Question about Dryers
400mm Cinni fan oscillation stopped working
I have a 400mm desk fan by Cinni (unknown age); motor drives the blades fine, but the oscillation isn't working. Does anyone have a manual for this fan? Cheers
vivek chi
  • 14 Answers
SOURCE: Oscillation works but motor doesn't
try tofix the axle with some glue or so
Posted on Jan 15, 2008
SOURCE: Vintage Oscillating Electric Table Fan ~ Repair & Service
go to this link, hope you might find something useful.
http://www.hudsonscustommachining.com/FAQs.doc
or you can go to this URL http://www.vintagefans.com/contact.htm and post your question there.
Posted on Sep 29, 2008
SOURCE: motor can be heard going but the blade wont spin!!
see if the fan blade set screw is tight and if it is then see if the motor is turning or humming if its humming and not moving then the end armature bushings have went bad.
Posted on Jul 18, 2009
dnewcombe1
  • 1564 Answers
SOURCE: Humming noise from motor of oscillating fan.
Wd-40 is not a very good lubricant. It only lasts fror a few days and then dries up again. In order to get your fan working again, take some 3-in one oil and put a drop at the bearing side of each bearing top and bottom with the shaft upright. Spuin and tap the motor briskly with a small tack hammer or screw driver handle. This will impact and allow the oil to get into the bearings Keep tapping and turning until you feel it lighten up a spin freely. Turn it over and do the same thing again. I garuntee that all will be fine after this.
Posted on Sep 07, 2009
Testimonial: "Unbelievably fast response - off to try to fix it!"
SOURCE: My Casablanca model 19n8c is
Hi nsohorn1,
I see that you are getting scrapping noises from your fan weather it is oscillating or not.
You mentioned that you already put oil but the same thing right, most probably this is nothing to do with lubrication, but can be a possible gear that is not anymore aligned or need alignment or maybe about to give way and needs replacing.
you mentioned that you do not have the manual any more, check this link if you want to just send it in for repairs since there are no manual to be found anywhere online for this product since production has been discontinued.
I hope that this helps.
have a nice day,
mvincentc
Posted on Jun 12, 2011
Is Casablanca Zephyr Table fan # 1928C available???
It is. $50 on eBay.
  • Casablanca Zephair Desk Fan Table Fan Model 1928D ' eBay www.ebay.com > Search > Casablanca Zephair Desk Fan Table Fan Model 1928D Find best value and selection for your Casablanca Zephair Desk Fan Table Fan Model 1928D search ... Vintage CASABLANCA Model 1928C Floor Fan 120vac 60HZ ...
  • Casablanca Fan Zephyr Oscillating Desk - sears.com www.sears.com/search=casablanca fan zephyr oscillating desk Home / Results For: "casablanca fan zephyr oscillating desk" ... SYBA 8-inch Tall Personal Table Mini Oscillating Fan, 2-Speed, Adjustable Head, Black.
  • Casablanca Zephair Desk Fan (Table/Desk Fan) 1928D in ... www.hansenwholesale.com/ceilingfans/casablanca/model.asp?ProdNo=1928D Casablanca Zephair Desk Fan (Table/Desk Fan) Model 1928D. Choose Custom Options & Accessories Here. ... The Casablanca Zephair Desk Fan is UL Listed for ...
  • Casablanca Fans Zephair Floor Fan Portable Fan 1928F www.casablancafansonline.com > ... > Portable/Freestanding Fans Casablanca Fans Zephair Floor Fan Portable Fan ... This 0.0 light Portable Fan from the Zephair Floor Fan collection by Casablanca Fans will enhance your home with a ...
  • Mar 24, 2016 | Casablanca Fan Zephair 19N8C Table
    Fan not blowing but the osscilate works?
    This is crazy - the same motor powers the blades and oscillating assembly. If the latter is working then the drive to the blades is no good and/or stipped. The fan should be spinning!!!!!!
    Nov 14, 2015 | Dryers
    How can I get my Seville desk fan to stop squeaking? When I called their toll-free number, they said their fans don't squeak. Talk about a company being in denial!! Their only suggestion was to take it to...
    Remove the guard, remove the fan blade. Lay the fan on its back and drip 4 drops of 3 in 1 Oil down the spindle. Turn the spindle by hand about 6 turns and leave it overnight with the spindle upwards. The next day, run the fan with the blade off and see if the squeaking has stopped. If it has, replace the blade and guard.
    If it is still squeaking, it is the bearing at the other end of the motor. That one is not quite so easy to lubricate and usually the motor would need to be fully stripped down, cleaned and lubricated.
    Aug 24, 2015 | Dryers
    Why wont my dyson fan oscillate?
    Hi there, it's Jack at Dyson.
    Your Dyson Air Multiplier AM01 desk fan should oscillate when you press the oscillation button on the base:
    If you find that it's not oscillating when this is pressed, we'd need you to contact our Support team directly - we can confirm if we're able to resolve this for you under our free 2-year parts and labour guarantee.
    You can reach us directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
    Sep 08, 2014 | Dyson Air Multiplier 10" AM01 Bladeless...
    Where to lubricate fan
    What type of fan do you have? If it is a desk or stand fan, you need to add oil to the front bushing/armature (accessible by taking off the fan blade) and to the rear bushing. To reach the rear bushing, you need to take the motor cover off - pull the oscillator push-pull lever up until it disengages, then using a phillips screw driver, unscrew the retaining screw of the motor cover. When the cover is out, you need to unscrew 3 retaining screws on the oscillator assembly at the back of the motor. When the oscillator mechanism is out, you will see the motor armature at the back of the motor (has a threaded end). Add a little oil to the bushing of the armature. Then reassemble (reverse order - secure the oscillator assembly with 3 screws, install the motor cover and screw the back, insert the push-pull lever and you're done). Hope this may help.
    Jun 27, 2014 | Dryers
    Broken cinni pedestal fan
    rattling fans are an indication of unbalanced fan blades. check for dirt or corrosion on blades Remove the blades and see if the motor still vibrates. If so scrap the unit. You may be able to get new blades but as few places carry fan spares I would hold out hope in that department. Check around the appliance repair shops and see what info you can dig up . May be a contact to the manufacturer on the web will give some answers as to spares
    Jul 14, 2013 | Cars & Trucks
    My air conditioner tries to turn on, air comes out of vents but isn't cold, and outside the blades on the AC unit are not spinning. I hear a noise when it tries to turn on but they don't start...
    Outdoor condensing fan motor has stopped running. This problem could be caused by a bad motor run capacitor. If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor
    Jun 17, 2011 | Heating & Cooling
    Sep 07, 2009 | Windchaser 3-way Oscillating Fan
    Fan oscillation
    Probably damaged the fan blade. If plastic, it could be missing a blade or maybe cracked. If metal, probably bent. I would ttry to get an eyeball on it while it''s running to see just what's up. Fan motors are usually pretty durable and last quite awhile.Good Luck and hope this helps.
    Mar 15, 2009 | Hotpoint HSM25GFRSA
    Dryers Logo
    788 people viewed this question
    Top Dryers Experts
