Question about Samsung SCX 4521F All-In-One Laser Printer
I have a Samsung SCX4521F black and white printer. I just got a new laptop and installed the printer on it. The printer works perfectly with other computers. On the new laptop, however, although it is installed properly and will print a test page, it will not print anything else. Ideas?
preachw996
  • 1179 Answers
SOURCE: Printer not printing in color; new cartridge, tests are fine
Check your printer settings to make sure the print in b & w box is not selected. Hope this helps.
Posted on Feb 08, 2009
  • 220 Answers
SOURCE: Samsung CLP-300 poor print quality
black developer on drum worned out,need changing.
Posted on Jul 03, 2009
  • 670 Answers
SOURCE: Samsung CLX-3160FN Vertical lines when printing black
This is a very common problem with Samsung CLX-3160 and CLP-300 printers. The real problem is that the developer blades get dirty with the toner. Buying a new imaging unit will only fix the problem for a short period of time then it starts to get buildup on the developer blades.
You need to clean the developer blades. If there are streaking on any color, then also needs to be cleaned.
To clean the developer blades, look to this link. http://losingambition.com/clp300imagefix/ It describes how to clean them. It only takes a few minutes to do once you get the developers out of the unit. Just be careful when you clean the edge of the blades. You need to make sure that the residue is completely removed from the edge. Also be sure that when you reinstall the blade that the little foam does not get trapped below the blade. Otherwise when you print the side where the blade is not properly installed will have too much color.
If you are afraid of messing your printer up, then you need to buy a new imaging unit. They go around $100.
Posted on Dec 24, 2009
  • 7 Answers
SOURCE: My CLP-350 Samsung printer only prints black ink
Here is my solution, hope it will solve your problem.
From your post, I believe your CLP-350N printer has enough black toner. The black cartridge is on the far right side of the printer, so the black toner is harder to go to left side of the roller than right side. Everytime we start the printer, it will move some toner of each color to the roller before it shows ready to print.
Because we always use B&W printing when we start the printer, but less Color printing. The result is there are always enough toner on the 3 color rollers, but the black toner is lean on the black roller. When this gets worse, the left side of the black roller may hardly get any toner at all -- so it only print black on the right side fo paper.
Step by step solution
(CAUTION: Never loss balance while tilting printer! You may drop and damage your printer! Hold the printer firmly all the time! Ask someone to help you if needed!)
Here, front of the printer is where you can access the cartridge, back of the printer is where you connect the power cord and USB cable, left is your left, right is your right.
1.Lift the front to keep the printer tilt to its back at about 45 degree
2.Power on printer while it's tilted back, wait untill green light is on
3.Open the front door, red light will be on, then close the door, printer will start up again,wait untill green light is on
4.Repeat step 3 once again, then put the printer back to level position
5.Lift the right to keep the printer tilt to its left at about 45 degree
6.Open the front door, red light will be on, then close the door, printer will start up again, wait untill green light is on
7.Repeat step 6 once again, then put the printer back to level position
8.Print some test page to see if there is any improvement of black print quality.(Hold the printer button for 3-5 seconds, it will print the test page.)
You may try several times and print several pages each time before you finally cure the problem.
Good luck! And do it safely!
Posted on Feb 10, 2010
  • 5100 Answers
SOURCE: printer will not print anything except test page and wont delete
Possibly, the print spooler needs to be restarted. In Windows, one of the ways to do this is in the Command Prompt window. (Start > Accessories > Command Prompt, right click on the command and choose Run as Administrator in Vista or Win7).
Type "net stop spooler" <enter> without the quotes. At the next prompt, type "net start spooler" <enter> again without the quotes. After the last command finishes, restart the computer. Check that the queue is empty and retry printing.
I hope this helps.
Posted on Apr 15, 2010
How scan legal page in scx4521f
Clean the inner side of the printer and if that does not help, then replace the toner cartridge.
Aug 28, 2012 | Samsung SCX 4521F All-In-One Laser Printer
My driver for samsung scx4521f is installed and prints but the scanner does not work
hello friend
in samsung driver cd their have a software SMARTRU that is the driver for scaning function so you have to install this driver.if u didnt found it
go the www.samsungusa.com and download it.
Jan 27, 2012 | Samsung SCX 4521F All-In-One Laser Printer
I just purchased a samsung scx-4623 and it shows in my control panel that it is installed but when I select to scann on the scanner panel it says its not connected even though the test during installation...
you may deinstall the software from your computer and install it new after, then try, if it is still the same problem go to samsung web side and write your modell name scx4521F then go to download side and download: 1. Printer driver; 2. Scanner driver; 3. Dr. Printer,
when you download the soft ware do not install this direkt from down load, say save then you will find the soft ware in your download folder and you can install this soft ware from this folder as many times you need it. Choos allways the newest version of the soft ware mentioned on the samsung download side for your printer modell, hope this solves the problem.
Apr 19, 2011 | Samsung SCX 4521F All-In-One Laser Printer
How to scan multiple pages to pdf samsung scx4521f
Open your smarThru programm, then click on scan to, then on OCR, in the new opened window set a mark at the option " Scan Multiple", then you can scan as much pages as you need to.
Apr 10, 2011 | Samsung SCX 4521F All-In-One Laser Printer
I need you to send me a diagram for samsung scx4521f i need to replace pickup roller plzzzz
when fax are coming in my printer the fax is not received & message disply- memory received- in SCX4521F samsung all inone
Aug 05, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Low heat error Samsung 4521f
check your heat roller unit.some time thermistor is fault
channel your service provider
Feb 10, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
