Question about HP Compaq 2025 (Carbon, Silver) 20.1" LCD Monitor
I plug in the monitor and the lights light up but there is nothing on the screen
    Sergeant:
    Novelist:
  • 183 Answers
Hello there andy_sellard.
Here's your GEEK-steer ...
To be clear, what I'm hearing you say is, the monitor is NOT connected to a functioning PC during your procedure. If this is the situation:
  • My presumption is you're just trying to test it by powering it up in order to see if you can get a display image.
  • However, there's nothing necessarily wrong with it. In fact, under these circumstances, it is behaving as designed. It isn't showing an image because it is not being SENT image signals (from a PC's video adapter) to display. That;s why you probably also notice there is a brief message stating something to the effect "No signal" or something similar.
If on the other hand, I'm mistaken, and it is connected to a (presumed) functioning PC, and behaves as you describe, there are a few questions:
  • Is it the monitor that was usually paired with this PC (i.e., was it working with this PC before now/recently)?
  • Were any hardware modifications made to this setup prior to this trouble?
  • Do you have access to another "known good" working PC, and/or access to another "known good" working monitor? If you do to either, perform a test as appropriate (e.g., hook up the problem monitor to the "good" PC, and vice-versa) in order to deduce what's "bad".
If still unresolved, please fire back these answers and we can pick it back up.
Good luck, and thanks in advance for posting back ...
  • to let me (and others) know how things worked out,
  • if you have any further questions,
  • to provide clarification or feedback.
"Today's the best day of my life ... and NOW you're part of it!"
Via-con-Dios and Godspeed -- Craig
Posted on Sep 26, 2009
    Novelist:
  • 152 Answers
Andy_sellard, Gee wiz, maybe the PC is broke? Maybe a stray dog bit and severed some critical conductors in the data cable from PC to the display, way back in 2001. You could try to make some voltage measurements if you have a DMM/DVM to see if all the DC source voltages are where they should be. Did someone pilfer your "cold-cathode-fluorescent-tubes" from your monitor when you weren't looking?? They would also have swiped your "switch-mode-power-supply" too. Try this! Reconnect bad monitor to an already booted, KNOWN GOOD PC that has the winDesktop showing. turn on the bad monitor and note what happens. If LCD screen remains BLACK, shine a bright flashlight at lower left corner of screen to see if you can see the WIN-start button being displayed. Get back to me with result of this test if you do see, or don't see anything!! I'mlouie12fix on fixya or lmistyrel @aol.com Hope to hear from you.
My lcd screen switch goes green and a message appears "going to sleep" and the switch light goes yellow
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
May 10, 2014 | CTX S762A 17" LCD Monitor
Vga failure
6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
May 06, 2014 | Samsung Computers & Internet
SAMSUNG TMS22WS Flickering Picture
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Mar 26, 2014 | Computers & Internet
I have a 40" screen colby flat screen, I'm having problems with my monitor coming back on???? I've tried leaving it unplugged for two days but when I plug the monitor up, don't nothing com
if the power indicator goes light green then turn to red, you must check the power supply board. look for a bulging capacitors.http://en.wikipedia.org/wiki/Capacitor_plague.a panasonic brand capacitors with low esr is a good replacement just look for the ratings and value must be the same when replacing. then make it sure check the polarity the positive and the negative. just let me know if you need further assistance good luck
Nov 01, 2012 | Computers & Internet
Red light on computer monitor, black screen, but nothing else
if the power indicator light from green then turn to red with no display, check the power supply board which may have leak or bulged capacitors. check also weather your vga cable is good, if no signal the monitor will turn to off.
Oct 14, 2012 | Computers & Internet
Desktop PC monitor suddenly went black & power light went off
1 either ur VGA card is corrupted or
2 RAM is corrupted
3 Last may be your motherboard is gone - not sure
Jan 04, 2010 | Computers & Internet
Monitor power light blinks blue but does not power on
if the screen was fryed the fuse would of blew which means there would be no lights at all.. the best thing you can do is plug your screen into another pc to see if anything happens.. if nothing happens then yeah your screen must of messed up somewhere.. but if your screen works on another computer then your graphics card config cant be right somewhere along the line
Jun 10, 2009 | E-Machines 19" Widescreen Flat Panel TFT...
Black screen on monitor when plugged in., no picture at all
When you plug in the monitor no lights come on at all green, orange nothing ?
Try
1. Using a new power cord ( maybe something is wrong with it)
2. Plugging it into a new socket on the wall.
If you can't get power to the monitor at all you may be in for buying a new one.
Jan 04, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
CTX S762G power on but nothing is showing up on the screen
bad capacitors on the inverter board, need service at electronics tech site or replace the monitor
May 02, 2008 | Computers & Internet
Monitor light blinks
have you tested the power supply connection feeds? test each connector I think you will find your power supply has failed on either the 5 volt or the 12 volt side more than likely 5 volts are down' the agp adapter needs 5 volts to run. since you have changed out every thing else I would replace that or test your dads power supply in your computer, that should do the trick
Apr 28, 2008 | Samsung Syncmaster 730B 17" Flat Panel LCD...
HP Compaq 2025 (Carbon, Silver) 20.1" LCD Monitor Logo
126 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
