Question about HP OfficeJet d145 InkJet Printer
I replaced all my printheads. Also Both the black
I replaced all my printheads. Also Both the black ink cartridge and the color. My hp officejet d145 keeps giving me a " No print head, Insert black print head now." message. I tried re inserting it. I tried turning the printer off overnight.
What can you recommend?
Thank you;
  • 161 Answers
Call the manufacture or tech support. Maybe there is a printhead reset on the printer??
Posted on Sep 26, 2009
Why is my hp officejet 6110 printing everything green
You didn't use the HP printer cartridges? I know they are expensive. but the quality is worth it . I trust not a cheaper ink in a quality printer. You may need to check this HP url
Printer Prints Blank Page or Does Not Print Black or Color Ink for the HP...
When you get to Solution four: Use an automated tool to clean the printhead a helpful tip is to repeat the printhead cleaning up to 4 times .
Jan 17, 2015 | HP OfficeJet 6110 All-In-One InkJet...
I just replaced by black ink on HP Officejet 6500. It will not print black thought it maybe the cartridge I replaced it again. Still want print. I tried three new cartridges. The color works...
The following may work: remove all the ink supplies. Remove the printhead and soak it for about 5 minutes in 0.5" of very hot water. Gently blot the printhead on a soft damp paper towel to remove the excess water, then replace in the printer and then reinstall the ink supplies.
Jul 24, 2011 | HP Officejet 6500 Wireless All-in-One...
I have an hp officejet 7110 all-in-one and I've been getting a message saying that supply expired on the black cartridge. i replace it and it still won't let me print. what else could be wrong
Hello there:
This problem is usually due to a print head that needs to be replaced
I have provided the information that you will need ok
best regards mike
This document provides information on how to replace a printhead or ink cartridge.A printhead may need replacing when print quality issues cannot be resolved by cleaning the printheads or a front-panel display message indicates a printhead needs to be replaced.An ink cartridge needs replacing when a front-panel display message indicates either:
  • Low ink levels
  • Ink cartridge approaching expiration date
CAUTION: Never remove an ink cartridge and a printhead at the same time. Use the table below to identify the correct ink cartridge part number: Ink cartridge Part number HP 14 black print cartridge C5011A HP 14 tri-color print cartridge C5010A Use the table below to identify the correct printhead part number: Printhead Part number HP 14 black printhead C4920A HP 14 cyan printhead C4921A HP 14 magenta printhead C4922A HP 14 yellow printhead C4923A Replacing the ink cartridges Follow the instructions below to replace the ink cartridges:
  1. Turn on the unit, and open the print-carriage access door by lifting the handle until the door locks into place. Figure 1: Opening the access doorc00064456.jpg
  2. The print carriage will move to the center of the unit.After the print carriage stops, remove the ink cartridge by pressing the gray release button, then lifting the cartridge up and out of its slot. Figure 2: Removing the ink cartridgec00064457.jpg
  3. Remove the new ink cartridge from its packaging and, being careful to touch only the black plastic, remove the tape. Figure 3: Removing the tapec00064458.jpg
  4. With the ink cartridge label face-up, push the new ink cartridge firmly down into the appropriate slot until it clicks into place.The color ink cartridge inserts into the right-hand slot as indicated by the rainbow colored oval. Figure 4: Inserting the new cartridgec00064459.jpg
  5. Close the print carriage access door. CAUTION: If the ink cartridge is removed before a replacement is available, close the print carriage access door and replace the ink cartridge within 24 hours.
Identifying parts of the printheads Use the table below to identify the parts:
  1. Printhead handle
  2. Printhead tower
  3. Copper contacts
  4. Plastic tape
  5. Ink nozzles
c00064460.jpg Do not touch:
  • Copper contacts
  • Ink nozzles
  • Printhead tower
Jan 24, 2010 | HP OfficeJet 7110 All-In-One Thermal...
Prints only from color cartridges, black ink not working
The problem is in the print head.It's clogged or damaged.You need to replace it.It's part number is C9381A - HP #88 Printhead - Black and Yellow
Nov 01, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
I have changed the black cartridge twice but a
Are you using a factory new ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
Don
Oct 22, 2009 | HP OfficeJet d145 InkJet Printer
Bad Printhead
http://krakahead.blogspot.com/2009/03/review-of-hp-officejet-all-in-one.html
Place the bottom of the print head on a towel soaked in ammonia for an hour or more if needed. This will unclog it and it will work again. You may need to do this a few times depending on how bad it is.
Also clean all the metal contacts where the printhead attaches in the carrier.
Jan 30, 2009 | HP OfficeJet d145 InkJet Printer
HP Officejet d145 print head problem
Did you replace the PRINTHEAD, or did you replace the INK CARTRIDGE? They are not the same on the D145.
Good chance that you may have replaced the ink cartridge, not the magenta PRINTHEAD which sits under the ink cartridge.
PS - in my experience, non-HP ink cartridges clog up HP printers with separate printhead mechanisms... any possibility here?
Jul 26, 2008 | HP OfficeJet d145 InkJet Printer
Printhead problem
Any chance the ink cartridges, which are separate from the printheads, are empty or dried out? If the printheads were exposed to air for more than a few hours without an ink cartridge on top of them, they may have dried out. HPs are especially bad for this, and BTW, never use a non-HP cartridge in a D145 - the inks aren't compatible and clog up everything (at least it happened to me..) You could also replace all the printheads and cartridges, but that'll cost you more than a new printer.
Jun 17, 2008 | HP OfficeJet d145 InkJet Printer
HP officejet D145
Does it happen when you try to print from an application - like Microsoft Word or even Notepad? How about printing a test page from the properties page of the printer?
Sounds like either the printheads are clogged or there is no ink at all. Try running a few cleaning cycles. If you're sure you have ink, then try cleaning or replacing the printheads.
Dec 31, 2007 | HP OfficeJet d145 InkJet Printer
HP OfficeJet d145 InkJet Printer Logo
135 people viewed this question
Seeker5211
Seeker5211
