Question about Whirlpool Duet GHW9150P Front Load Washer
Cleaning the washer, since if door left closed, clothes, smell like mildew, know there is a solution.....lost my book and have done in the past
  • Whirlpool Master
  • 2,605 Answers
Run the machine thru a normal or quick wash cycle adding only bleach, but before starting clean out around the door bellows by wiping with bleach on a rag. This works quite sufficiently for most folks. If on a septic system you can also substitue bleach for "pure white vinegar" hope that helps good luck
Posted on Sep 26, 2009
I have an IQ touch front load washer. lately I have noticed a mildew smell coming from the clothes and drum after washing. i have followed the manual and completed the refresh and comlete cleaning...
Water can remain in ANY washer after the load is done. With a top-loading washer, it's easy to leave the lid up so that the water evaporates. With a front loader such as yours, however, the open door can take space in your laundry area, so we usually close the doors. I suggest that you take a dilute solution of chlorine bleach and water and put it on a disposable cloth and wipe down the inside of your washer as well as the areas around the door itself and the part of the washer that the door closes onto. Once you've done this, leave the door open until the smell dissipates OR overnight. If you will get into the habit of leaving the door open for a couple of hours after you're done with your laundry, you will probably solve the problem.
I really hope this helps. If it does, please come back to Fixya and rate my solution.
Jul 09, 2011 | Electrolux Washing Machines
Washer smells like mildew after a load of wash, clothes smell.
Use a washer cleaner like AhFresh (all three tablets) with the tub clean cycle, no clothes in the washer. Now, only use 1 to a maximum of 2 tablespoons of HE laundry detergent per cycle. Due to low water consumption of these machines, you must adjust soap usage or odors will result. It may also help to leave door open for a hour or so after cycle is finished to allow inner tub to dry completely.
Jan 12, 2011 | LG WM-2277HW Front Load Washer
Smell of mildew on our towel and sheets
This is probably happening because the clothing is being left damp in the washer. When it is warm during the summertime mildew will grow very quickly in the towels. On front load washers you need to leave the door open when not in use to keep mildew from growing. You should wipe out behind the inner seal any moisture when you are done doing laundry. This is an issue for most front loaders. Some front loaders have a clean washer cycle that uses bleach to sanitize the drum. Other washers like the Samsung have a block of silver and release silver ions in the wash to sanitze the clothes.
Sep 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
I have sour mildew smell problem with my clothes
Look inside the door to the gray rubber ring gasket thingy. Pull apart the sides and look in. Betcha a dollar to a donut there's mold in there. It's a gross, nasty problem whirlpool customer service doesn't give a damn about.That's where water sets after wash cycles. There are tablets call "Affresh" which can be run with hot water for a cycle to attempt to clean out the mold/mildew. Not cheap, not fair, and probably will only be a start to a maintenance type cure if you've had the washer for awhile. May take some manual labor with bleach as well. NOT a sanitary washer. This is an unbelieveable problem with a washer. Piece of ****.
Aug 06, 2009 | Whirlpool LHW0050PQ Front Load Washer
I have exactly the same problem!
Try using the tub clean cycle and use a good dose of bleach or vinegear. Here is how to run the tub clean cycle.
To start the TUB CLEAN cycle:
1. Remove any clothing or items from the washer and close the door.
2. Open the dispenser drawer and add liquid chlorine bleach to the bleach compartment.
NOTE: Do not add any detergent to the detergent compartments. Excessive suds may be produced and leak
from the washer.
3. Close the dispenser drawer slowly.
4. Power On and then press the Extra Rinse button for 3 seconds. (Prewash option will be selected.)
5. Press the Start/Pause button to start.
6. After the cycle is complete, leave the door open to dry around the washer door opening, door seal and
door glass.
Jul 11, 2009 | LG WM2688HWM TROMM SteamWasher
LG washing machine has AWFUL mildew smell
Don't know if this is the same as your problem, but I had a Kenmore washer, (made by Whirlpool) that did the same thing. It was a high efficiency model without an agitator. I finally found out that this type of washer never drains completely but always has some water left in it. This water is somewhere internal that cannot be seen unless the machine is taken apart. That water goes bad and stinks. Everything smelled like mildew and for some while my husband thought I was was washing clothes and leaving them in until they dried. I ended up having to just buy a new machine and when the stinky washer was taken away, just tilting it caused all this foul water to come out everywhere. Also I found this on the internet http://www.consumeraffairs.com/homeowners/lg_washing_machine.html
scroll down and see how other people feel about this machine. I decided that instead of buying the newest, latest, greatest, with all the bells and whistles appliances, from now on I will buy the time tested, plain jane models.
Jun 02, 2009 | LG WM-2277HW Front Load Washer
Washer smell
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 06, 2009 | Kenmore 24032\24036 Top Load Washer
Clothes have a musty smell if left in the washer
Make shure to do a cleaning cycle. As well, wipe out the inside, the rubber gasket and the door when done washing for the day. We also have found that
leaving the door "Open" for several hours, when finnished, eliminates any future
smells.
Jan 10, 2009 | Kenmore Elite 45986 Front Load Washer
Smells of mildew and so do clothes
If the odor does not go away, it is probably time to change the rubber door boot, or you have something stuck in the drain. Take a good look at the rubber around the door. If it has mildew spots and/or mold, it generally won't go away. Pull the rubber back a bit and look BEHIND the boot as well. You may have some lost items stuck in the boot causing the odor. Last of all, UNPLUG the washer and remove the lower kick panel under the door by removing the three 7mm screws and check the drain pump for foreign objects. There's only one pump inside the washer so it won't be too hard to find. It is usually white in color and has a screw off access cover. There is a bit of residual water that remains in the wash tub all the time. You will need to drain this first or you will have a mess to clean up. You can use some towels or use a shop vac. If you use towels, lay them down around the drain pump and remove the access cover. If you use a shop vac, pull all the residual water from the wash tub through the drain line. Sometimes this pump will build up with all kinds of scunge from soap residue and/or foreign object getting caught. Clean it out real well and run the washer on a bleach cycle with the hottest water setting you have. Let me know if any of this helps you. If you decide to change to door boot, post a response to this solution and I will give you step-by-step procedures.
Aug 26, 2007 | Kenmore Elite 45986 Front Load Washer
Washer door ring has mildew on it and is causing my clothes to smell moldy. What can be done to get rid of this? I've used bleach, and cleaners directly on the rubber ring, but with out success.
Unfortunately, when mold and mildew impregnate the rubber door boots on these models, it's nearly impossible to get it to go away. I would recommend replacing the door boot and follow these diligent preventive measures to keep the problem from coming back: 1. Check the area in and around the door boot after each wash for lost articles of clothing like underwear and socks. Also, clean out any lint or debris that collects under the boot. You might want to think about using a mesh garment bag for small items in the future. 2. Wipe the area periodically with a towel to get rid of the accumulation of soap deposits and dirt. This means wiping BEHIND the door boot where it meets the wash tub as well. I recommend waiting until you get ready to do a load of towels. Clean the area with a towel, then throw it directly in the wash. 3. Leave the door OPEN between washes to allow the door boot to air dry. Due to the nature of these door seals, they seal air tight and create an environment for mildew and mold to grow. 4. Run the washer with no load on the hottest cycle you have with nothing but bleach about once a week to keep bacteria to a minimum, and to flush the drain lines and pump. The door boot costs about $80 to replace, but it may be your only solution to getting rid of the smell and bacteria. Let me know if you decide to replace it. I can give you some pointers.
Jul 28, 2007 | Kenmore 44072 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
97 people viewed this question
Dan Webster
Dan Webster
Sal De
