Question about Microsoft Windows Server Standard 2003 for PC
What is replication
What is the windows replication ? how can i apply these application on server 2003
    Problem Solver:
  • 7 Answers
Replication is just having a copy of your data. Replication is a constant or daily activity...not once a month. It allows you to have a backup plan should your primary plan fail. I am sure there is more technical explanations, but that is basically it. What r u trying 2 do?
Posted on Dec 18, 2007
I have a server running sql application. I need to create a backup system that replicates the current server to another server so that if my current server crashes; I can start the other one to provide...
This is a complex and diverse question due to the numerous scenarios.
A common setup: Dual servers setup on a fail over cluster. You basically make two servers seem as one with a virtual IP and name. Hardware breakdown is 2 servers with 5 drives each minimum. The first 2 drives the OS at RAID 1 (mirrored). The other 3 drives are the database at RAID 5 (striped). You now have hardware redundancy all the way around. When 1 drives fails, you simply replace the drive. The database is replicated and is fail safe. When a complete server fails or needs maintenance you just roll over the server / database to the other node via cluster administration.
This is just an example, but a very common SQL server setup in busisness enterprise environment.
Feb 05, 2013 | Computers & Internet
Hi , We are having 2 windows servers with identical configuration, and also we are using the windows 2003 with vendor application, We installed 8 GB of RAM in both server , But I could only 4 GB amount...
To reply your query in short. If you have any of the following versions of server it would support the maximum RAM upto 4 GB.
Windows Server 2003 R2 Standard Edition
Windows Server 2003, Standard Edition SP1
Windows Server 2003, Standard Edition SP2
Windows Storage Server 2003
Windows Small Business Server 2003
If you are using : Windows Server 2003, Web Edition
It will support only 2 GB of RAM
For your information to get a complete information about Memory Limits for Windows Releases. Please visit the following site:
If you find it useful please do not forget to rate this solution.
Jul 14, 2010 | Microsoft Windows Server 2003 Enterprise...
VMWare Clustering with Veeam or just replication
There are several advantages of clustering, as you stated, ease of server environment replication is one of these advantages. There are several others, instant fail-over replacement, swaping from one machine to the other for hardware / software maintentance / upgrades with little to no downtime during the proceedures, shared access to similar content / configurations, there are many many reasons to cluster.
you may also look into ESXi:
VMware ESXi is the easiest way to get started withvirtualization—and it’s free. Consolidate your applications onto fewerservers and start saving money through reduced hardware, power, coolingand administration costs. VMware ESXi has been optimized and tested torun even your most resource intensive applications and databases withminimal performance overhead. With VMware ESXi you can:
You can download ESXi from -=[ HERE ]=-
Nov 03, 2009 | VMware ESX Server (370598B21)
How to configure additional domain controller in win 2003
execute dcpromo to convert a win2003 to a domain controller.
Global catalog is not replicated by default to the new promoted 2003 domain controller.
Feb 17, 2009 | Keystone Microsoft Windows Server 2003...
Http/1.1 internal server error
If you are running two versions of ASP.NET, you may get HTTP:/1.1 500 Internal Server Error when creating a new Web project or opening an existing Web project in Visual Studio.
This problem may occur when IIS is not sure what version of ASP.NET to use or where to locate ASP.NET files. One of the following solutions should fix the problem.
Solution 1.
  1. Remove web.config file from inetpub/wwwroot directory
  2. Go to IIS, Right click on Default web site / All tasks / Check server extensions and let it run
  3. Reset IIS by right click on IIS or call iisreset from Run command
Solution 2.
  1. Install ASP.NET again using the following command from your Run command: C:WINNTMicrosoft.NETFrameworkv1.1.4322aspnet_regiis.exe
    Make sure to change the windows folder and ASP.NET version folder with the version what you want to install
  2. Reset IIS
Solution 3. Applies to Windows Server 2003
Note: This is a Microsoft KB article:
When you try to create a new Microsoft ASP.NET 1.1 application after you change the script mapping of the existing ASP.NET 1.1 Web application to ASP.NET 1.0 on a Microsoft Windows Server 2003-based computer, you may receive the following error message:
The Web server reported the following error when attempting to create or open the Web project located at the following URL: 'http://localhost/822319ev1'. 'HTTP/1.1 500 Internal Server Error'.
This issue occurs because Windows Server 2003 does not allow two versions of ASP.NET to run in the same application pool.
To work around the problem, do one of the following:
Restart the IIS before you create a new ASP.NET 1.1 application. At the command prompt type the following command: iisreset
OR -
Create an ASP.NET application in a separate application pool. Create the script-mapped application (ASP.NET 1.0) in a separate application pool -- for example, in the ScriptMapappPool application pool. Then, create a new ASP.NET 1.1 application in an application pool other than ScriptMapappPool. For more information about how to create an application pool, visit the following Microsoft Web site: Configuring Application Pools
Dec 10, 2008 | Acer Aspire 5610 Notebook
Active directory
An application directory partition is represented by a domainDNS object with an instanceType attribute value of DS_INSTANCETYPE_IS_NC_HEAD combined with DS_INSTANCETYPE_NC_IS_WRITEABLE. This domainDNS object represents the application directory partition root (NC head), and is named similar to a regular domain partition, for example, "DC=dynamicdata,DC=fabrikam,DC=com", which corresponds to a DNS name of "". An application directory partition can, therefore, be instantiated anywhere a domain partition can be instantiated. There is no NetBIOS name associated with an application directory partition.
It is possible to nest application directory partitions, that is, an application directory partition can have child application directory partitions. Searches with subtree scope rooted at an application directory partition head will generate continuation references to the child application directory partitions.
An application directory partition replica can only be created on a domain controller that is running on Windows Server 2003 and later and only while the Domain-Naming FSMO role is held by a Windows Server 2003 and later domain controller. In a mixed forest that has both Windows Server 2003 domain controllers and down-level domain controllers (Windows 2000 domain controllers or Windows NT 4.0 primary domain controllers), an attempt to create an application directory partition replica on a down-level domain controller will fail.
An application directory partition also has a corresponding crossRef object in the Partitions container of the configuration partition. The crossRef can be pre-created manually before creating the domainDNS object. The pre-created crossRef object must have the attribute values shown in the following table or the partition creation will fail. If the crossRef object does not exist, the Active Directory server will create one when the application directory partition is created.
Jul 09, 2008 | Microsoft Windows Server Standard 2003 for...
What is global catlog & how it works
The first domain contoller in a network is a global catlog server
global catlog do the replication in the forest and it require to create any object in the forest if global catlog is not availiable we cannot create any object
May 30, 2008 | Microsoft Windows Server Standard 2003 for...
please define users & give him restrictions as well as rights,
make them as an standard user (dont define them as an administrators) if u have some applications which have to be use by terminal users then give them only that much of applications..
dont allow them to use anyother applications..
May 03, 2008 | Microsoft Windows Server Standard 2003 for...
Replication problem
You are not given a full information in your question, maximum replication problems comes with DNS and Group Policies. If you have any previous System state Backups, restore in both the servers. i think it will resolve your problem. Next time any problem comes give full specifications.
Apr 30, 2008 | Microsoft Windows Server Standard 2003 for...
You need to either use a Domain Account if you are using Windows authentication or you need to use SQL server authentication.
The reason for this is because the user account that you are using only exists on the machine that you are on not on the machine that you will be replicating to.
Sep 24, 2007 | Microsoft SQL Server Standard Edition for...
Microsoft Windows Server Standard 2003 for PC Logo
94 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
