Question about Dell Latitude D510 Notebook
Dell latitude D510
My laptop just stops and these little black marks fill the screen. i have to hold the power button for it to turn off then when i turn back on it has a black screen. i have to do it 3 or 4 times before i can use it again. please help
  • 56 Answers
There's a problem with your video card...i suggest your bring that to the service center to fix that problem...cause the laptop is highly sensitive component..
Posted on Dec 17, 2007
Dell latitude d510 has no power
Please check out the following steps to confirm the real issue:
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad
6. The motherboard could be defective & needs to be replaced.
I think the most likely cause is that your dell charger is broken, just try a new charger to test:
Replacement Dell Latitude D510 AC Adapter 90Watt 19.5V 4.62A
Dec 04, 2012 | Dell Latitude D510 Notebook
My dell latitude d510 cpu fan won't start when i turn it on
sound like a faulty fan or the fan's power lead check all connections soldering and plugs for secure dust free connections or replace the fan
hope this helps
Oct 09, 2012 | Dell Latitude D510 Notebook
LapTop will not power on. What do I do to fix it?
try to turn off the laptop. Remove the cables and battery & then press/hold power button for 8 secs. Reinsert the cables and battery then turn it on. Call tech support if symptom persist
Apr 24, 2011 | Dell Latitude D510 Notebook
How to turn on the wifi in lattitude d510
Hi Friend, In order to turn on the wireless switch on Dell Latitude D510 laptop you have to press and hold the "Fn" key in blue color and then press the key "F2" for once and then release both of them. It will turn on the wireless switch of the system
Dec 11, 2010 | Dell Latitude D510 Notebook
My dell Latitude D510 starts up, but the screen remains black.
Check the lights on the power LED. If it is steady green and there is no display then your computer is clearing POST, and there might be a Video card or screen backlight issue.
However, if the light is blinking green or amber etc then its a post issue and you will need to get the computer checked by a hardware technician.
Thanks. If this was helpful, then kindly rate me.
Nov 10, 2010 | Dell Latitude D510 Notebook
Dell latitude d510 want power on
Why can't you dell latitude d510 power on?You didn't descript your dell latitude d510 problem clear even.It may be the problem of ram,graphics card ,mainboard,or dell latitude d510 battery.
May 31, 2010 | Dell Latitude D510 Notebook
I have a dell D510 latitude. AC power OK - doesn't charge battery
The battery of the dell D510 latitude is completely bad and need to be replaced. i suggest you get another one and avoid the battery running completely down before charging it.
Compliments and I wish you best of luck
Dec 24, 2009 | Dell Latitude D510 Notebook
Dell Latitude D610 Laptop wont turn on
Press the volume button and the power button at the same time. Hold them down untill the diagnostic program starts. Let it run it's course. It will stop on the problem. Fix the issue. I had the same issue. It was a simple world clock setting for me. Go figure?
Feb 02, 2009 | Dell Latitude D610 Notebook
Dell latitude d510 cannot recognise harddrive
Doesn't sound good. A bad cmos battery can cause symptoms like this (small battery inside the computer to run the clock when it is off).
Although I am afraid it is probably more like the BIOS is corrupt. Which is what is called in a bricked state. You may find info on the Internet for tricks for trying to get it unbricked, but they don't always work. :(
Jan 18, 2009 | Dell Latitude D600 Notebook
Restart always
sounds like a reload of the operating system, and or your hard drive is corrupt. See if it will boot into safe mode (F8) on startup. You can also run diagnostics on it by holding down the FN key when you push the power button and see what happens.
Oct 22, 2007 | Dell Latitude D510 Notebook
Dell Latitude D510 Notebook Logo
70 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
