Question about Fisher Dishwashers
Fisher and Paykel nemo dishwasher stuck on rinse
Disherwasher will only do rinse. If I hold down the start/reset button for a while I can select other modes but they don't work.
  • 351 Answers
SOURCE: Problems with Fisher & Paykel Nemo model DW681.
is there somthing stuck in the wash motor,can you hear a humming noise ? if yes remove motor and see if you can turn it by hand.hopr this helps.
Posted on Mar 14, 2008
SOURCE: Fisher & Paykel Nemo Dishwasher
try ensuring that the container is completely dry before putting in powder
Posted on May 18, 2009
  • 784 Answers
SOURCE: Fisher Paykel dishwasher drawer won't stop.
Let's go to diagnostic test mode to see if you can retrieve the the actuator hence the tube out.
1- Press Lock button and start/pause key until the display showing up.
2- Press Power to show HO.
3- Press start button to advance the display until you see P2 for draining, if you pass, keep doing it to get it back in a loop.
4- When at P2, press lock to turn on, press a again to turn off.
5- Listen to the sound of the pump. If you hear nothing that means the pump is dead or stuck.
6- The Motor has 2 directions: one for, Rinse and one for Drain. When you done with the diagnostic, press the power button to get out of the mode.
7- If this is the case, unplug the power then remove the rack, the bottom stanless steel plate with holes then take out the rotor to clean up. It is a good design the stator is outside of the tube, so you don't have to worry too much about the complication.
8- Make a note of all the positions so you can put them back the same as they were. Good luck
Posted on Sep 09, 2009
SOURCE: fisher n paykel nemo dishwasher won't go. Sounds
Check to see that the outlet pump (underneath) isn,t stuck eg sumething stopping the pump from turning.Also check that the outlet is clear where it connects to the sink outlet.Hope this helps.
Posted on Dec 13, 2009
SOURCE: dishwasher problem
i had the same problem with a fisher paykel nemo dishwasher beeping at end of cycle, as im a mechanic i was curious to pull it apart and see how it works, i pulled the main control board out and unscrewed the three screws holding it all together and inspected the circuit board, and what did i see, a dry solder on the blue relay box or something, resoldered it, reassembled it and now works a treat, hope that helps
Posted on Jan 26, 2011
Why cant i hard reset my kyocera C6740
1. At the very beginning hold down the Power key in order to switch off the cell phone.
2. Press and hold the Volume Down + Power button for a few seconds
3. You should release held keys when the Recovery Mode starts.
4. Afterwards, press Volume Down a few times to highlight "wipe data/factory reset", and then push the Power button to confirm this option.
5. Next, select "Yes--delete all user data". Use Volume buttons to scroll and Power rocker to select
6. When the Recovery Menu appears once more on the screen, choose "reboot system now".
If this didn't work:
Go to "Settings", then-> "Backup & Reset", after that tap "Factory data reset", choose "Reset phone", and select "Erase everything"
Aug 11, 2016 | Kyocera Cell Phones
My watch is 3 hours and 5 minutes off its a shp8948
1. Since all of the settings seem to go through the start/stop button, hold it down for three seconds to put it in "set the watch mode" (when the seconds at the bottom start blinking).
2. Do a quick press of the start/stop button to move from seconds to minutes to hours to years to months to days. The mode button subtracts & the reset button adds.
3. Setting alarms & so on require putting it alarm mode via the mode button. Use the reset button to move to the selected alarm (1-5).
4. Hold the start/stop button for three seconds to "set the alarm mode."
5. Quickly press the start/stop button to between things to set (kind of alarm, hours, minutes).
6. Again, the mode button subtracts & the reset button adds.
7. A three-second press of the start/stop button exits the setup mode.
Feb 27, 2015 | Watches
Fisher paykel nautilus
hold button for 10 seconds.
otherwise >> service agent
Oct 17, 2013 | Dishwashers
Mi samsung exivit 2 stop to work it just don t turn on, in the scrim apear RAMDUMP MODE CAUSE ; FORCE TO UPLOAD.
1. If your mobile is
on, power it off.
2. Press and hold
Power until the
device powers
on, then
immediately
press and hold
Volume Down
(while still
pressing Power).
You will see the
word Start with
an arrow drawn
around it.
3. Press Volume
Down twice to
designate
Recovery mode.
4. Press Power to
restart into
Recovery mode.
You will see an
image of an
Android robot
with a red
exclamation
mark.
5. While holding
down Power,
press Volume Up.
6. Use the volume
keys to scroll to
"wipe data/
factory reset"
and press Power
to select it.
7. Scroll down to
"Yes - erase all
user data" and
press Power to
select it.
Jan 29, 2013 | Samsung Cell Phones
Reset my password
Here you go, keep in mind you will lose everything stored on the iPhone with this method.
Before you start, with the iphone off hold down the circle button and plug the phone in. Keep holding it down until you see a picture of a cable and the iTunes logo. Don't release the middle button until you see this screen.
Once in the restore mode, you can connect your iphone to itunes and phone in restore mode menu will pop up. Click ok, and hit restore (some iphones might require you to shift restore in order to change the firmware). This will reset your iphone and all of your contents and the iphone will be back to its original factory settings.You can put the iPhone in restore mode by holding the home and power button at the same time (sometimes it only works if u hold the power button at first and then hold on to home button)
Jul 02, 2011 | Apple iPhone 3G
Hello, I have a F&P Smartdrive 5.5 Excellence washing machine. Am I able to reduce the amount of rinses it does? It appears to be performing 2 rinses and I would like to cut it down to one only as we...
Hi just read your posting.Now the 1st rinse cycle is always a spray rinse when the machine is set at the factory.If you follow these instructions then the 1st rinse will be a short spin only,with no water usage.1---Select the OPTION ADJUSTMENT MODE by pressing and holding the START/PAUSE button, then pressing the power button.Then release both after about 2 seconds. 2---Press either SPIN SPEED button to turn on the SLOW light,which is the spin only mode on the 1st rinse. 3---Once the SLOW button is lit push the POWER button to return the machine to normal mode again.Hope this helps and please reply back to let me know how you got on.We are on tank water too but thankfully we have a good bore.Looking forward to your reply and good luck.
Jul 11, 2010 | Fisher and Paykel Washing Machines
Dishwashers Logo
274 people viewed this question
Top Fisher Dishwashers Experts
Tony Houde
Tony Houde
Alan Matzke
NOEL
NOEL
Are you a Fisher Dishwasher Expert? Answer questions, earn points and help others
