Question about Daewoo DTQ-13P2FC 13" TV
Its set on line can't get it to tv and remote isn't working
There should be an imput button on the front to the tv
Posted on Sep 26, 2009
Batteries are good. However TV isn't on right channel to show any programming what to do?
Hi William,
To confirm if the remote control is working fine, aim the infrared emitter of the remote control to your cellphone camera, press any button key and check if the infrared will flash to your camera. Watch this video on how to do this trick.
Also, does the front panel button key of the TV isn't working?
Jdvillanueva
Jul 09, 2011 | Toshiba CT-9995 Remote Control
TV isn't responding to the remote
Hello, sorry to hear that you having issues with your remote or TV.
First, comes the most common questions but its worth a shot, Did you replace the batteries?
Second, You could try and clean the infrared eye on the tv with a moist cloth to make sure the window on it is not dirty or blocked from the line of sight of the remote.
Also check you batteries once more, also take the batteries out of the remote and push on the buttons as one ore more could be stuck causing the remote to malfunction.
Worse cases are bad remote or bad control board in the TV witch cause it not to respond to the remote. First check the remote very well. You could also replace the remote at www.remotes.com or purchase a universal remote as well.
Only if the new remotes do not work you would call it a bad control board in the tv witch could cost around $90 to replace if there are part available.
Most cases would be the remotes batteries or connectors itself or batteries incorrectly installed.
Thanks for using Fixya.com
Regards
Rulds2008
Jun 14, 2011 | Sylvania 6419TD 19" TV
I have a soniq 42"
Ah, the old universal remote isn't so universal anymore is it? Most "universal" remote controls were designed for the old tube type television sets. There are some seriously nice universal remotes for new flat screen TV's, but most of them are pretty pricey. The only reasonable flat screen universal remote that I've found (that actually works) is the Vizio HDTV Universal Remote. It's about $25, and believe it or not ... Wal-Mart carries it in the store.
May 16, 2011 | Televison & Video
What is tv code for remote ?
Unfortunately Its not that simple, every remote has its own codes for different brands. There isn't 1 set code for all brands of remotes so would have to know what type of remote it is and maybe we can find the info on the net.
May 13, 2011 | RCA 20V500T 20" TV
Sanyo television doesn't turn off either by using the remote or by turning it off at the tv.All other fuctions work using the remote or directly on the set.Even using the sleep timer doesn't turn...
Unplug the set and hold the power button for 30 seconds. Plug it back in and see if that fixes it. If it doesn't then it sounds like there is a problem on the board underneath the power button. Something isn't allowing the circuit to be cut.
May 05, 2011 | Televison & Video
NEED A 4-DIGIT CODE TO PROGRAM MY FISHER TV "1982"MODEL.
I have a universal remote for an older model Fisher TV. The only code they list is 0154. Hope that helps?
May 06, 2008 | Big Button TV Universal Remote
My TV Says Line and Displays Just One Channel
Unfortanatly, your gonna need the original remote or a simular one to get to the channel programming mode in the menu. You can go to http://remotes.com or call 1-800-remotes and get one for your set. Im sorry i couldnt assist you more. Good Luck
Jul 12, 2006 | Panasonic PV-M2048 20 in. Combo
Daewoo DTQ-13P2FC 13" TV Logo
51 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
