1995 cutlass ceira takes forever to crank,the lights & radio comes on.. but it tics tics about 6 times until it turns over! paid $250 last month for a starter! As soon as he finished it still tic tics? Now my trans is jerking & sliping & cuts off a couple of times when i stop or pull off ! feels like im driving in N..its really bad when i turn left even a slight left turn? please help! I think because im a single female im being taken advantage of!
I HOPE THESE TIPS CAN HELP YOU MOSTLY WHEN A STARTER TICS IS A LOW BATERY VOLTAGE BUT IN SOME OTHER CASES IS THE STARTER THE STARTER CAN BE CHEKED REMOVE AN CAN BE SERVICED BY A GOOD MECHANIC BUT IF THE BATERY VOLTAGE IS OK AND THE STARTER IS IN GOOD CONDITION THE PROBLABLE CAUSE MAY BE THE START NEUTRAL SWICTH THAT IS LOCATED IN THE TRANMISIION LINK AND MAY BE THE CAUSE OF POOR TRAS PERFORMANCE TRY CHANGING OR CLEANING THE BATERY TERMINALS WHITH A LEMON AND SOME WATER
Testimonial: "Thank you! I'll get to it 1st thing on monday!"
How do you replace a starter Ignition switch on a 1995 Oldsmobile Cutlass and where is it locatated
