Question about Whirlpool 24 in. ADP5962 Free-standing Dishwasher
Dishwasher door wont open
My dishwasher wont open the door to let the soap out
  • 1 more comment
  • Anonymous Dec 24, 2007
    kitchen aid soap door wont open on diswahser, i cleaned the exposed portions, is there some mechanism inside the door? Don't want to rip it open unless i have to jcardon2@rochester.rr.com
  • Anonymous Mar 18, 2014
    door wont open
  • Anonymous Mar 28, 2014
    DOOR WONT OPEN
    Problem Solver:
  • 14 Answers
There is a solenoid inside the door at the back of the dispenser.occasionally the electrical connection to this comes loose and simply needs pushing back in.if not the solenoid has failed and that means replacing the dispenser
Posted on Dec 29, 2007
  • 1314 Answers
SOURCE: Problems with my dishwasher
You need to replace the dispenser or possibly the wax motor on the dispenser. I would be more than happy to help you. But need to know the brand an model # so I can make sure that I give you the proper advise.
Posted on Jan 01, 2008
  • 3 Answers
SOURCE: Dishwasher soap dispenser sticks
Mine dishwasher (a Maytag) did this also. At first it was becoming stuck because of the soap. My repair guy cleaned it and I switched to liquid soap and it worked great another 2 years then did it again. That time it was just wore out and had to be replaced. I was told it was no longer available but we found it here http://www.repairclinic.com/and our repair guy installed it. He was amazed because he had even called everywhere.
Posted on Jan 02, 2008
  • 105 Answers
SOURCE: Have the Kenmore Limited Edition
check the wash arms to see if food has not cloged the holes stopping water getting through
if these are clean the machine may not have enough water entering machine
also check how you stack machine
Posted on Feb 02, 2008
  • 351 Answers
SOURCE: soap door won't open during wash cycle
its either the dispenser or the timer/pcb.
Posted on Mar 02, 2008
SOURCE: Dishwasher leaves soap in dispenser.
Hi Dirty Dish gang.
After having 2 appliance repairmen here, I now have the latest scoop on our dishwasher problems, $200 later!
Los Angeles IS currently having hard water issues. Also, all the new cleaning gels etc. are actually a cause of our dishwasher problems.
So, here is what we need to do:
1. Use Cascade POWDER detergent only.  Make sure is is just "plain" no "scented" or "complete"  or gel, etc. (I have tried a phosphate free powder and gel and this is a cause of our problem as well!) 2. Use Jet Dry in the dispenser (set it to a 2-3 opening) 3. Make sure water is at least 120 degrees 4. Only run dishwasher on "normal" setting.  All others just run it longer, hence causing more water stains. 5. Do not pre-wash dishes! You can knock of chunks with a "non" soapy brush, but don't rinse (the oils actually help to clean the dishes) 6.  Do not wash sponges in dishwasher.
Acid Wash: The repairman just gave my washer an Acid Wash today. It says it is an acid derived from lemon, I got mine from Carters appliance in Torrance, CA for about $19. I am to run a normal cycle with the above mentioned Cascade after this "acid cycle" is finished.
If you are still having problems:
Monthly maintenance: Glass Magic: Buy a box of Glass Magic (near the Cascade)  Use 1 Tbsb in main detergent compartment of dishwasher along with the Cascade, till washer starts working again. White Vinegar: You can run an empty dishwasher with white vinegar once a month.  Fill a bowl with 2 cups vinegar and place on bottom rack.  Then run as a normal cycle...this allows vinegar to disperse slowly.
So far it seems to be working.  Good luck.
Posted on Jan 09, 2009
My dish washer wont finish cycle and wont open soap door
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem
Detergent Cup does not Open
heatman101
Feb 22, 2011 | Dishwashers
Detergent door wont close
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Feb 09, 2011 | Hotpoint 18 in. DC26P Free-standing...
Soap dispenser wont open to release detergent?
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) Maytag dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Oct 26, 2010 | KitchenAid 24 in. KUDS02SRSS Stainless...
GLD6500 Series Dishwasher -- soap dispenser has
Yes that's normal for that machine. The soap has to be washed out of the soap drawer by the top spray arm turning, and that's usually the problem - the arm isn't turning. Check both spray arms for blocked jets at the very end - remove blockages with a pin and water flow from tap. In the worst case, you may need a new spray arm - but they are usually cheap.
More points to remember - on a rapid 30 minute wash program only, if you are using wash tablets, don't put them in the soap drawer as there wont be enough time for them to dissolve. put the tabs in the cutlery basket. Also - a dishwasher is not a garbage disposal unit, and uneaten food must be scraped of plates before putting them in the dishwasher. Run a dishwasher cleaner through now and then, or do a full program wash with nothing in the machine to clean it out and to keep spray arms clear.
Feb 02, 2018 | GE 24 in. GLD6500L Built-in Dishwasher
Soap dispenser door does not open during wash cycle
Here's a link to an article on why the soap dispenser won't open and tests to find the issue so you can resolve it...
http://www.partselect.com/repair.aspx?appliance=dishwasher&part=cup-wont-open
Oct 18, 2009 | Bosch 24 in. SHX33A05 Stainless Steel...
Powdered Soap Dispenser
The soap door doesn't open fully on that model, and usually flips fully open as you open the dishwasher door.
It relies on the top spray arm turning to 'wash' the soap out of the drawer - and that will be the problem.The spray arm isn't turning.
Check the spray arm for blocked jets at the very end - use a pin to clear them out, or replace them - check both spray arms. Make sure the spray arm rotates freely also.
Remember the dishwasher isn't a garbage disposal unit - remove food deposits from plates etc before loading the machine. Run a dishwasher cleaner through the machine now and then. Food like pasta, or fruit pips often get carried to the end of spray arms and block them.
If using a 30 min rapid wash program ONLY and dishwasher tablets, put the tab in the cutlery basket as it wont have time to dissolve fully if you put it in the dispenser.
Feb 02, 2018 | General Electric Profile PDW7980NSS...
Tablet falls to the bottom of tub but wont disolve
The newer Whirlpool dishwashers have little slots in the top of the soap dispenser to allow water to seep in during the first water fill. This design allows the tablet to begin to dissolve during the first fill then be usefull when the soap door opens. In your case, I would check to see if the soap dish is opening at all. Perhaps one of the racks are not allowing clearance or the soap door itself is sticking closed.
Let the dishwasher fill, drain, and then fill again. Open the door of the dishwasher and see if the soap door is still closed and if so, there is your problem. Also, at this time, check the water temperature. It should be at least 120 degrees F for the soap to be effective.
Hope this helps, Ken
Jul 17, 2009 | Frigidaire Dishwashers
Dishwasher detergent door won't release soap
There's an answer at: http://www.partselect.com/dishwasher+cup-wont-open+repair.htm.
Pretty in depth, but not a simple fix.
May 22, 2008 | Maytag PDB3600A Built-in Dishwasher
Soap door won't open during wash cycle
IT SEEMS YOU SOAP DOOR HAS A BAD SOLENOID ACUATOR OR RELAY
Jan 17, 2008 | Kenmore 24 in. 16592 Built-in Dishwasher
Whirlpool 24 in. ADP5962 Free-standing Dishwasher Logo
212 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
