Question about Microsoft Windows XP Home Edition
When my laptop boots up (Windows XP), the following box opens up every time: C:Program FilesYahoo!Search, how do I get rid of it?
  • 39 Answers
This could be a registry problem. try fixing the registry by using a registry cleaner, such as reg cure or registry mechanic
Posted on Sep 26, 2009
    President:
  • 987 Answers
Goto start >run >type msconfig
then select startup tab and uncheck yahoo seach...
How to get rid of error messages on gateway laptop Model # NE56R43u to boot up laptop.
click the start tab and in the run or search box at the bottom type in this exactly msconfig then hit enter. a window will open for system configuration. click the startup tab and then uncheck items until you find the one causing the error message, for my computer it was caused by the antivirus trying to check the internet befor the wirless had started. finding the right program or could be several programs should stop your problem
Sep 23, 2014 | Computers & Internet
I let the HP asst. Install a bios update and the install is stuck at 40%. What can I do to get out of the update?
Turn on the computer and begin hitting the "F8" key when you see the BIOS screen.
This will take you to the Safe Mode menu.
Use the arrow keys to highlight "Safe Mode," then hit "Enter" on your keyboard.
This will boot your computer in Safe Mode, a minimalist manner of operating Windows that runs only essential Windows files.
If using Windows XP in Safe Mode, click the "Start" button and then click "Run." In the box that pops up, type "msconfig" and hit "Enter."
If using Windows Vista or Windows 7, click the Windows logo in the bottom left corner of the screen, type "msconfig" in the search field and then hit "Enter."
This will open the System Configuration Utility.
In the System Configuration Utility box, click the "Services" tab, check the box that reads, "Hide All Microsoft Services," click "Disable All" and then click "Apply."
In the System Configuration Utility box, click the "Startup" tab, click "Disable All" and then click "Apply." Next, click the "Close" box.
A box will pop up that prompts you to restart your computer.
Select "Restart" and let the computer restart itself, allowing it to boot to Windows normally.
If the computer still stalls when trying to boot to Windows, restart the computer and boot to Safe Mode again.
Run your antivirus program in Safe Mode, deleting any files that are flagged as viruses, spyware or malware. Restart the computer and boot to Windows normally
hope this helps
Sep 29, 2012 | Computers & Internet
Schedule record application starts automatically in background when system restats
Try this:
Disabling Startup Programs in Windows For some programs, it's smart to have them start with Windows, such as anti-virus and firewall software. However, for most programs, starting them at boot-up just wastes resources and extends startup time. There is a tool installed with Windows, called MSConfig, that allows you to quickly and easily see what's running at startup and disable the programs you prefer to run on our own after startup as needed. This tool is available and can be used to disable startup programs in Windows 7, Vista, and XP.
NOTE: MSConfig can be used to configure several things other than just startup programs, so be careful what you do with it. If you're not sure about using it, just follow the steps in this article and you should be fine.
To run MSConfig, open the Start menu and type "msconfig.exe" (without the quotes) in the Search box. As you type, results display. When you see "msconfig.exe," click on it or press Enter, if it is highlighted.
NOTE: If you are using Windows XP, open the Run dialog box from the Start menu, type "msconfig.exe" in the Open edit box, and click OK.
Click the Startup tab on the System Configuration main window. A list of all the startup programs displays with a check box next to each one. To prevent a program from starting up with Windows, select the check box next to the desired program so there is NO check mark in the box. Click OK once you have made your choices.
A dialog box displays telling you that you may need to restart your computer for the changes to take affect. Click Restart to restart your computer immediately. If are not ready to restart your computer, click Exit without restart.
Aug 26, 2012 | IBM Lenovo ThinkPad L412 Notebook
When my laptop comes on i get an error message that says jitdebuggingis enabled what can i do to get rid of this error
To get rid of this error, open up "My Computer" and do the following.
    1. On the Tools menu, click Options.
    2. In the Options dialog box, select the Debugging folder.
    3. In the Debugging folder, select the Just-In-Time page.
    4. In the Enable Just-In-Time debugging of these types of code box, select or clear the relevant program types: Managed, Native, or Script.
