Question about Garmin Nuvi 660 GPS Receiver
Cant get sattelite signal on my gps nuvi 660 - Garmin Nuvi 660 GPS Receiver
    President:
  • 1,111 Answers
Try the master reset.
note: that the master reset will erase all your saved data
with the unit off,and unplugged, try pressing and holding your finger on the low right corner of the screen and slide the power switch to the on position until you see the message "confirm if you really want to delete all user data?" hit yes and let it restart. then it will set up the nuvi again, so follow the prompts.
if that fails, hook up the nuvi to the web updater and get the latest update
(actually i would do this either way)
bill
Posted on Sep 27, 2009
No sattelite on nuvi 660
Common problem due to a failed part on the GPS receiver board. Please see this link for more info.
http://www.sharc.net/gps_antenna_repair.htm
- Jim
Feb 02, 2011 | Garmin Nuvi 660 GPS Receiver
My garmin nuvi 660 na is locked and i cant unlock it
There should be a small pinhole for a reset button. Press and hold this reset button for 60 seconds. Then turn the device back on.
Mar 25, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 Can not locate Sattelites
Please read the solution that resolved this problem for someone else. Most likely, you have already tried this. However, the antenna of your Nuvi 660 is the same as the 3xx Nuvi series. I know this because I have worked on them.
http://www.fixya.com/support/t1115882-garmin_nuvi_360
If the above procedure does not work for you, the entire antenna assembly will need to be replaced.
The other option is to purchase an external antenna for your Nuvi and plug it into the external antenna port (gold connector) on the Nuvi antenna assembly.
Best wishes,
- Jim
Oct 21, 2008 | Garmin Nuvi 660 GPS Receiver
GPS & XM
I have both a 660 and xm...no problems
May 01, 2008 | Garmin Nuvi 660 GPS Receiver
Loss of signal after about 10 minn of time
If it happens around the same suburb the sattelite can't get to that area.
Or it is programmed for another location meaning : it wont display most of the places near you.
Or if its old it wasn't programmed with all the streets as new streets do get built alot.
Also this GPS is a pretty bad one as I am already dealing with 5 others They are all 660s and are the only GPS with problems.
Hope this helps - Josh
Jan 30, 2008 | Garmin Nuvi 660 GPS Receiver
Sat nav
NUVI 660 ,
Well sir, did you flip up your antenna parallel to earth surface as mentionned into the manual.
Without the antenna you will not be able to get any signal.
Dec 17, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
120 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
