Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer displays F-35 and stops
Whirlpool Duet washer displays "SUDS" after START
button is activated, then water flows-in, and after F-35 is displayed the machine stops.
  • 15,935 Answers
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
The "SUDS" or "SUD" error can be caused by too much detergent, improper detergent, drain pump/drain line problem, or pressure switch malfunction.
1. If you are not using HE detergent, you need to be. These washers are designed to use HE detergent which is formulated for wash tubs that use 5 to 7 gallons of water. If you use regular detergent, you are, in affect, placing a higher concentration of detergent in the washer that is normally formulated for wash tubs that have a 35 gallon capacity. The manufacturer should have a disclaimer in the owner's manual explaining this. In most cases this will also void your warranty. NOTE: Prolonged use of the wrong detergent can damage the drain pump components and or wash tub seals.
If you are using the correct detergent, double check the label to make sure it is not double (2X) or triple (3X) concentrated. You could still be placing too much soap in your wash.
To get rid of excessive detergent, place the washer on a RINSE & SPIN cycle, then run it through a normal wash cycle with NO detergent added. You may have to repeat these steps depending on the amount of detergent used.
2. If you do not have a detergent issue, double check the drain pump and drain lines to ensure they are not obstructed in any way. Click on the following link for step-by-step instructions:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
Obstructions in the drain pump and/or drain lines can attribute to air getting trapped in the drain pump and cause the error code. Double check all electrical connections to the drain pump and Central Control Unit (CCU). You will need to remove the top panel of the washer to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top panel in place. With the screws removed, slide the panel back, then off. The CCU is located directly behind the wash tub in the center of the washer. The Drain Pump connector will be the 6th connector (facing from the front L to R) in the center of the CCU.
3. Check the Pressure Switch to ensure it is good. The Pressure Switch is located to the right of the CCU as you are looking from the front. It is a small cylindrical shaped device with a connector plug and an air hose attached. The switch can be checked at several water levels by removing the plug and taking resistance readings at the connector pins. Readings are as follows:
(Pins are numbered R to L facing the from the REAR)
Pins 1 to 2 (SUDS Detect) - 0 ohms
Pins 3 to 4 (Overflow) - 0 ohms
Pins 4 to 5 (L1) - 0 ohms
Pins 4 to 6 (Empty) - 0 ohms
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%%$$##@@
Posted on Sep 30, 2010
Tip
Whirlpool duet washer F02 or F21 error code.
This error code indicates that drain times are longer than expected.
Make sure the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose.
Use only HE High Efficiency detergent. Using non-HE detergent, or more than the manufacturer's recommended amount of detergent, can cause excessive suds. The excess suds will slow or stop the removal of water from the washer.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
Temporary fixes:
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
on Mar 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool 9500TC Front Loader Washer. Can't wash garments due SUDS Display. Can't use any washer functions due to SUDS display.
Run a cycle with white vinegar this will clear the suds. Make sure you are using HE soap if not the unit will over suds.
Another common issue is the drain pump filter. If it gets clogged the sud error will come up as well. If you have water inside the pump may need to be cleaned. Simply remove the three screws ont he bottom of the lower access panel and then twist the handle on the filter. If water is inside the washer, it will come out when the filter is pulled out.
Good luck with your washer repair friend.
May 19, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F02
The f02 error code is caused when the unit control thinks there is still water in the tub after it has tried to drain. If the washer is full of soap suds it will also display an f02 error code. You will need to use only name brand HE detergent. If your washer is not draining the water out you will need to clean the pump filter. I have provided the instructions below. Run the washer in a drain and spin to ensure the pump is running. If the washer has no water and no suds the problem will be either the pressure switch or a plugged pressure hose. To check the pressure hose you will need to remove the top and remove the hose from the pressure switch.
Jan 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How do I fix my washer that only says 'sud' constantly and won't work at all? Whenever I try to start a cycle nothing happens. Whenever I push a button nothing happens. Please Help.
http://whirlpool.custhelp.com/app/answers/detail/a_id/2948
Hi please go to this above link, it is all explained at length what is going on and what to do.
This error code indicates that excessive detergent suds occurred during the cycle.
If a "Sud" or "Sd" error code is displayed, or if you can see excessive suds in the window:
There are too many suds in the washing machine. The washer will not be able to spin out water with the excess suds. When "Sud" or "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the tumbling and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This pause and rinsing are necessary and may occur several times to eliminate the suds. See the animation below for more information.
  • If you see "Sud" or "Sd" with the Rinse status light on, the washer is in the process of removing suds. Let the cycle continue.
  • If you see "Sud" or "Sd" and the Cycle Complete light is on, the washer detected too many suds during the cycle and your load may not be fully rinsed or water may not be fully removed. You may want to select a Rinse/Spin cycle for further rinsing.
Aug 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Our Whirpool duet washer will not spin, gives us the SUDS and F02 message and now the door is locked.....suggestionss?
k now the washer beleives that it is full of water.
pour about 3/4 cup of veg oil in the dispenser. and start the unit.. this will get rid of the suds error.
F02 means long fill.. and the water level has not satisfied the computer for 40 secs. check water connections. making sure they are fully open.
to open the door if it does not unlock, in the dispenser there should be an ODD colored line, five that a tug and the door will pop open
Oct 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer Displays F 35 code and stops
Sep 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F20 CODE Whirlpool Duet Sport Washer wfw8300sw00
Hi!
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
Do rate the solution.
Thanks
Rylee
Feb 08, 2009 | Whirlpool WFW8300SW
Washer will not complete a cycle.
sounds a s if you have ablockage within oyour pump assy, remove th elower acess panel and undo the "button trap" your problaby clogged up.. be sureto use HE detegent this will eleminate "suds"
Jan 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
206 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
