Question about Pegasus Technologies Elongated 2 Piece Toilet by Pegasus - 15 3/4 Inch Bowl Rim Height
Pegasus toilet tank will not refill
Pegasus tank will not refill after flushing, the line is clear and lots of water pressure, nothing is stuck, the toilet is brand new, does anyone know of any common problems such as adjusting anything or how to fix?
  • 54 Answers
Most likely the washer came off and is stuck in the shut off valve or the float is stuck all the way up. Checkk adjustment screw in the top of the water control valve to make sure it is not turned all the way in.
Posted on Sep 26, 2009
Kohler cimarron very noisy when flushed
You probably have one of the newer Cimarron-series toilets that feature what Kohler calls "AquaPiston" technology. These gadgets use the water pressure in your supply lines to pressurize a charge of flush water in the tank, causing the flush water to rush into the bowl at high pressure and velocity. Many Cimarron-series toilets use only 1.28 gpf (gallons per flush), compared to the current industry standard of 1.6 gpf for conventional gravity-flush units. Reducing the gpf rating by 20% requires pressurizing the water in the tank, and the release of pressurized water makes a lot of noise. I'm afraid your toilet will always be noisier than what you may be used to.
Sep 22, 2017 | Kohler Home
After flushing the toilet with the fluidmaster 300 installed, and during the tank refill, the refill valve emits an extremely high pitched squeal until just a second or two prior to the tank being...
hiya:) This is a result of a very minor design error (i am a big fan of FluidMaster products) combined w/a slightly higher than normal water pressure situation or foreign matter stuck in the valve somewhere. try turning down the water pressure via the shuttoff under the toilet tank:)
Jul 26, 2011 | Home
Elijer Diplomat toilet flushes perfectly, but after the water in the bowl takes forever to fill up again. You have to wait 10-15 min. before the water is up to normal level and it will then flush...
Pressure assisted toilets have a stainless steel tank that refills under lid,if your refilling bowl it only needs to fill trap for smell,the pressure assist does the rest,thats part of the water saving of the toilet,you don't have a lot of water in the bowl
Jan 28, 2011 | Eljer Aqua-Saver 12" Two-Piece...
I puchased a new Pegasus toilet about 6 months
it is filling up too much you can adjust the arm there is a screw on the side that adjusts the leval of water in the tank
Jan 22, 2010 | Pegasus Technologies Elongated 2 Piece...
My pegasus won't flush with enough pressure to complete it...
Maybe the shut off valve is not open all the way .....
can you adjust the fill valve so that more water comes into the tank ... more water more flush !
Dec 07, 2009 | Pegasus Technologies Two-Piece Round...
PEGASUS TOILET DOES NOT FLUSH COMPLETELY EVERY TIME WE SOMTIME FLUSH 4-5 TIMES
sometimes if you change the flapper and add more water to the tank by adjusting the fill valve they will flush with more power
Aug 08, 2009 | Pegasus Technologies Pegasus Toilet Paper...
Pegasus HET toilet splashes water when it flushes
make sure the fill valve is not cracked,that's the long tower looking thing on the right side of the toilet when you stand in front of the unit. you can replace this part at homedepot. it is called a fluidmaster 400A.good luck.
Jul 16, 2009 | Home
Toto Toilet - no water flow to refill tank after flush
Remove the tank lid and look at the fill valve. Is it a yellow valve?
This fill valve is common on the Toto Toilets and can easliy plug with debrie.
They can be disassmbled and cleaned. however, I usually just replace the valve with Fluid Master Fill valve.
You will also want to check the water coming into the toilet by turning off the water that supplies the toilet and disconnecting the water supply line. After removing the water supply line turn on the water at the valve to make sure that the water is flowing properly. Check the supply line also to make sure it is not plugged.
Be sure and place a small container to catch the water that will come from the valve. A towell will also help from making too much of a mess.
If the Supply line and the valve are clear the problem is in the fill valve.
The G-Max system denotes the Flushiing system which is a 3" flapper that allows the water from the tank to flow into the bowl quicker.
Good Toilets!
sanray
Jan 05, 2009 | Toto Toilets ST753S 01 Cotton Dartmouth...
After flushing, water does not refill the tank.
yeah sounds as though the ball valve or water inlet valve is stuck in the closed position or jammed so when you flush the loo the water doesnt refill.
Isolate water service remove valve as required clean/replace re instate test & leave working
Dec 15, 2008 | Toto Carlyle 1-piece Elongated Bowl Toilet
Pegasus Technologies Elongated 2 Piece Toilet by Pegasus - 15 3/4 Inch Bowl Rim Height Logo
473 people viewed this question
Top Pegasus Technologies Home Experts
john h
Jim Goldsmith
Jim Goldsmith
Paul Carew
Are you a Pegasus Technologies Home Expert? Answer questions, earn points and help others
