Question about Nokia 6610
No signal the LCD was fastly heat and the battery is automatically broke. and no signal
Try to change the signal ic....
Posted on May 13, 2008
    Guru:
  • 167 Answers
Your phone is shorted'
fastly heat' and battery broke' automatically
P.A. Problem, change the Power Amplifier to fix your phone,
skilled technician can do...
Posted on Jan 15, 2008
My asus vh192 lcd monitor automatically shutdown...sometimes it shows no signals.
it most likely is over heating because the fan and heat sink is clogged with dusty yuck..... careful tho never usea brush and if you use air use very low psi or dammage will ensue
Oct 06, 2013 | Computers & Internet
Battery gets low very fast in 7 hours. I only use sms
Hi shontemple.....
Battery life is depends on *signal strength in your area *network settings
If signal strength is high at your place then also your battery discharge fast....
You need to change the battery
Feb 02, 2011 | Cell Phones
Idle fluxuates up and down consistantly
Check the Idle Control System
Idle speed is controlled by the Idle Air Control Valve (IACV). The IACV changes the amount of air being bypassed to the intake manifold, in response to electric current controlled by the ECM. When the IACV is activated, the valve opens to maintain proper idle speed.
Symptom and Subsystems to Check:
1. Difficult to start engine, when cold--check Fast Idle Thermo Valve.
2. Fast idle out of spec, when cold:
a. Check Fast Idle Thermo Valve.
b. Check IACV.
c. Check idle adjusting screw (see Section C).
3. Rough idle:
a. Check hoses and connections.
b. Check IACV.
4. RPM too high, when warm:
a. Check IACV.
b. Check Fast Idle Thermo Valve.
c. Check hoses and connections, check Power Steering Pressure Switch Signal, and check idle adjusting screw.
5. RPM too low, when warm:
a. Idle speed is below specified rpm, with no load--check IACV and idle adjusting screw.
b. Idle speed doesn't increase after initial start up--check IACV.
c. Idle speed drops in gear (automatic transmission)--check automatic transaxle gear position switch signal.
d. Idle speed drops when AC is on--check air conditioning signal and IACV.
e. Idle speed drops when steering wheel is turned--check power steering pressure switch signal and IACV.
f. Idle speed fluctuates with electrical load--check hoses and connections, IACV, and Alternator FR Signal.
6. Frequent stalling, while warming up--check IACV and idle adjusting screw.
7. Frequent stalling, after warming up--check idle adjusting screw and IACV.
Additional Steps:
. Check Alternator FR Signal. Have alternator inspected, if idle speed fluctuates with electrical load. The FR signal communicates to the ECM how "hard" the alternator is working to meet the electrical demands of the car, including the battery and any loads which aren't monitored by the ELD. This square-wave signal varies in pulse width, according to the load on the alternator. The ECM places, approximately, 5 reference volts on the wire. The voltage regulator will drop this signal to approximately 1.2 volts, in proportion to alternator load. The ECM compares the electrical load (ELD) signal with the FR (Charging Rate) signal from the alternator and uses that information to set the idle speed and turn the alternator on and off. This helps fuel economy.
. Clean main ECM ground on thermostat housing.
. Reset ECM, by removing the 7.5 amp Back Up Fuse, in the under-hood fuse box, for 10 seconds.
. Replace PCV Valve, cleaning hose with brake cleaner spray.
. Substitute a known-good ECM. If symptom goes away, replace original ECM.
Check the ICM (Erratic RPM and PGM-FI System)
When the engine is cold, the air conditioner compressor is on, the transmission is in gear (automatic transmission only) or the alternator is charging, the ECM controls current to the Idle Air Control (IAC) Valve to maintain correct idle speed. Here's an overview of how the PGM-FI System works.
Background:
Various inputs to the ECM are TDC/CKP/CYP Sensor, MAP Sensor, ECT Sensor, IAT Sensor, TP Sensor, HO2S, VSS, BARO Sensor, EGR Valve Lift Sensor, Starter Signal, Alternator FR Signal, Air Conditioning Signal, Automatic Transmission Shift Position Signal, Battery Voltage (Ignition 1) Brake Switch Signal, PSP Switch Signal, ELD, and VTEC Pressure Switch.
Inputs are received and processed by the ECM's Fuel Injector Timing and Duration, Electronic Idle Control, Other Control Functions, Ignition Timing Control, and ECM Back-up Functions. These are the primary functional areas within the ECM.
Outputs from the ECM control Fuel Injectors, PGM-FI Main Relay (Fuel Pump), MIL (Check Engine Light), Idle Air Control (IAC) Valve, A/C Compressor Clutch Relay, Ignition Control Module (ICM), EVAP Purge Control Solenoid Valve, HO2S Heater, EGR Control Solenoid Valve, Alternator, Lock-up Solenoid Valve A/B (A/T), VTEC Solenoid Valve, and Interlock Control Unit.
