Turn on to TV and all I get is blue screen with no information. Audios is good and channels change. I changed the 1000uf 10VDC caps and still have the same problem the model number is FLM3732 manufactured Nov 2005
  • 5 more comments
  • dre_jfe Sep 26, 2009
    I hooked up my satellite dish and I do get good audio so I know it is receiving the signal. None of the inputs seem to give me any video. Normally the TV manufacture name is displayed when I turn on the TV and that doesn't even come on.
    My TV is an LCD TV and not a projection TV. There is no information shown on the screen it is just a light blue screen.
    I also tried the signal from my XBOX 360 and my DVD player and I still don't get anything but the blue screen.
    All I get is a blue screen with no information displayed such as channel or if I am getting signal. I tried other inputs ie XBOX 360 or DVD player with the same results.
    Are these caps located in the power supply or in a different location? I don't believe I have a power supply problem as the TV starts normally with good audio. I think it may be in the mother board or video control board. It is a light blue tint on the screen not the dark blue normally seen when the TV has an input problem.
    I saw a video controller card on ebay part number 200-107-JK371CBH REV:B THE SAME AS MINE. THE OTHER PART NUMBERS ARE: 200-107-JK371CH REV:C AND TCL 06070601. I hope this helps.
  • dre_jfe Sep 27, 2009
    Thanks for your assistance. I did win the board on EBAY and got it for $20. 'Will let you know if it works.
  • 497 Answers
Sure, please go ahead.
If you require any further assistance, please get back to us.
Posted on Sep 27, 2009
  • 5,138 Answers
Change All of these capacitors C-111 47uf 50v ,C-112 1000uf 25v, C113-1000uf 25v C114-1000uf 25v. This should Fix problem. I know these caps were 10v go to 25v .
Posted on Sep 26, 2009
  • 1 more comment
  • ladywinn
    ladywinn Sep 26, 2009
    Yes ,I know your TV is LCD Polaroid most of the time you replace all of these capacitors set will start back working normal again ,So you have no display,menu,show of ch nothing but light blue? Yes the problem can be in Video board which is called Main Board where your in/outputs with tuner area? Let me do some more checking on prices and soluition for your problem!
  • ladywinn
    What are the numbers on each board this will help me to Identify part and prices ,also Do you have a control box with the Numbers 909-KSO-GF371XAH ? Encompass has this part for ($661.17) ($100.00 dud exchange,Call UED ask if they have any parts avaiable 1-800-648-6657 and you have want to try to Buy from E-Bay where someone has same TV but screen was broken and all parts are good. I seen one for 49.00 has almost same model number FLM3725 screen broken on it. Here is another thing if you have Bad display pannel then TV would cost pretty penny, unless you find used one.
  • ladywinn
    OK ,I think if you order the Video RF 200-107-jk371CBH 24.99 this should fix problem.And heres another thing anytime you order parts like this on e-bay and it turns out you dont need it you can always resell it and get your money back plus more . In the mean time replace all the caps i listed as well.I will also post your problem on website for TECH only to talk to other techician that may have ran across this before and the out come, I talk to over 5,000 team members daily we all trade up information and we are all TV repair Shops. Go with the Video RF Board.
  • 615 Answers
Blue screen comes when you do not have a feed, try to see if you have your setup to cable or Air and run the scan again...let me know. Please do not forget to grade my assistance so I am able to continue to provide you with better service. I will be working with you to conclusion of the issues.
  • Norman Al-Anbar Sep 26, 2009
    That may be true however with the digital signal if it not strong you will not get it just a screen but lets try to see if you can get the same signal on another TV from the same resource to eliminate the feed issue then we can troubleshoot the TV next...let me know. Please do not forget to grade my assistance so I am able to continue to provide you with better service. I will be working with you to conclusion of the issues.
Have a westinghouse lcd tv 50inch model ew50t5kw and would like to know before changing any parts or boards what causes a blue screen no sound or picture
  1. Frank: Verizon. com says try this: Change your VCR's Channel to 3 or 4. Most blue screen issues are caused by the VCR not being set to Channel 3 or 4. If changing the VCR's channel (using the channel buttons on the VCR or from the VCR remote control) did not change your TV screen, go to step 2.
  2. Make sure your TV is not in Video mode. There are three possible ways to change your TV's mode using your TV remote control: 1) Press a Mode button, toggle through the options and select TV, 2) Press a Video button to change your TV's mode from Video to TV or 3) Press Menu, locate Mode or Audio/Video setup and select TV from one of the options. If you are not sure how to change your TV's mode, see your TV's user guide for more information.
  3. Check to make sure your set-top box is plugged in and turned on.
  4. Check to see if other TVs (connected to different outlets) have a blue screen. If they do, contact the Verizon Fiber Solutions Center.
May 21, 2015 | Westinghouse Televison & Video
PLTV3250 have a blue screen. It won't power on
Hello
Probably a power supply - if you open the back of the tv (if you have electronic experience) find the power supply look for bulged capacitors and replace them.
power supply unit problem you have bad caps (capacitors) change all the caps or at least the ones that are leaking how do you see if they bad usually they are bold on the top instead of flat. change it with a higher voltage but the same UF. if it shows 10V-1000uf you change to 16V-1000uf or if it fits a 25V-1000uf.
THANK YOU FOR VISITING FIXYA
Mar 03, 2011 | Protron PLTV3250 32 in. LCD Television
Tv wont turn on power light just blink and nothing happen , no picture or sound
power supply unit problem you have bad caps (capacitors) change all the caps or atleast the onces they leaking how do you see if they bad usually they are bold on the top instead of flat. change it with a higher voltage but the same UF. if it shows 10V-1000uf you change to 16V-1000uf or if it fits a 25V-1000uf.
Feb 08, 2011 | Insignia NS-LTDVD19-09 LCD TV
Red button on TV flashing, won't turn on
power supply unit problem you have bad caps (capacitors) change all the caps or atleast the onces they leaking how do you see if they bad usually they are bold on the top instead of flat. change it with a higher voltage but the same UF. if it shows 10V-1000uf you change to 16V-1000uf or if it fits a 25V-1000uf even better.
Feb 08, 2011 | Televison & Video
Red button flashes on tv and won't turn on
Feb 08, 2011 | Panasonic Televison & Video
Tv sound will turn on for a few seconds no picture then it shuts off and blinks 5 times
TV will turn on but no picture or sound
No audio on polaroid flm-2017
Hi:
There a two capacitors that needs replacing in the power supply. the value of these caps are 1000uf rated for 10vdc, replace them with 1000uf rated at 16vdc.
Jun 26, 2010 | Polaroid FLM-3225 32 in. LCD Television
Blue screen with flickering horizontal lines
Sounds like the 1000uf capacitors on the FMT board need replacing. This is a common symptom with that chassis. There are three 1000uf caps that fail on that PC Board
May 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
174 people viewed this question
Top Televison & Video Experts
