Question about Garden
I have a snapper S31SST weed eater. It is 4-5
I have a snapper S31SST weed eater. It is 4-5 years old and been very reliable. Yesterday it ran about 20 minutes and shut down. It would not restart. This morning after cooling it would not start. In fact it is not hitting at all. It sounds normal when I pull the cord but no hit. I have checked and cleaned plug. Please advise best course to diagnose...
  • 148 Answers
Remove spark plug and check for fire with a spark tester. (some inline models are also available and safer since the spark plug stays in place using those types)
If no spark:
Remove covers and unplug small kill-circuit wire(s) from ignition coil...Test for spark.
If you have spark the switch needs replacing.
If you have no spark the coil needs replacing.
Hope this helps.
Posted on Sep 28, 2009
Oh it's snapper s31sst weed eater
I love this brand,, really eats up the weeds.
May 31, 2015 | Garden
I put brand new carb on weed eater snapper s31sst model runs wide open when should idle and close choke it idles down the way it should my cell changes the letters I type in
Check the the ldle screw play with it screwing counter clockwise or clockwise don't play with the high and lo adjusters
May 30, 2015 | Garden
What's the best way to adjust the carburetor gas flow on a snapper s31sst weed trimmer?
Technically the answer is to correctly adjust the L and H mixture screws on the carburetor. Here is a tutorial on how to do this.
http://www.zamacarb.com/tipspage.html
Aug 13, 2011 | Garden
Need carbureator jet settings for snapper SKU 952711718 weed eater motor
screw all the way in and back out 3/4 of a turn. Then adjust the bottom screw out 1/4 turn at a time till it cranks and continue adjusting till it idles good.
Then adjust the top screw till it stays running when going to high speed abruptly.
Jul 22, 2011 | Garden
Very weak spark.....how do I check the points under the fly wheel.....How do I get the fly wheel off? I just picked any weed eater product cause there was no link for my weed eater ride on mower with a...
Unless your engine is more that 25 years old (not possible for an Enduro), there are no points. The ignition is solid state, which means that a weak spark will require a new ignition module. Not the end of the world - they're cheap and easy to find.
Change the plug first!
Feb 17, 2010 | Poulan/Weed Eater No. 5000p 952711612 Pole...
Craftsman weed eater wont run
MAKE SURE YOU REPLACE THE CARB GASKETS. ALSO MAKE SURE YOU ARE USING FRESH FUEL WITH THE RIGHT MIXTURE. COMPRESSION SHOULD BE AT LEAST 90LBS
Sep 24, 2009 | Garden
Troy Bilt 4 cycle weed eater - trimmer head doesn't spin
rotate attatchment head slightly while inserting driveshaft
Jul 30, 2009 | Garden
Poulan Pro weed eater won't accelerate.
check the fuel mixture screws on carb high should be turned in & 1 turn out & low side should be turned all the way in & 3/4 of a turn check those & let me know thanks wade
Jul 06, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Weed eater won't run
Sounds like you may just have a dirty carburetor.
Youwill need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to seedaylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Jim
Jul 01, 2009 | Troy Bilt Tb70ss Gas Trimmer
Garden Logo
1,265 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