Idle RPM:
Once you understand how the PGM-FI system is configured, it's easy to see how the ECM, Idle Air Control Valve, and the Ignition Control Module affect idle rpm. If the ECM's Electronic Idle Control function is not working properly, then it cannot properly control the IAC Valve. Likewise, if the ECM's Ignition Timing Control function is not operating properly, it cannot properly control the ICM (igniter). Obviously, idle rpm will also be affected if there's a problem with the IAC Valve or the ICM. As stated above, the ECM controls current to the Idle Air Control (IAC) Valve to maintain correct idle speed. This cannot happen if the IAC Valve is failing. The same situation exists if the ICM is failing. The ECM will tell the ICM to open and close the primary voltage circuit going to the coil and it won't respond properly. The result will be erratic spark plug firing and erratic rpm.
Conclusion:
If you are experiencing erratic idle rpm, try and isolate whether the problem is caused by the ICM (ignitor), IAC Valve, or the ECM. My experience has been that a failing ICM is usually responsible for the problem. Keep in mind that tachometers are connected directly to the ICM. Therefore, a fluctuating tachometer needle is often a dead giveaway. Heat and poor preventive maintenance (causing high secondary voltage to be discharge on internal distributor components) frequently causes the ICM (and coil) to fail. Besides performance, this is another reason why it's important to regularly replace spark plugs, spark plug wires, rotors, and distributor caps. Electricity will always follow the path of least resistance, even if it isn't the intended one. Our job is to ensure the intended path is the path of least resistance.
Ignitor (ICM) and Coil Replacement:
1. Disconnect negative battery cable.
2. Remove hex head machine screws, securing distributor cap to housing, using an 8 mm nut driver.
3. Move distributor cap and wires off to the side.
4. Remove machine screw securing rotor to shaft, using a #2 Phillips head screwdriver. It may be necessary to "hit" the starter once or twice, in order to rotate rotor for access to mounting screw.
5. Remove rotor and leak cover.
6. Unfasten ignitor wires, remove coil mounting screws, and set coil aside. Note: Removing coil first improves access to igniter.
7. Unfasten screws securing igniter to housing.
8. Remove ignitor from distributor and unfasten screws mounting ignitor to heat sink.
9. Coat back of new ignitor (or old igniter, if reusing) and male connectors with silicone grease. Silicone grease increases heat transfer to heat sink. Failure to apply silicone grease will cause the ignitor to quickly fail.
10. Mount ignitor to heat sink and reinstall ignitor, igniter terminal wires, coil, coil wires, leak cover, rotor, and distributor cap. Ensure female ignitor terminals fit snugly--crimp with pliers, if necessary.
AutoZone can test ICMs and coils for free. If you plan to keep the car, I would replace the ICM due the age of your Civic.
Sep 15, 2010 | 1991 Honda Civic
I replaced the 50A51-495 two stage automatic interrupted ignition control and must have not correctly connected the low voltage wires. The furnice fires ok but the fan doesn't start. The LED light flashes...
The white wires are neutral. The low voltage wires are used on the thermostat terminal and the 12 pin connector. The high voltage wire uses the spade terminals. Trace back the wires to each component and you will know which connection goes where.
Dec 02, 2009 | Honeywell Electronic Programmable...
Heat wave
It is not a heat wave it is the electro magnatic radiation, you feel it like heat.
It is very hurmfull for human *& a cause of cancer. Just replace the panel it has manufactureing defects. Act fast
Feb 18, 2008 | Astar LTV-3201 32 in. LCD Television
TV signal problem?
look on the lcd website and see if there is an update for the lcd bios.
if you play a dvd is the issue the same.
try using a different connection to the cable box sometimes thats the issue.
try channel 3 /4
then composite video
then component 3 color
then DVI or svideo
with one of these you may see and improvement in video and sound
Feb 17, 2008 | Televison & Video
Pc automatic turn off
see the system temprature is cool it happen normally bcoz ho heat see your graphic card fan is working fine and it is not generating more heat. bye
Sep 12, 2007 | Acer AL1916W 19" LCD Monitor
42" AKAI plasma screen problems
This is a sign of a lack of the luminance signal which may denote a problem with the chromanance signal ariving fast to the screen then the Luminance signal this is video problem. You will need to have a qualified TV technician look at this. You can find one on FixYa.com, or look in your area for one.
Aug 25, 2007 | Akai LCT3201AD 32 in. LCD Television
Lcd heat
it seem like water must have entered the set get it serviced
Aug 23, 2007 | Motorola Mobility RAZR V3
Nokia 6610 Logo
67 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
