Question about Mitsubishi CS-31305 TV
My tv turns off intermittently - Mitsubishi CS-31305 TV
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Mitsubishi Master
  • 1,632 Answers
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Posted on Apr 15, 2010
My tv (Samsung LE40B620R3W) keeps turning off intermittently
Check ur Sleeping timer modes,see it is not on like 30,60,120 mins?If ur Sleeping timer modes is off.Than ur tv power supply board is the causes and the problems,it not consistinly giving ur tv the right voltages anymore that why ur tv it turning off intermittently.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jan 13, 2011 | Samsung LE40R74BDX 40 in. LCD Television
My tv will lose volume for no reason while we are watching it. I try to press the volume button but nothing happens. I have to turn the tv completely off to regain volume. I have only had the tv for a...
This tv have intermittent Tuner signal board problems,this tv will develope alot more problems later for devices and for the incomming tv broadcasting signal cable attached to it.Take this back where u bought it,get a replacement.Don't take warrenty repairs,because intermittent problems will come and goes will be be there for weeks or months,until the problems is develope for good,than it can be fix.Get a tv replacement,a new tv replacement ok,don't take warrenty repair,when dealing with intermittent problems.
Dec 27, 2010 | Emerson LC320EM9 32 in. LCD HDTV
I have a GE 31 inch TV. Intermittently, it will
most likely buttons on front panel are going bad.
Aug 11, 2009 | Televison & Video
MAGNAVOX 27" TV, PICTURE START UP PROBLEM
This problem with your television set is more than likely a problem with intermittent component failure. The fact that the television turn on for awhile is a sign the the component or components are intermittent.The reason the television turns off is that it goes into the protection mode caused by the intermittent component or components. They are unstable and are causing unstable voltages supplies to appear in the circuits. The television has a built in feedback circuit that will detect the faulty operation and turn off the television. When it stabilizes again the television turn back on. This is usually a sign of aging or faulty components. The problem will only get worse and the television should be thoroughly tested. You can call Magnavox customer support at this telephone number 1-800-705-200. Give them the model number of your television and tell them about the problem you are having with intermittent turn on of the television. They will be able to tell you where to take the television for testing and service. I hope this information helps you with your problem.
May 19, 2009 | Philips Magnavox 27MS343S 27" TV
TV would turn on intermittently
Hiii...
what chassis number of TV you have ?
Thank's
[vrya]
Jan 08, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
TV intermittently turns off, then on, showing initial menu
Probably time to put the poor thing to rest. This is your chance to move into the HD world. That's exciting!
Dec 14, 2007 | Televison & Video
TV won' turn on
Solder, solder, solder! Shut down circuits protect crts to avoid permanent damage. If any of the deflection circuits are defective, or intermittent, shut down occurs. I have not only seen bad solder on deflection circuits, especially vertical, but also intermittent connections on the yokes themselves. I've also seen shorted convergence ics cause shut down. Don't forget solder connections in the power supply.
Jul 05, 2007 | Mitsubishi WS-55807 TV
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
