Question about Sony XS-V1330 Coaxial Car Speaker
Sony radio sub outputs don't work at all
I've read post before but none seem to be answered the sub volume is up the amp and sub work I know because I've tested them I tried changing the RCA jacks from the doungle if I turn it up all the way up I hear it faintly there must be some setting I'm missing cuz they just stopped working my stereo is the cdx-gt50w I also know it's not something lame like the remote turn on cuz the Amp and sub r powered up they wil play if I hook it to rear out and no I don't wanna just hook it to that cuz I loose the option to turn the sub up or down
  • 54 Answers
You may need a new head unit. it sound like you have lost the fron rca hook ups on your unit. common prob. usually cause by a surge traveling then the rca cables. i myself have had this happen and there is nothing you can do to the unit to fix it.
Posted on Oct 27, 2009
Sony CMT-GP5 subwoofer output very quiet
From the description the subwoofer is the problem, since the item is new return it to the place of purchase, this is a manufacture issue.
Aug 13, 2012 | Sony CMT-GP5 CD Shelf System
I have a clarion m 309 radio and I'm trying to hook up a fusion FM 402 amp for a sub woofer. I had all speakers playing but, I could not control the volume of the sub with the radio. I need to know...
Amps usually receive their signal through RCA wires. Your radio should have one pair of RCA outputs on the back. (red and white) You will adjust your subwoofer volume by adjusting the gains on the amplifer (little knob next to the RCA inputs of the amp), then you can turn up the bass on your radio.
Sep 06, 2011 | Clarion Car Audio & Video
I have a sony xplod 2/1 channel amp 800 watts. I already have 2 sony 6 by 9's hooked up to it running at 60 rms each but I wanna bridge a sub to it too. I was planning on taking a positive from one...
I don't recommend it. It may work good during low volume, but from experience, you will only turn it up so high before it trips the protect light on the amp since it's drawing too much current due to extra speaker(sub), then you have to turn off the radio and turn it back on to get it working again, it gets annoying. I recommend saving up for a mono amp, it will keep your system sounding clean and clear. the setup you specified will work, but it's not recommended. Your amp may run hot as well.
Jul 22, 2011 | Sony Car Audio & Video
I've got a vsx-920-k Pioneer receiver with s-11 Pioneer speakers and a s-21w Pioneer subwoofer. All of a sudden my sub stopped working and it seems like it's stuck in standby mode (blue light...
The manual is here...
http://www.pioneerprodj.eu/eur/products/42/99/S-21W/media.html
Flashing Blue is not defined in the manual.
Have you tried changing the Auto Standby switch to ON?
You can prove if the sub amp will respond to a known good input by TURNING ITS VOLUME DOWN tp start and just feeding it ANY RCA output from the receiver while playing, say, FM (to keep it simple). That way you would known in which direction the problem actually lies (internal or external).
Jul 05, 2011 | Pioneer VSX-C300 Receiver
Hi! I have a Jensen XA2150 Amplifier, from the speaker output I have connected a Subwoofer Sony 10 inch 1100W. Tha'ts gave me a nice bass sound, but now it's death! The amplifier have a 25A fuse,...
Have you checked the fuses inside the amp?Unscrew the cover and with the amp sitting on its back,remove the cover.You have 2-4 fuses,old round type,in there.
May 21, 2011 | Jensen XA2150 Car Audio Amplifier
I have been given a Sony SS-WSX1 subwoofer. However |I do not have the bespoke cabe. I need the pin out of the sub woofer to connect the unit to my system.
The sub was part of a Sony DAV-X1. This whole system is highly proprietary in its connections for a reason. For all anyone knows, the original amp's output was frequency-shaped to correct for speaker response issues, like Bose would do. Substituting a different amp may be electrically unwise and audibly unsatisfying. It is certain that the DAV base unit did all the electronic magic to create a surround effect from only 2 speakers and a sub.
Your best bet to put these speakers to use would be to examine the sub and speakers for two conductors each that would be for the amplifier's audio output. Measured across them wit han ohmmeter it would read somether around 6 ohms.
Then somehow craft a physical connector to carry an amp's speaker output to it and carefully test it with very low volume.
http://www.retrevo.com/support/Sony-DAV-X1-Home-Theater-Systems-manual/id/750ci463/t/2/
Jan 20, 2011 | Audio Players & Recorders
Sub not working with amp
Connect a sub cable to the amps sub OUTPUT then to the sub input turn the volume up half way on the sub then go to the amp setup menu and make sure the sub is switched on then set the cross over to suit your speakers,if your not sure set to 80hrtz.
Hope this helps.
CABLE GUY.
Feb 24, 2009 | Sony STR-DE475 Receiver
No Subwoofer output
the connections to the amp seem to be all wrong .check the wiring again.Does your deck have a seperate sub woofer output ?If it does , just connect one sub, i repeat, just one sub,and see the output.
OR
check the GAIN control on the amp.it should be 2/3rds of the max volume of the cd player.check it is not zero!
AND
Set the amp to the L.P.F. position.
bye .happy listening.
May 26, 2008 | Alpine CDE-7856 CD Player
Help ASAP Plaese
Are you saying you connected the sony output jacks to your subs directly without any other amp? Are the sub outputs powered? Or line level? Are the subs powered or direct? need some more info please. and post the Manual here if you can. Thanks
Jun 14, 2006 | Sony CDX-M850MP CD Player
Sony XS-V1330 Coaxial Car Speaker Logo
87 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
