Question about HP PSC 750 All-In-One InkJet Printer
Computer doesn't print color
The computer doesn't seem to tell printer to print color. I can copy in color from printer. Went into section that says grayscale/black or color and color is checked. went into another section and it says color is enabled. color is set at normal so its not down to low to print color it all comes out black. new cartridge, but it copies color anyway fine. Can you help me. Please! My color printer will not print anything in color. It has been working fine til a few months ago when all of a sudden for no apparent reason it stopped printing in color. I bought a new color cartridge and that didn't help. I have tried everything I have been told. Nothing works
  • 5 more comments
  • Maxi16 Apr 11, 2008
    Lexmark X1270 no longer printing color. Have new cartridge installed, still no color.
  • stavosho Jul 07, 2008
    hp750 won't print in color just b/w. when test page is run the colored squares are printed. tried priming, etc, still just b/w printing....
  • Anonymous Jul 09, 2008
    PRINTS BLACK ONLY VERY PALE. HAVE NEW INK CARTRIDGES
  • formapl Jul 19, 2008
    I ALSO HAVE AN HP PSC 750 PRINTER/SCANNER/COPIER, ALL OF A SUDDEN IT ONLY PRINTED IN BLACK / NO COLOR, I PUT A NEW CARTRIDGE IN , BUT STILL ONLY GET BLACK. WHEN I ALIGN THE PRINT CARTRIDGE, I DO GET STRIPS OF YELLOW, BUT ANY CARD/ PICTURE/ ETC WILL ONLY PRINT IN BLACK AND WHITE
    HELP
  • olse Nov 24, 2008
    hp psc 750 won't print color although it did before. Cartridges are OK. Only major thing that I did was install MS Office 2007. Is that the problem? What is "ravs" solution that he talks about? - “the problem seems with the logic board inside the printer, …open the printer and try some stunts…”
  • Joanne Burns Nov 30, 2008
    Other Users Have The Same Problem
    Posted by olse on Nov 24, 2008
    Posted by formapl on Jul 19, 2008I ALSO HAVE AN HP PSC 750 PRINTER/SCANNER/COPIER, ALL OF A SUDDEN IT ONLY PRINTED IN BLACK / NO COLOR, I PUT A NEW CARTRIDGE IN , BUT STILL ONLY GET BLACK. WHEN I ALIGN THE PRINT CARTRIDGE, I DO GET STRIPS OF YELLOW,
  • Anonymous Jan 20, 2009
    When I try to print something it won't print color and I don't now why.
    Champion:
  • 238 Answers
Hi, the problem seems with the logic board inside the printer, are you in a position to open the printer and try some stunts, that is only if you have done it earlier.. let me know??
Posted on Dec 17, 2007
Epson stylus dx6000 only copy in color mode
Any ink in the black cartridge or can you use clean mode to clean it?
Mar 15, 2014 | Office Equipment & Supplies
Printer has ink but wont print in color test page wont print in color, also aligned printer and it worked in color. cleaned printer head as well which printed all the colors. what else can i do? It seems...
Take color copy, test all colors are OK..Go to printer properties, printing preferences, finishing check is there any check mark on print in black cartridge only? mark on print color..apply..OK.. give print command..
Go to paint draw a color drawing, print it.> check colors if its not printing in color it might be drivers issue.. un install the drivers re install once again check..> if printed in color check the file which you are printed..take another file.. then test..
Oct 29, 2011 | HP Photosmart C6180 All-In-One InkJet...
I am tired of this mfc 440cn not printing in black only mode if the colors are empty, even one. I want to print and work with the black only cartridge. How can I get it to print in that mode only. ie: ...
Yes! There is a way around the problem. On each ink cartridge there is a narrow section that a sensor in the printer reads to decide when the ink is low. Cover that spot with a piece of black electrical tape to fool the sensor and you can keep printing. This page has good pictures showing what to do.
Sep 11, 2011 | Brother MultiFunction Center MFC-440CN...
We recently switched to Comcast and now our printer is not working. It says that it is on, and ready, but nothing happens when we try to print. We have an HP Color LaserJet 2840, and we use it for faxes,...
It seems that the connectivity b/w the printer and the computer is not through. Is it a wired or wireless printer? When you switched to comcast, did you made any changes to the wired connection with printer?
Mar 02, 2011 | HP LaserJet 2840 Printer
Prints only top half of photos on top half of
I suggest that you go into the printer properties section on control panel. There Will be a section which allows you to tell the printer the type of paper, size desired, orientation of photo to horizon and etc. There is also likely a selectable setup procedure on the printer's own display to do the same... It sounds like a basic setup format issue....
Apr 02, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Color copy doesn't work
wut is the model number of your 4 in one?
Dec 19, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Power Light Continues to blink.
if you are having issues after installing the new cartridges , then perform the following steps.
unplug the power adapter and remove both the cartridges and then power on the printer , look for the power light. if it does not blink then .
install the black cartridge first and then try to print , if it prints fine its ok. then remove the black cartridge and then put the color one in and then try printing or copying .
if it doesnot print with any either black/ color then you have to replace that particular caratridge..
lemme know once u r done....
May 02, 2008 | Lexmark X1270 All-In-One InkJet Printer
Big Black not printing
Sounds to me your print head is plugged up. This is not usual though because the majority of people use black ink much more. So, in your printer utility, do a deep cleaning. If that does not work, there is a thing called a purge unit in it. This is a usual way of draining waste ink to a pad that soaks it up. if the hose, or other parts are clogged, it backs the ink up and causes the print head to clog. If this is the start of it, do not waste your ink cleaning, and try not to let it sit too long. Contact canon, and let them kno what you think it is.
Oct 05, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Have you tried to reinstall the printer driver?
Jun 29, 2007 | HP OfficeJet G55 All-In-One InkJet Printer
HP PSC 750 All-In-One InkJet Printer Logo
480 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
