Question about VeriFone (M19755014US1) Magnetic Card Reader
I have a Vx570 and the display is showing everything inverted or backwards like reading it in a mirror. How do I switch it back?
Why is everything upside down when looking in the simmons telescope
Most "astronomical" telescopes do invert. You can add an inverting mirror between the telescope and eyepiece, like this one:
http://www.celestron.com/browse-shop/astronomy/visual-accessories/diagonals/125in-star-diagonal
You'll get rightside up, but left/right backwards images.
Sep 07, 2014 | Optics
Back up mirror
go to settings and look for the camera settings to switch the orientation
Sep 30, 2013 | Car Audio & Video
Everything is upside down! why? how do i fix it?
Astronomical telescopes show upside down images. No up or down in space. To invert the image would require more glass and or mirrors.
You can purchase an erecting prism to use in viewing terrestrial targets.
http://science.howstuffworks.com/telescope23.htm
Read my Frequently Asked Questions TIP on my profile page.
Mar 30, 2010 | Tasco Specialty 301051N (100 x 50mm)...
I have a Fujitsu Siemens Lifebook s7020 with no backlight. The display is showing everything but it's hard to see because there's no backlight. Everything is also fine with an external screen. I have a...
The Inverter board must be tested and eventually replaced. The inverter is the small board located at the base of display. This is connected to one side to the backlight lamp, to which supplies AC high voltage, and on the other side to motherboard, where receives DC voltage.
Inverter contacts to otherboard and to lamp must be tested , using a multimeter to read volts. The inverter is an AC board, and for safety reason the test must be done by a trained repairer.
If the inverter is OK check the contacts to motherboard and wiring harness to motherboard..
Also ensure that light is not just dimmer because energy save mode is on, or because the laptop is running on batteries.
Sep 07, 2009 | Fujitsu Siemens LifeBook S7020 Notebook
Touch Keys and Screen
I think this a problem related to the flex cable that connects the main phone body to the sliding screen. Over time the flex cable wears down as it slides and results in a whole range or problems such as: display acting weird (eg. mirror-image and inverted colours), speaker not working, off-button not working etc.
Flex cables are cheap to buy on ebay (a few dollars) and there's internet sites that show you how to open the phone and replace them. (google: samsung u700 replacement flex cable)
Jul 13, 2009 | Samsung SGH-U700 Cellular Phone
Hp j5780 printer is printing backwards.
See link here or here, depending on your os, to correct this problem.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 14, 2009 | HP Officejet J5780 All-In-One InkJet...
Someone changed a setting
The setting is in the Menu. It sounds like you went to the "Image" section which lets you make the adjustments you list. Try the "Source" menu, then "Mirror". That's where you will find options for Rear Screen Projection, which makes the image backwards.
Feb 05, 2009 | BenQ MP610 Multimedia Projector
Display is backwards
The video can be reversed in either vertical or horizontal direction. To change it press left or right buttons while playing DVD. See page 29 of manual.
May 12, 2007 | Toshiba SD-P1400 Portable DVD Player
VeriFone (M19755014US1) Magnetic Card Reader Logo
76 people viewed this question
Top VeriFone Televison & Video Experts
Bosse Photos
Rozan Perry
Rozan Perry
Level 1 Expert
Are you a VeriFone Televison and Video Expert? Answer questions, earn points and help others
