Question about Dell Latitude D600 Notebook
Dell latitude d600...i want to disable my touchpad, the mouse does whatever it wants anytime I touch my laptop or even when I am not touching my laptop! I am so much happier with my wireless mouse!
  • 1,498 Answers
Hi MKW,
I know the feeling. Here we go,
  1. Go to Control Panel
  2. Click System
  3. Click the Hardware Tab
  4. Click Device Manager
  5. Click the '+' located to the left of Mice and other controllers
  6. There should be two mice listed. Select the touchpad.
  7. Right Click it then click on Properties.
  8. At the bottom where it says 'Device Usage', Change it to Disable.
  9. Click OK until you're out.
  10. If it wants to reboot, let it.
That ought to do it. Hope you found this to be very helpful.
Mike
Posted on Sep 26, 2009
I can not disable touchpad of INSPIRON 1545 of DELL Computers There is no option for disabling touch pad in the MOUSE option of Control Panel
Go to the Control Panel. Under the 'Hardware and Sound' options, click 'Mouse'immortal4u.png
Since you have a Dell laptop, you'll have a special tab called 'Dell touchpad' in the window that pops up. Click on the touchpad picture in the window.
In the new window that appears, click 'Device Select'
Click on the 'Disable' radio button to disable the touchpad completely. If you want to disable the touchpad of your Dell laptop only when an external device like a mouse is attached, check the last option that says 'Disable Touchpad/Pointing Stick when external USB mouse is present'
That's it. You've disabled your laptop's touchpad for good. If you don't find an option to manage your touchpad in Mouse settings, you have to install Synaptics drivers from here. Similar options can be found in other laptops as well.
Good luck ! if your problem is solved don't forget to rate
Dec 30, 2010 | Computers & Internet
How do i disable the touch pad on my Dell Lattitude E5400 laptop? Thanks, Tom tc@tc-talent.com 917-733-5968
You can turn off the touch pad through the mouse settings in the Control Panel. I was a little frustrated by this too, but if you go to the Control Panel and click 'Mouse', the first tab of this new window is 'Dell Touchpad'. Simply click anywhere in that window and you'll be able to configure the touch pad settings. One great option for many people is 'Disable Touchpad/Pointing Stick when external USB mouse is present' as there is no easy one-button solution to disable it.
* Please rate this solution with Thumbs up and comment to help us improve providing support
Nov 30, 2010 | Dell Latitude E5400 Laptop
How can I disable the mouse tapping function on my dell latitude e5400?
  1. Click Start.
  2. In the Search box type main.cpl, click main.cpl in the list of programs.
    • In Windows XP click Run, type main.cpl in the box next to Open, click OK.
  3. Click the Dell Touchpad tab.
  4. Click on the picture of the touchpad.
  5. Click Touchpad Settings.
  6. Make sure there is a check in the box to the left of TouchCheck, move the slider bar all the way to the right (this can always be adjusted back).
  7. Uncheck the box to the left of Tap to Click.
  8. Move the slider in the Touch Sensitivity area to the right until it is 3/4 of the way toward Heavy Touch.
  9. Click Apply, then click OK.
  10. Click the X in the upper-right corner to close the Dell Touchpad Utility.
Sep 23, 2010 | Dell Latitude E5400 Laptop
How do i disable the touchpad on the dell d430 when the mouse is connected?
All you need to do is go into control panel, open up MOUSE and click on TOUCH PAD SETTINGS then DEVICE SELECT and then DISABLE TOUCHPAD.
Sep 01, 2010 | Dell Latitude D430 Notebook
How do I disable the touch pad on my Latitude E5400? The curser jumps all over when I type. On my other laptops, there is a button clearly marked to disable the touch pad and this has solved the problem....
  1. Click Start.
    Go to Start, click Run, type main.cpl in the box next to Open, click OK.
  2. Click the Dell Touchpad tab.
  3. If you are not getting the Dell Touchpad tab, update your driver, you will get the Tab.
    Click Device Select.
    Click to check the box to the left of Disable Touchpad / Pointing Stick when external USB mouse is present.
  5. Click the X in the upper-right corner to close the Dell Touchpad Utility.
Aug 31, 2010 | Dell Latitude E5400 Laptop
Touchpad mouse not selecting when touched
Here is a link , to your drivers for your laptop, in input devices that is a glide mouse driver must be your touch pad hope this helps click here for page
Dec 02, 2009 | Dell Latitude D620 Notebook
My cursor has suddenly developed a mind of its own and floats around at will! How do I solve this please?
Keep the palms of your hands away from the "touchpad" -- it's sensitive to objects that don't actually touch it, but come "close" to it.
Also, check that none of the "arrow" keys on your keyboard are "stuck" in the "down" position.
If necessary, use CONTROL PANEL to "disable" the touchpad, and connect an external USB mouse.
Nov 18, 2009 | Dell Latitude D600 Notebook
The mouse on my dell keyboard has a mind of its own, can i fix or disable it
Go to
http://driverscollection.com/?H=Latitude%20D800&By=Dell
and download and install the driver for the touchpad. If that does not solve your problem then use a USB mouse and forget about having the touchpad.
Aug 27, 2009 | Dell Latitude D800 Notebook
Touch pad is not working in my dell latituse 600
If the touchpad is not working, then ensure that the touchpad is not disabled in the BIOS, in control panel ensure that is is not disabled there either. If the touchpad is not disabled in BIOS or Control Panel, then a palmrest would be required to fix the issue. On a system of that age, I'd just use a wireless mouse till I was ready to replace the system
Jul 03, 2009 | Dell Latitude C600 Notebook
Dell Latitude D600 Notebook Logo
236 people viewed this question
Alun Cox
