Question about Samsung Exclaim M550 Cell Phone
Same issue my phone has been doing this for a while. i reseted my phone and that worked for a while but now its back again. and when the message comes up i figured out that when that happens you actually get a message, and eventually you will get the message at a later time.
Messages disappearing on new iPhone
well okay. maybe you could log out from your old iPhone 4 then logon to your iPhone 5s with the same informations you use on your what's up from iPhone 4.
Feb 07, 2014 | Apple iPhone 5S
Phone Camera Issues
DO A FACTOR RESET AND IT SHOULD COME ON, IF NOT THEN GO TO A HARD RESET FOLLOW YOUTUBE FOR HARD RESET. ALTHOUGH A NEW PHONE SHOULD JUST BE TAKEN BACK THAT IS WHAT I WOULD DO
Dec 27, 2013 | ZTE Engage Cricket Wireless
My lg quantum is giving a a message:"retry again
If you are uncomfortable with resetting your phone, or unsuccessful in fixing the problem, please contact the phone company for which you receive service from for help with resolving your issues.
Soft reset
To perform a soft reset, power the device off and back on.
  1. With the screen unlocked, from the top panel, press and hold the Power key to turn on the phone off.
  2. When the phone is off, press the Power key to turn on the phone. press and hold the Power key to turn on the phone off.
Hard reset
To perform a hard reset, remove and re-insert the battery.
Master reset
IMPORTANT: The device will be set back to factory settings; all data stored on the device will be lost. The device may not be functional for up to 15 minutes after a master reset is performed.
  1. From the home screen, swipe left to expose your app list
  2. Tap Settings
  3. Scroll down and tap about
  4. Tap reset your phone
  5. Tap yes to confirm, then tap yes to confirm again
That's it! Your LG Quantum will now be wiped. It will then reboot and you'll be left with a factory fresh phone.
Feb 10, 2011 | LG Quantum (16 GB) Smartphone
My samsung corby s3653 cant receive text messages sometimes...and sometimes when i receive text messages i receive it 10 times over and over...help me pls!what should i do?
if this happened from the beginning after purchasing your phone, it would help you if you bring it back to your phone dealer mostly if it's still under warranty.  but if this issue just comes up now, and you didn't encounter this issue before, it is a network provider problem.  however, since you are the phone owner, you may want to restore it to its factory settings and check,  here is the code for it but let me remind you that you will lose all your settings once you decided to hard reset it. so you need to back up your files first once you decide to restore it.  1.  switch off phone 2.  remove battery, sim and sd card 3.  reinsert battery and switch the phone on 4.  on your keypad, type the code *2767*3855# 5.  after successful hard reset, reinsert everything again,  6.  try sending a txt message to your own number and observe.
take care.
Mar 11, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
Touch pad is not working; can't do anything but receive calls-
Please reset your phone by removing the battery from the back for 5mins.Connect the phone to the power cord and then reinsert the battery again.Then press and hold the power button for 1 min.This should fix the issue.If you still face any problems then you will have to get it repaired.I hope your Phone is under warranty.
May 15, 2009 | Samsung SGH-U600 Cellular Phone
''Connection Error & Message Sending Failed''
Try doing a Factory Reset. (PLEASE DO IT ON YOUR OWN RISK - FACTORY RESET WILL DELETE EVERY THING OUT OF YOUR PHONE)
Dial *#7370# now it will ask restore original device settings,yes,it will ask for password its-12345, your phone will restart, all the data on our phone memory will be deleted,and it will be like when you first bought it.
But i don't think so that gonna help you out that much. It seem to be issue with the network. Try using some other Mobile service provider. See if problem still remain their on your mobile.
These kind of error message comes when you have WEAK NETWORK.
Dec 28, 2008 | Nokia 6680 Handheld
N95 NOT SENDING TXT SAYS MEMORIES FULL
Probably a virus.. setting it back to factory settings will not work most of the time, got the same issue but on my older nokia 6600, try a hard reset.. press #7370#.. this will erase everything in your phone... contacts.. old messages..images.. i mean all.. back up first before doing this.. =)
have fun
Aug 20, 2008 | Nokia N95 Cellular Phone
Voice Mail Message Indicator
i cant figured out the battery issue myself but you can reset the voice icon to zero through setting ...more...morephone settings then more again then hit the clear voicemail icon
Jun 09, 2008 | Motorola Mobility Moto Q
Can't access msg inbox!
you should master reset the phone then try it again and if that does not work you can have the mobile reflash that should correct the issue.
Feb 20, 2008 | Motorola Mobility RAZR V3
Stucke while sending MMS
At first, Try delete some bookmarks and unwanted stuff from your phone memory (I mean, free-up some phone memory) and try. If it do not work then, You should reset your mobile to factory settings first, then reset your MMS settings asper your operators instruction.
Aug 30, 2006 | Nokia Mirafone OP201 Phone
Samsung Exclaim M550 Cell Phone Logo
108 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
