will not fire, press release again then the mirror goes down, the shutter motor is bad (same model motor). If mirror goes up, shutter fires, both blades travel together/no exposure, probably the shutter is bad.
May 07, 2012 | Canon EOS Digital Rebel XS / 1000D IS...
Camera won`t shoot
Have you tried taking off and then re-installing the lens?
Jun 29, 2010 | Canon EOS 40D Digital SLR Camera Digital...
Pressing shutter switches the camera off (40D)
Before you send the camera in for repairs, try this free fix. The problem that you described is frequently battery related. Make sure that your batteries are the correct type for the camera, and that they are fresh/fully charged. If the batteries are OK, the problem may be due to corrosion on the contacts inside the camera. Remove the batteries and wipe the inside contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, wipe the ends of the batteries, and replace them in the camera. This cleaning process works about 90% of the time, and I hope that it cures your problem.
Sep 11, 2009 | Canon EOS 40D Digital Camera
40D turns off as I press shutter button
The shutter mechanism had to be replaced. I've heard that this is a typical 40D problem, due to a shutter design flaw. They say that it has been fixed on replacement shutters.
Jul 26, 2009 | Canon EOS 40D Digital Camera
Canon 40D locks up after pressing shutter problem.
If you extended the warranty and it happens again, I don't see why not. Just make sure the damage is covered under the plan you purchase.
In this case, it is a manufacturer defect, and should be covered.
40D's are notorious for Live view failure, as well.
Apr 06, 2009 | Canon EOS 40D Digital Camera
HOW TO REMOVE SELF TIMER
You know the button you pushed to turn it on? Push it again. There are several setting such as timed or one shot, etc. Simply select one shot and you'll be fine.
Dec 25, 2008 | Canon EOS 40D Digital Camera
Firing "lag time" response
Hi poseguerai,
Try this:
I had the same issue and even if it sounds crazy giving a massage to the shutter button all around in circles helped and when you switch on the camera has no shutter lag again.
I hope it works as it did for me.
Oct 27, 2008 | Canon EOS 40D Digital Camera
Canon eos 40D error 99
Check this link: www.richardsnotes.org/archives/2005/04/29/50mm-lens-contact-points/
Oct 20, 2008 | Canon EOS 40D Digital Camera
Canon EOS 40D Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
