Question about Frigidaire 20.3 cu. ft. / 575 liter Upright Freezer FFU2064DW
Fridge walls very warm around freezer door, fridgidaire
  • 110 Answers
You may have a restriction somewhere, but i would definitely try to clean your coils, it is probably full of lint
Posted on Sep 26, 2009
Fridgidaire freezer warming up
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Sep 09, 2013 | Freezers
My Fridgidaire upright Gallery freezer is freezing my food but the appliance seems to be constantly running and the temperature control on the outside is reading 29 Celsius when it obviously isn't
Hi Susan Abboud - Modern freezers have increased storage capacity and keep more even temperature that may require the compressors to run longer but use less energy. Was the unit disconnected previously for any reason? If so, freezer requires a minimum of 4 hours to cold down completely. Confirm that the temperature control is not set too cold and that the door is not being open frequently. A dirty, cracked, worn or poorly fitted door gasket can allow warm air to enter the unit causing it to have to run longer to remove the warm air. Leaks in the door seal will cause freezer to run longer in order to maintain desired temperature. Cleaned the gasket, if it is too damage then it will need to be replace. You can check and see if the door seal is bad by, placing a dollar between the gasket and cabinet. Check to see if the door is being blocked by anything stopping it from closing properly. If nothing is stopping the door then replace gasket. Keep in mind that there should also be at least 4-6 in of air space on all sides of the unit. If freezer is built in or has items stored on top that cover the unit, the can cause long run times, high temperature in the freezer and premature failure to the unit. Do not block the toe grille on the lower front of the unit. Sufficient air circulation is essential for the properly operation of your freezer, about 3 inches around the unit.
Nov 22, 2012 | Frigidaire 20.6 cu. ft. / 583 liter...
My Kelvinator N245C fridge freezer is ok but fridge not cooling when i open the freezer door , the cold air through to fridge air outlet ok but when the freezer door shut and than no air to the fridge the...
first look for an air vent in the bottom of the fridge(a small grill on the inside wall) & make sure nothing is blocking it, like bread eg: if there isn't then unplug your fridge & let it defrost, check the drain outlet in the back of the freezer, sometimes a small item like a frozen pea gets into the drain & the water freezes around it causing the air not to return to the freezer from the fridge, to push air into the fridge you must be able to get air out or it presurises,
Nov 01, 2011 | Kelvinator 12 cu. ft. / 340 liter Chest...
Replaced gasket twice; still ices up around door.
If you replaced your door gasket and your absolutely sure that its sealing properly, then it might not be coming from your door. Ice builds up when warm air enters the fridge and the condensation freezes inside the freezer. The biggest suspect for warm air entering into the fridge is a faulty door gasket. However there can be another cause. If you remove the back panel of your freezer you should be exposed with the wires that come into the freezer and power the different components inside. The entrance point were the wires come in is insulated with a type of clay that prevents moisture from entering. However if this clay becomes loose it is possible for moisture to enter and start icing up. If you can remove the panel yourself safely without hurting yourself or damaging the fridge i recommand trying this first. If you don't feel comfortable doing this i recommand having a service technician taking a look at it. Hope this helps.
James Memije
Head Technician
Accufix Appliance Service Centre
Oct 22, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
My Maytag msd2756geb freezer is too cold.
You are probably right that it is always running. This is because the thermostat/sensor has gone bad. The fridge adjusts by a door that allows air to come from the freezer to the fridge side. Therefore this will still work...
You will need to replace or have the thermostat replaced....
Heatman101
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Feb 04, 2010 | Maytag Freezers
The compressor on my refregerator seem to be overheated it is a side by side the insides of the doors are warm and the freezer will not free but it is running there is cool air in freezer
The doors should be warm. There or heaters in the doors or what they call a yodelers loop in the frame around the doors that keeps condensation from forming. Make sure the fan if blowing on the compressor and the fan inside the freezer is also running. If so be sure there is no ice built up on the bottom inside back panel of the freezer. If so you will have a defrost problem and the coil is full of ice and not allowing the air to flow through it and cool the fridge. If there is ice, the heater behind the panel is most likely bad.
Dec 21, 2009 | Whirlpool Freezers
Can't get alarm to turn off while temperature stabilizes
My wife solved it for me :-) You turn the alarm off with a switch at the bottom. The alarm turns off, but the light stays red for another 4 hours. After that the red light goes off too, and you can turn the switch back on without the alarm going off, if the freezer is back to operating temp.
Aug 06, 2009 | Frigidaire Upright Freezer FFU12F2H
Side by side refrigerator is not cold. Bottom freezer is.
if the freezer is cold and the fridge is not then it can be several things. The freezer could have a bunrt out defrost heater, defrost timer faulty, fan not working in the freezer??. all of these things will stop your fridge getting cold, but your freezer will still be around minus 9 deg c. you wont get any air into the fridge as the coil in the freezer is prob all iced over. Dont worry about the heat on the door frame as it is only the anti sweat heater
May 01, 2009 | Maytag Freezers
Kelvinator F/Freezer not working. Not fuse
Sounds like gas is out.Probably leaking Contact the dealer where you bought it,Should still have guarantee.Jan
Feb 12, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Indest Fridge Freezer
Possibly something was spilled and it got to the door gasket. Clean the door gasket area with warm soapy water. In the door there is nothing critical to the system operation that should cause the condition you have.
May 17, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Frigidaire 20.3 cu. ft. / 575 liter Upright Freezer FFU2064DW Logo
142 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
