Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Freezer side builds up ice on back wall ,then both sides stop air flow
  • 146 Answers
Hmm excessive moisture entering the unit - this can happen with excessive door openings or bad seal gaskets - make sure the seal is tight and not worn out. You are talking about frosting on the freezer outer wall right not behind the back panel ?
Try removing the back panel and look for icing/overfrost on the evap coils too - that could signal a defrost problem inw hich case you would need to inspect and change the control board or defrost timer components.
Posted on Sep 26, 2009
GE GSS25WTGA BB
This could be a dozen different things causing this. Do you see ice build up on the back wall? Your freezer coil could be icing over and blocking fan air flow. This can be due to a bad fan, low freon.....
Oct 12, 2013 | GE Refrigerators
The refrigerator is not staying cold yet the freezer side appears to be ok
The freezer keeps the fridge side cool on most units. Now i don't have a modle or brand to work with but I would start by making sure your defrost system is working okay. Check for ice build up in freezer on back wall.
Also make sure the holes in the walls or floors are not covered and blocking the air flow from the freeezer to the fridge.
Thanks
Shawn
Jan 31, 2011 | Refrigerators
Whirlpool side by side - freezer is fine. Fridge not cold
This is a common problem, and worth fixing if the frig isn't to old. The frig is making cold air just fine, which is a plus! All we need to do is get that air to circulate throughout the entire appliance.
Behind the freezer wall is a fan called an evaporator fan. This fan simply blows the air straight up the back of the freezer. From here it enters the frig at the top left and sinks to the bottom. Then it re-enters the freezer and continues its loop :D
So, either the circulation is being obstructed by something (maybe ice build up), or the fan is out.
Behind the freezer wall is the evaporator fan (that has probably stopped moving). Either ice build up (or some obstruction) has stopped it, or it has just served its time and needs to be replaced. Generally I would just replace it. You never know if it has been damaged from ice blockage or whatever the problem may be. If the motor is trying to spin and it is being held in place, bearing could be wearing out or completely gone which will just cause you more pain in the near future. So replace that puppy and you should be all set! :D good luck!
P.S. Naturally, if the fan is fine but you have something blocking the air flow, just fix the air flow problem in an apppropriate manor :)
May 25, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
Refrig not cold enough, ice buildup on banck panel of freezer
ice build up means your refrigerator is not going through defrost cycle. you have ice build up on evaporator which restricts your cold air flow into the fresh food side. check defrost timer, defrost thermostat located on evaporator behind the wall where your getting frost. check defrost heater. it wraps under the evap.
Jun 21, 2009 | GE Refrigerators
Freezer way too cold, refrigerator side too warm on side by side.
This can be caused by lots of faults first inspect the evaporator in the back of the freezer for ice build up if this is the case the defrost system has a fault, if not the unit that opens between the wall of the freezer and the fridge may be faulty check for the grills opening and closing
May 29, 2017 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerator side stops cooling
Drain stopped up.
Take out the bottom drawer in the freezer, look at the back wall and you should get a partial view of the bottom of the cooling coils. Directly below these coils is the drain area. You may need a light to see the drain hole. If this area is covered with ice then a hair dryer will help clear this so you can see the drain hole.
I have some O2 tubing that I put down the drain to clear any cloggs. Also, I seal the top of the drain hole around the O2 tubing with tape and use the air from my lungs to clear the drain tube. Pour a little water down this drain hole to make sure it’s clear.
Dec 17, 2008 | Frigidaire FRS26R4A Side by Side...
No air flow in fridge compartment,rfeezer working but not as well as normal
you may have ice build up at the freezer section. kindly look at the back side of the freezer if you have ice build up.
if you do then you have problem with defrosting.
tnx 4 using fixya,
drcool
Sep 20, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Side by side fridge not cooling properly
If you have NO water in ice maker... check to see if inlet water valve to ice maker is still good.
Frig not cooling...
Look in freezer see if any frost build up, on back wall ..make sure fan in freezer is blowing.. also fan in back by compressor
Jun 09, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Both the Freezer and the Refridgerator quit working...
Do you have ice build up on the back wall in the freezer? If so you have whats called a defrost problem. (can be timmer, adc, heating element or thermostat)... All cold air in you fridge side come from the freezer, therefore if you have ice build up behind back wall in freezer it is blocking air flow....
Dec 21, 2007 | Maytag MTF2156GEQ Top Freezer Refrigerator
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
248 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
