Televison & Video Logo
Posted on Sep 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Konka TV is no longer on. The little greenlight / the standby redlight is not on. As if there is no power. But I've checked that the power chord is connected and power is on. Even when I hit the power on button on the side, the TV is not on. It happened all of a sudden. It was still working yesterday.
Anonymous
Level 3:
President:
  • Master 2,923 Answers
  • Posted on Sep 26, 2009
Anonymous
Master
Level 3:
President:
Answers
2923
Questions
0
Helped
730596
Points
8409
A defective power supply is a very good possibility. Failed power supplies caused by poor solder connections and bad capacitors. Checking for leaking or bulging capacitors can often get the power supply working although not all capacitors will look bad and must be checked.The only way to know for sure what is causing the problem, which parts that are no longer within factory specs and for proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment and the skills to use the test equipment.
Have a great day!
My konka android TV not loading. It is stuck on the start-up
SOLVED: My konka smart tv is stuck on smart tv loading ...
www.fixya.com > Forum > Televison & Video > Konka
May 27, 2018 - my konka smart tv is stuck on smart tv loading doesnt go further - Televison & Video. ... check the site linked here. Pull up older posts. ... My TV Konka LED TV KDL55XS712AN is not starting and saying: LOADING... Corrupted ...
How to perform a Forced Factory Reset on an Android TV ...
www.youtube.com > watch
Jun 8, 2017 - Up next · Sony Smart TV: How to HARD FACTORY RESET without Remote (Use Buttons on TV) · How To Run Through A Power Reset On Your TV.
Konka LED TV KDL55S712AN has refused to start and is ...
www.justanswer.com > ... > Smart TV Problems
Sep 2, 2016 - Konka LED TV KDL55S712AN has refused to start and is staying in the screen on" Smart TV loading..." ... Then on the actual TV, hold the power button for 60 seconds then release. Then wait 10 minutes, connect the power again to the TV, turn it on and tell me please if it is now operating correctly. 1 answer
Android Stuck On Boot Screen and How To Fix It ' Wirefly
www.wirefly.com > guides > android-stuck-on-boot-scr...
Restart The Device. This is the first step in troubleshooting an Android device that won't boot past the startup screen. If this has not been done, it ...
Power failure and now tv won't turn on just has a blinking red light
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
I hve poloroid lcd 3200 tv redlight greenlight on no sound no video just black blank screen ..what can i do?
Hello, check all of your inputs to see if there is a change in your picture. if there is no change the most likely problem is the main board has gone bad. thanks,Terry
1helpful
KONKA KDL32AT23U 32 in LCD Television No back light, sound OK
Not likely it is the back light if you can eventually get it to come up.
Some general information (cap?):
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.3_29_2012_1_25_02_pm.jpg
No signal from the RCA output on ps3 but works fine through hdmi cable
Ok...little trick......ready????? Hook up your rca cord to tv....Make sure hdmi cord is not plugged in. Have your ps3 where its on standby (redlight). Push and hold your power button down for about 5-7 seconds....you should hear a beep or 2. let off button....wait a few seconds and you should be in business.....The ps3 automatically detects hdmi....but if you switch back to rca you have to reset it.....Let me know if this helps
1helpful
Power is not coming on sony LCD TV. No standby power after switch on.
hi,
check the power chord first. also check whether there is power in that power socket to which ur tv is connected. if all these ok ur tvs power supply card have some problem. u can fix it only if u have an electronics basics. you can contact me through fixya.
ok
1helpful
32" beko TV stuck in standby
Ur power board is dead.U need a new one.
2answers
How to unlock my Konka K2001UM TV
check the tv's manual to see if there is anything about a "Child" or "Button Lock" feature.
1helpful
6answers
MY KONKA MODEL KLC 1508U
My Konka model KLC-1508U tv will not come on there is no red light that shows it is off
Top Konka Televison & Video Experts
ZJ Limited
ZJ Limited
Paul Bade
matt martin
matt martin
Are you a Konka Televison and Video Expert? Answer questions, earn points and help others
