Windows does not recognize my usb device. i tried using a new cable but it still didn't work. help anyone
  • 161 Answers
Check for drivers..
Posted on Sep 26, 2009
Windows Vista does not recognized the Brother HL-2240.
hi Markaz.
you can try is to open Device Manager, expand USB Serial Bus Controllers, right-click on USB Root Hub and then click on Properties. Click on the Power Management tab and uncheck the Allow the computer to turn off this device to save power box.
or read up more at this link.
How to Fix USB Device Not Recognized in Windows
What do I do if my USB device is not recognized? Method 4: Reinstall USB controllers.
  1. Select Start, then type device manager in the Search box, and then select Device Manager.
  2. Expand Universal Serial Bus controllers. Press and hold (or right-click) a device and select Uninstall. ...
  3. Once complete, restart your computer. Your USB controllers will automatically install.
Error: "USB Device not recognized" when you try to access a USB ...
https://support.microsoft.com/.../error-usb-device-not-recognized-when-you-try-to-acces... Search for: What do I do if my USB device is not recognized?
or this link.
Windows does not recognize the USB device Google Search
Dec 02, 2017 | Brother HL-2040 Laser Printer
USB Port Not Recognized
Here Two Reason for USB Port Not Recognized:
1. Check you USB cable properly connected to the you computer, If cable break or not connected properly, It will show your cable not recognized.
2. If again these problem shows. go to,
My Computer - right click - Properties - Hardware - Device Manager - and Unistall you USB drivers - then again scan new hardware.
Jan 29, 2010 | Emerson BAR900 MP3 Player
Canon MP240
Have a look at this link
http://windowsfixup.com/2009/03/usb-device-not-recognized-fixes/
"Delete the INFCACHE" has worked for me in the past.
Also I found that I was using a non USB 2.0 cable which caused the "unrecognized USB" problem. Once I used a proper USB 2.0 cable it was fine.
Hope that helps.
May 11, 2009 | Office Equipment & Supplies
USB DEvice not recognized
Turn off the CPU unplug the power cable and all usb cables, let it sit for about 15-20 minutes. Plug power cable back in, turn on CPU, plug in your usb devices.
Mar 06, 2009 | Canon PowerShot SD790 IS Digital Camera
How to connect JVC GR-D820E camcorder to PC
Hi, connect the cam and PC using 4 pin firewire cable. Switch on the cam. Open Windows Movie Maker and import the video from device.
Dec 28, 2008 | JVC GR-D370 Mini DV Digital Camcorder
Windows does not recognize USB connection to the SpeedStream 6520- malfanctioning
try using different USB port. if the it is unknown device. means the machine didn't recognized the device. you may have to install the device driver. (windows is a funny thing).
Nov 05, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Hp laserjet 1020 ( usb device not recognized )!?
I wish that there was a simple, single answer for this. There's only one thing more distressing - no device recognition at all. Here are the most likely culprits:
* The USB device or the USB adapter requires it's own power source. If your USB device or adapter came with an AC power "brick", try connecting it.
* Here's a likely one - the front USB ports on your PC case may be misconnected. I've seen them that way from the factory. It's a good idea to check the connections against specifications. The standard order of connection is Red, White, Green, Black. No more than 4 wires per USB bank are needed.
* Defective device. Do not assume that all PC components work correctly out of the box. I've seen many new USB devices that do not work. If you can, try the device on another PC.
* All drivers are not installed. Some devices will require installing the driver package before plugging in the device. Some devices will also require basic USB files from the Windows CD before the unit will function. The general rule is to always follow installation directions precisely and to have the Windows CD ready.
I will now discuss how to address an unknown device problem which is caused by a driver deficiency.
1. Try to update the unknown device driver from within Device Manager. First try letting Windows search for one. If that fails, go back and choose "Select from a list" and then "Have disk". Browse to the device CD and look for the appropriate Windows folder there. Try browsing to the Windows CD (Win9x folder or i386 folder). Lastly, try updated drivers from the manufacturer's web site.
2. Try uninstalling the unknown device, unplugging the device and rebooting. Replug when back in Windows.
3. Be certain that you have the correct drivers! You may have gotten the wrong CD or a CD with drivers for more than one device on it.
4. Cleaning up in Safe Mode may be necessary. Unplug all USB devices. Reboot the PC. To enter Safe Mode, press the F8 key repeatedly while restarting the PC. Timing is important. Try to press quickly before the Windows logo screen appears. Pressing and holding the CTRL key may work too. Choose Safe Mode and open Device Manager. In Windows 2000 and XP, click View > Show hidden devices. Now locate all USB devices, HID (Human Interface Devices), USB drives and controllers/hubs. Remove all and save the USB Host Controllers for last. When done, restart and replug USB devices one at a time.
Just remember that you are entitled to support from the device maker. If you can't get help, do not hesitate to return the device. Some manufacturers only seem to respond to lost business. It's a shame, but it's true. Send them a message - that you won't accept shoddy goods or lackluster support.
Mar 26, 2008 | HP Photosmart 3210 Printer
Firewire (i-link) computer does not recognize cam
as far as the camera not being recognized when using firewire, you have to use a genuine, original Sony i-link/firewire cable. for the longest time i couldn't figure out what was wrong with the camera. i tried two different cables and two different computers. finally i took it to a sony service center and had them check it out. when i went to pickup the camera they said there was no problem. i didn't believe them and asked to talk to the technician that worked on the camera. I told him to show me it worked and was recognized. He did indeed, but using a sony cable. when i gave him my cable to try, it didn't work. luckily they were nice enough to let me go without paying the $80 minimum charge for any work, including the diagnostic "plugging in sony cable" check. I then bought an overpriced sony firewire cable for $25 and everything works. Damn sony's proprietary **** (all the sony people i related this story to blamed the bad quality of the cables i had been using)
Sep 29, 2006 | Sony Handycam DCR-HC42 Mini DV Digital...
Can't get connected
There are 3 possible things wrong. You will have to try to test them all. 1) The USB port could be bad. Try plugging another USB device into it and see if the computer recognizes it. Try a USB mouse, portable music player, or any other type of USB device. If it does, then the port is good, and move onto #2. If not, then try another port. If all USB ports are bad, then you will need to have that fixed. 2) The USB cable may be bad. Try swapping out the USB cable. Try using a different USB cable. Also try using the original USB cable with another USB device on another computer. 3) The printer may be bad. Contact vendor support, or just return is to where you purchased it. Another place to see if the device is even being recognized is the Deviec Manager in windows. This can be viewed by Right clicking on My Computer and selecting "Manage". In the Computer Management window that opens, select Device Manager. If you see any question marks there, then your computer may "see" the printer, but the drivers are not installed properly. If you do not see any question marks or the printer, then there is a problem with the printer.
Sep 15, 2006 | Canon PIXMA IP5200 InkJet Photo Printer
141 people viewed this question
 Grubhead
Grubhead
