Question about HP PSC 1410 All-In-One InkJet Printer
Trying to figure out the # of black & white copies per minute on this 1410 printer.
    President:
  • 1,901 Answers
Here is the full list:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00316821&lc=en&dlc=en&cc=us&product=441115&lang=en#N670
As the list will verify, the quality of the printing makes a lot of difference in the output.
Thanks for using Fixya.
Posted on Sep 26, 2009
Printer is too slow to print once the command is given from PC
Hi
While printing from the USB Port sometimes slow printout/data transfer will result in slow printing of print jobs. or The printer might be printing slow , pausing in between print jobs , or intermittent printing. The symptom solution is mention below, read and follow the instruction.
Solution 1
After the printer is installed on the USB Port, check the description under the Ports Tab what is selected. Please refer to the figure below : c00873625.jpg Using the USB/ Virtual Printer Port and DOT4/ HP Laserjet 2420, under the Port/Description Tab printer speed will be as per the standard. Whereas using the DOT4/ Generic IEEE 1284 under Port/Description Tab, Printer speed will be very slow. If DOT4/ Generic IEEE 1284 is selected by default, then you have to uninstall the USB driver from the Device manager and plug in the USB cable again. Then it will detect the printer and USB port with respect to the printer model. Insert the Driver CD as prompted and by default it will select the DOT4 HP LaserJet2420 Port.
Solution 2
  1. Insert the HP LaserJet 2400 print series CD-ROM.
    NOTE: If the HP Software does not automatically start, click Start , Run , and then Browse . Browse to the CD-ROM drive at the top of the window under look in and select Setup.exe .
  2. Select Modify Installation . Figure 1: Modify Installation c00369540.gif
    NOTE: If Modify Installation is not available See Modify Installation is not Available.
  3. Select the Language of your choice. Figure 2: Select Language c00369541.gif
  4. Click Next. Figure 3: Setup Wizard c00369542.gif
  5. Verify Reinstalling an existing printer is selected. Under Select the port for this printer , choose USB001 or Dot4_00x and click Next . Figure 4: Choose Port c00369543.gif
  6. Select desired Features and click Next . Figure 5: Select Next c00369544.gif
  7. Click Finish . Figure 6: Select Finish c00369545.gif
Uninstall options
  • First verify if an uninstall options is available. If an uninstall option is available under Start, Programs, HP LaserJet 2410 2420 2430 , use this method to uninstall the printer.
God Luck
Sep 09, 2011 | HP LaserJet 2420 Printer
My photocopier is printing black
Try removing the developer and reseat it.
Mar 09, 2011 | Canon NP 7130 Black and White Copier
Dear All We want to but sharp Machine but we ...
5316 ,16 copy per minute
5320 , 20 copy per minute
May 20, 2010 | Sharp AR-5320 Black and White Copier
How many pages per minute doe it print?
Black Print Speed:--------- 15 ppm***** Total Media Capacity:---- 250 Sheets****** Max Resolution (BW):---- 600 x 600 dpi*********
Being laser-based, the SCX-4100 is a more economical choice over bubble jet printer whose cartridges are expensive in comparison to their durability. But be mindful that the SCX-4100 is a black-and-white device – so no color printing/copying for you, although it obviously scans color documents. The toner cartridge is good for about 3,000 copies, a figure that can increase 40% with toner management software (included).
The device has a main paper tray that holds 250 sheets up to legal size. You can manually feed a sheet at time into a slot right above the front paper tray, and there’s also a rear slot for jam-prone material, like envelopes and transparencies. Unfortunately, the SCX-4100 lacks an automatic document feeder.
Thanks. you can rate this solution and show your appreciation.
May 18, 2010 | Samsung SCX-4100 All-In-One Laser Printer
Black/white setting for printing?
Hi there
No sorry but the printer will not work with just the black it needs all inks to work
All the best Pineworks
Apr 25, 2010 | Canon PIXMA MP620 All-In-One InkJet...
HP psc 1410 all scans and copies are a total black
Yes, either the lamp or photo sensors in the scan assembly. You need a torx driver to remove the top and back covers and check that all ribbon cables are plugged in fully, sometimes a poor connection can cause that problem.
Apr 20, 2010 | HP PSC 1410 All-In-One InkJet Printer
Hi,how do I change setting from color to print black and white on HP PSC 1410 ALL IN ONE PRINTER?
Hi there nothing to do in printer. When you print some thing go in print preference and select the B/W print option. Then it will come as B/W print. Thanks & waiting for your feedback.
Mar 17, 2010 | HP PSC 1410 All-In-One InkJet Printer
Trying to print in black & white only
THis option is in the printer driver.
under Printing Preferences
Graphics
Output Color
Change this to BLACK
Jul 01, 2009 | Dell 3110cn Laser Printer
12 black and white copies per minute
be sure you are selecting B&W when copying, and the same if printing from the print driver.
Speed is based on 8`1/2 x11 paper fed side ways. First copy speed not incluced, once the first copy exits the machine it should work at the rated speed.
Hope this is of some help.
Ed
Apr 22, 2009 | HP Office Equipment & Supplies
HP PSC 1410 All-In-One InkJet Printer Logo
21 people viewed this question
Seeker5211
Seeker5211
