Question about Whirlpool AWM8143 Front Load Washer
Getting "FH" on display, what does this mean - how do I fix it?
Malfunction is water not entering or not detected. Check tap, cold inlrt valve, pressure switch.
Posted on Sep 30, 2009
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
I have a whirlpool duet ht, and FH is coming up on the screen. what does that mean?
Hello & Welcome to FixYa
FH error is displayed when the control detects no water entering the machine. To clear this error press and hold the PAUSE/CANCEL button twice. You can then check if the water inlet valve is fine and not clogged with foreign particles, try to clean it. If the water inlet valve appears to be fine then check if the pressure switch hose is properly connected to the pressure switch & tub. Please get back to me if you have any questions.
Kevin
Aug 30, 2011 | Whirlpool WFW8300SW
With 26 minutes remaining FH appears where the time is displayed and the wash stops. What does FH mean
Kevin
May 03, 2011 | Washing Machines
The machine displays FH, what does this mean?
"FH" is a No Water Detect error.It is an indication that you either have no water coming into the washer, or very little water at all. Check whether the water taps are turned on sufficiently, the inlet hoses are not kinked, the water inlet valve is not clogged, you don't have a siphoning issue, and/or the drain pump is working.
Thank you !!
Jul 02, 2010 | Whirlpool AWM8143 Front Load Washer
The add garment light stays on and the FH shows up
Here's a link to the codes and what the possible cause's could be.
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
Hope that helps a little.
Dec 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag epic
hi there,
the FH error means it's either you have a drain problem if there is water in it or if if there is now water in it, make sure that both water inlets are turned all the way up. check to make sure that you don't have any water leaks anywhere visible.
Oct 03, 2008 | Maytag EPIC MFW9700S Front Load Washer
Help with whirlpool awm 8103/1
You probably need a new heater element
Nov 25, 2007 | Whirlpool AWM6120 Front Load Washer
Washer trouble
fh means no water coming into washer. remove cold water line from back of washer and see if the screen in the valve is clogged. if so, remove screen and clean it, if not replaced water valve
Nov 22, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWM8143 Front Load Washer Logo
196 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
