Question about Dell Computers & Internet
How do I install additional SDRAM in my Dell Dimension 4300 computer?
    President:
  • 1,901 Answers
1. Turn the computer OFF.
2. Unplug the power cord. Hold the power on for a few seconds to discharge any capacitors in the system.
3. Open the case. Locate the current RAM module(s). There are clips on either side of the module(s). Push out on the clips and lift them up and out.
4. To install the new ones, align the slots correctly, and insert the module straight don until the two tabs snap back onto the ends of the module(s).
5. Replaces the case panel, plug in the power cord and power up.
6. You may get a warning that the configuration has changed. If so, press the F key that it says, go into the BIOS, verify the amount of RAM it says, then do a Save & Exit to save the new figures.
For reference, here is a link to Dell's support page showing more detail for RAM and other replacements.
http://support.dell.com/support/edocs/systems/dim4300/replace.htm#1101964
Thanks for using Fixya.
Posted on Sep 26, 2009
  • 161 Answers
Shut the pc down, remove the cover. You will see the existing ram. Depending on how many sticks you can have install these where the existing ones are. Don't touch the metal on the sticks. Make sure it clicks in when you place it in the slots. Place the cover back on and turn on the cover. It should recognize it right away.
My system is recognizing only half of the new module's memory
Do you have the right memory for your Dell?
Memory Upgrade for Dell Dimension 1100 Computer, the Dell Dimension 1100 Computer takes the PC2700/3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory Type, and comes installed with 128 MB (removable) of Memory. You can upgrade your Dell Dimension 1100 Computer to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory, already with 128 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for Dell Dimension 1100 Computer.
Nov 20, 2010 | Dell Dimension 1100 PC Desktop
How do i know dell dimension memory need what MHZ speed
400-MHz (PC-3200) and 533-MHz (PC-4300) DDR2 unbuffered SDRAM non-ECC
Nov 01, 2010 | Dell Dimension 4700 PC Desktop
I have an old dell dimension 4300, it is running windows xp. i havent got the system restore disk and when i try to do it through windows it wont let me. How else can i do it?
Well download a disc from here http://www.tipandtrick.net/2008/download-unmodified-original-windows-xp-with-sp3-integrated-full-retail-and-vl-install-cd-iso-image-from-msdntechnet-plus-via-http-or-torrent/ download which ever version came with your computer either home or pro, burn it using a iso burner, and viola' you're good to go on a reinstallation.
Sep 26, 2010 | Dell Dimension 4300 PC Desktop
I need to buy and install and ethernet card for my
Ok - try this site for a great card
www.tigerdirect.com
Apr 16, 2010 | Dell Dimension 4300 PC Desktop
Is acer lcd 223w compatable with dell dimension 4300?
yes. you will need to know what connection you have on your dell video card. the standard is svga. the other is dvi. you may need a convertor or adaptor.
Dec 27, 2009 | Acer 22" X223w LCD Monitor
Dell Demension 4600 motherboard memory
From the Dell specifications page for Dimension 4600:
Memory
Architecture
Dual Channel DDR SDRAM
Memory connectors
Four
Memory capacities
128-, 256-, 512-MB or 1-GB
Minimum memory
128-MB DDR SDRAM
NOTE: Between 32 and 64 MB of system memory may be allocated to support graphics, depending on system memory size and other factors.
Maximum memory
4 GB
Memory type
PC2700 (333-MHz) or PC3200 (400-MHz) DDR SDRAM
(non-ECC)
Mar 09, 2009 | Dell (2336V) Motherboard
How to open dell 4300 dimension cover
the whole side pulls out, should be a level of some sort on the back or the top near the back, see the pic to see how it opens.
hope it helps
Feb 13, 2009 | Dell Computers & Internet
PNY memory
Hi
Dell Dimension 5150 supports DDR2 400MHz (PC2-3200) and DDR2 533MHz (PC2-4300) unbuffered SDRAM Memory (DIMM). You may install a total of four DIMMs in capacities of 256MB, 512MB, or 1GB. The maximum memory supported is 4GB.
From your query, I think the obvious question is; What is specification of the PNY DIMM and/or does the PNY DIMM meet the requirements for Dimension 5150?
Check for memory configuration and installation procedures for Dimension 5150 - http://support.dell.com/support/edocs/systems/dim5150/en/sm/parts1.htm#wp1364711
The Chipset used on Dimension 5150 is Intel 945G Express. I am not aware of specific compatibility issues regarding the Intel 945G and PNY Memory modules. However, there may really be known issues that I am not aware of.
To proceed, ensure that the PNY Memory is compatible with Dimension 5150. If not, install compatible (memory type, speed, capacity) DIMMs.
Let me know if further help is needed.
Mike
Jun 05, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Computers & Internet Logo
63 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