      To disable Just-In-Time debugging, once it has been enabled, you must be running with Administrator privileges. Enabling Just-In-Time debugging sets a registry key, and Administrator privileges are required to change that key.
    5. Click OK.
  • Oct 25, 2011 | Microsoft Windows XP Professional
    Not compatable with windows 7
    Hello
    OK, please be more specific on the exact question or problem you are experiencing.
    Kind regards
    Andrea
    Nov 26, 2010 | Computers & Internet
    When I installed and tried to run your program I get the following error: This application requires using the 4.73 help system or a more recent version. I am running Windows 7. What is the problem? Can...
    The specs for that program shows the last operating system it was designed for was XP. Let's try the easy fix first. ClickStart, type Compatibility in the search field, and click theEnter key. This will bring up the Program Compatibility troubleshooter. ClickNext and it do a quick check on your machine. It will ask you toSelect the program you're having problems with and click Next. Click Troubleshoot Program, then check the box forThe program worked in earlier viersions of Windows... Click Windows XP (Service Pack 2)and click Next. Click the box for Start the program. It will attempt to open the program as if you were running XP. After the program attempts to open, clickNext. Now it will ask if it worked for you. If so, click Yes, save these settings for this program. If you clicked Yes, every time you open the program now it will open as if it was running in XP. You're done if this worked!
    Sometimes that method doesn't work. For those cases, there is a new feature called XP Mode, which will install a virtual machine for you to run your program in. It's not too hard to get configured; it actually installs a legal copy of Windows XP for you to run your program in. Here's a Microsoft article on how to get it set up: http://www.microsoft.com/windows/virtual-pc/. XP mode will now work even if you don't have the chip installed for Hardware Assisted Virtualization Technology.
    Sep 02, 2010 | Anuman Interactive Home Budgets for...
    Laptop is stuck in safe mode Acer
    I faced the same problem with my laptop. I tried several methods. But none of them worked. But finally when I tied the following procedure it worked.
    The following instructions work on a computer running Windows XPmag-glass_10x10.gif only, this is assuming that your laptop has XP installed on it. Use this only if your computer wont come out of safe mode by restarting it.
    Go to Start > Run and type "msconfig" in the dialog box that comes up. Press Enter or OK and the System Configuration Utility box should come up. Click on the "BOOT.INI" tab. Down in the bottom left corner of the window under where it says Boot Options there will be several checkboxes. Make sure that the /SAFEBOOT box DOES NOT have a check in the box. When it is unchecked restart your computer and you should be out of safe mode.
    Dec 28, 2009 | Acer Aspire 5315 Notebook
    Loading win xp gives message script file cleanvirus.vbs not found
    Disable System Restore. Scan your computer with the free version of Malwarebytes' Anti-Malware.
    http://malwarebytes.org/
    If you don't have an Anti-Virus program, download Avast and scan.
    http://www.avast.com/
    If both scans don't detect anything, do this..
    Ctrl-Alt-Del > Processes - End the following processes in order:
    dxdlg.exe
    wscript.exe
    Start > Run > regedit - Open the following key:
    HKEY_LOCAL_MACHINE\SOFTWARE\ Microsoft\Windows NT\CurrentVersion\Winlogon
    In the right hand pane, select Userinit and delete everything except C:\windows\system32\ userinit.exe
    Make sure the processes wscript.exe and dxdlg.exe are not running.
    Delete the following files
    C:\Windows\System32\dxdlg.exe
    C:\Windows\System32\boot.vbs
    In your Windows drive, search for boot.vbs and delete all of them.
    In your Windows drive, search for kinza.exe and delete all of them.
    Enable System Restore.
    Restart your computer.
    Nov 28, 2009 | Microsoft Windows XP Professional With...
    Startup problems
    this is telling you that a Scan/checkdisk program is running.
    to get rid of this, run scandisk within windows, also go to Start/all programs/startup and remove from the startup if applicable.
    to bypass on boot-up, simply press enter beefore the program Starts to run.
    Mike @ compurepair.
    Mar 08, 2008 | Computers & Internet
    Microsoft Windows XP Home Edition Logo
    44 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Alun Cox
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
