Question about Philips 50PF7320A 50 in. Plasma HDTV
Hello, i have a 50 inch philips flat tv model # 50pf7320a/35. why is the screen half black?
  • 456 Answers
Unfortunately, i have found in my experience is when this problem occours you need to replace the plasma panel, which can be a costly thing to do and takes a little bit of planned time. Other than that you can try to replace the X-sus printed circuit board or the Y-sus printed circuit board. Those two boards control the screen circuitry, Good Luck.
Posted on Sep 26, 2009
OUR 50 INCH HD AMBLIGHT PLASMA MODEL 50PF9631D HAS SOUND BUT THE PICTURE HAS MANY LINES ANY IDEAS ON WHAT THE PROBLEM IS AND HOW TO FIX??
This is know as the" Blue Haze" defect. A tech may try to lower the screen voltages for you. Realign Ve, 110volts to 100volts. Vset from 195volts to 188volts...and the Vs from 197volts to 190volts. This was an authorized fix early in 2007. But more importantly you will have to live with this, as replacing the plasma screen is very costly. You probably have a bad screen.....SORRY!!!!!!
Oct 20, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
My Philips plasma only shows half the screen. The other half is just blacked out.
This model has PiP (Picture In Picture), find the button on the remote or check manual, this mode is most likely turned on and is being shared with one of the AV channels, or try turning on a plugged in SCART device to see if this picture shows on the other half of screen.
Sep 14, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
Philips 50 Inch Plasma Model 50PF7320A/37 will not turn on
Commonly it's going to be a power supply related problem. The two boards that need to be looked at is the Main Power Supply Board or the power supply board for the screen. The one that powers the screen, some manufactures call it a Backlight Inverter Board.
If you have some electronic experience, you can sometimes find a Service Manual for the TV over the internet for less than $20. It will have the all resource material for repairing your TV model. It's just the matter of replacing the bad part on the circuit board.
Aug 12, 2009 | Philips 50PFP5332D 50 in. Plasma...
Thin horizontal line,about 6 inches from bottom,is it fixable?
I am assuming it goes all the way across and is black ?
It sounds like a scan line in one of the chips inside has gone bad or needs to be resoldered. Most likely needs the board replaced by a tech.
Hope this helps
Scott
Mar 30, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
Philips tv blinking red light
I've seen this problem before with Philips. 6X3X blink was the X-sus or Y-sus boards. In other words, the TV cannot make the picture on the screen properly, so it won't even try and will shut down.
I've also had difficulty getting these parts from Philips (even while being an authorized service center). If you have an authorized service center near you, you might want to give them a try because I don't believe they were too expensive, just hard to get.
I hope this helps you...
Jan 08, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
Im just looking to buy a table top stand for my Philips 50PF7320A 50 in. HDTV Plasma can u help?
check online auctions, or local papers, it would b you best bet. Other option would be to buy a entertainment rack that has a big screen mount on it.
Dec 11, 2008 | Philips 50PF7320A 50 in. Plasma HDTV
Philips 50pf7320 plasma
Try to hard reset the tv..Leave it unplugged for 4-6 hours and then plug it again and use..If this did not help Try to contact a service centre or service person because this is probably a hardware problem which definetly needs service and replacement!!...Thank you..
Hope this helps you....
Kind Regards!!
DON'T FORGET TO RATE;
Sep 07, 2008 | Philips 50PF7320A 50 in. Plasma HDTV
Menu screen won't go away.
Kind Regards!!
Jul 21, 2008 | Philips 50PF7320A 50 in. Plasma HDTV
My 50 inch plasma
We have a 50 inch magnavox plasma screen. We found and used a fix from fixya! It only costs us $34.00 campared to the $300.00+
anyone wanted to look at it. The problem was on the powerboard but was two little capacitators with the model #3300 10v. We carefully took the back off the tv and removed the power board, went to a local electric supply store and bought the 2 parts for $2 each, we then found someone (tv repair shop!) to sauter the new ones on! Got it home put it back together and it stayed on, no depressing shutdown after a few seconds! you can find a picture of a fried capacitator on yahoo images, they are supposed to be flat but if defective will be bubbled at the top or even split! I am calling Magnavox today to complain that they are not recalling this part that should have been a better quality capacitator! Hope this helps some people!!
May 23, 2008 | Philips 50PF7320A 50 in. Plasma HDTV
Philips 50PF7320A 50 in. Plasma HDTV Logo
194 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
