Question about Edirol UA-4FX External Sound System
Sound and audio devices problem
My computer not supporting to sound
  • 3 more comments
  • panthangi Mar 30, 2008
    recently I have formated my pc & win XP proffessional OS loaded. Since then I am not getting audio n my pc. When I checked in Sounds & audio devices that window is not activated i.e., all the options are hidden. In the device manager PCI Device is not installed . kindly help me in this regard .
    thanking you
    p srinivas
  • maryouma Jul 31, 2008
    my sounds and aoudio devices properties is not working
  • vinosgreat Aug 10, 2008
    by mistake i have uninstalled my realtek audio device.
    now i have no sound devices on my pc.
    evan after installing drivers of realtek from my mother board cd aits not working.
  • emmalou22 Nov 04, 2008
    When I enter "Sound and Audio Devices" from control panel is says "No Audio Device" and no options are available. I'm getting no sound whatsoever.
    I'm not sure what to do to fix this. I have no disks and nothing to install drivers or anything that I might need. I just have the PC...
  • adynakiss4u Nov 11, 2008
    i don`t have sound in:bsplayer,madia player and winamp
I was having problems all day trying to figure out why my sound just stop working. If you have windows XP, XP/2000 : Go to your start menu click on Help and Support. Then lokk on the right where it says pick a task. Go down until you see ( Undo changes to your computer with SYSTEM RESTORE. It show you a calendar and pick a day when your sound was last working and it will fix this for you.
Posted on Aug 22, 2008
All the options in sound and audio device properties are in active no sound is heard
Posted on Feb 27, 2008
  • sidjagtap Feb 27, 2008
    i am having M2A-VM SERIES mother board of asus company . i have formatted the system and installed the drivers . in the sound and audio device properties all the options are inactive and theres no volume control button in the task bar . the os intalled is windows xp unlimited sp2.
Posted on Dec 06, 2008
    An expert whose answer gotĀ voted for 100 times.
  • 108 Answers
Ierify whether your ext sound card system is working properly. f you are connecting external sound card system .check audio in /signal cable. check audio in volume in sound and audio devices menu in the control panel. check whether the audio in fuction is mute by defauk. if then uncheck it. thank you !
Posted on Dec 20, 2007
I have no sound and i can not see the volume control
It's a possible problem with the driver or the sound card may be disabled. To check if the sound card is disabled or drivers not installed,
1. Right click on "My Computer" select "Properties"
2. Click "Device Manager"
3. From the list, you should see a "Sound Controller" and if you click on the drop down arrow beside it, you should see the audio driver installed(ex. High Definition Audio Device... audio driver name may vary depending on the brand of the laptop).
4. Right click on the sample "High Definition Audio Device" then select Properties. If it says device is working properly then there shouldn't be any problem with your audio.
** If the Sound Controller is NOT installed properly you need to download the Audio drivers from the support site of your Dell computer, , be sure to select the correct model of your laptop and operating system of your computer. Once you have downloaded and installed the drivers, Audio should work fine not unless it is the hardware itself that is damaged.
**Also don't forget to check if there are other external audio output devices connected to your computer, please do test if working properly.
Hope this helps. Glad to be of service.
Nov 23, 2011 | Dell Computers & Internet
Hi antonykionyo
You don't say which Operating System you use, so my answer will be presented in general, Windows terms. If yours is a non-Windows Operating System, consider applying the logic and principles involved here to your own Operating System and, if in doubt, please feel free to add a Comment or Clarification to this Question, including information about your Operating System.
Check the status of the Audio Device and the Audio Driver in Device Manager.
Start > (My) Computer > (System Properties) View System Settings > Device Manager
This will tell you if the Audio/Sound Device is installed and functioning properly and if the Audio/Sound Driver is installed properly. If a red 'x' or a yellow question or exclamation mark appears next to the Audio/Sound Device, then there is probably a settings anomaly, fault, error or conflict with the Audio Device and/or its Driver.
For your Audio/Sound Device to function properly, it must be set as the Default Device:
Start > Control Panel > (Hardware and Sound) Sounds Speech and Audio Devices > Sounds and Audio Devices > (Manage Audio Devices) Audio > click on the Drop Down Menu to the right of "Sound Playback - Default Device" (preferred Default Playback Device) > select "ADI 198x Integrated Audio" > Apply > OK > Restart computer.
Re-install the correct Audio/Sound Driver that relates to both the Audio/Sound Device (ADI 198x Integrated Audio) and your Operating System, then restart the computer. Install the Audio/Sound Driver either from the Dell Drivers and Utilities CD or from the official Dell support website here:
If your Operating System is not the original Windows 2000 or Windows XP for which this PC was designed, then it is highly probable that no Audio/Sound Driver exists for that Operating System.
If you are committed to both this PC and an unsupported Operating System but all the other Devices and their Drivers are functioning normally except the Audio Device or you are using Win 2000 or Win XP but the Audio/Sound Problem remains unsolvable (faulty Audio/Sound Chip), then consider buying and installing either an internal 5.1, 7.1 or 8.1 PCI Sound Card or an external USB Sound Card that is pre-confirmed as being compatible with your Operating System. They can all be inexpensive. See examples here:
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Sep 24, 2011 | Dell Optiplex GX60 PC Desktop
My PC is not giving sound...what can i do..?
Look for your sound card model and install required drivers.
Oct 01, 2010 | Computers & Internet
I want a sound device to my computer
You need to download the audio driver from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the XP or Vista Windows version of the driver you require and install them. Click on this link to download the drivers: -
Jul 23, 2010 | HP Audio Players & Recorders
No sound got eroor code 1b63:061b , 0f1b , 151b, 101b
This error code is usually generated by a Dell Computer. I suggest that you perform an extended test by pressing the F12 Key at the startup of the Computer.
Furthermore, you may go to the Device Manager and check the status of the audio devices which are listed under the "sound, video, and game controllers" category.
I suggest that you try uninstalling and reinstalling the Audio devices from the device manager.
In order to uninstall the audio devices from the Device Manager, please right click on the device and then click Uninstall. It's required to restart the Computer after uninstalling a device. Once the Computer is restarted, reinstall the appropriate Audio driver. You can download the audio driver from the support site of your Computer manufacturer.
Jun 22, 2010 | Dell (8H390) Sound Card
I recently got my computer fix but it came back with no audio.
Did you check that compatible driver for your audio device is installed Properly? Go to Device Manager and verify. if there is yellow marked device error with name of Audio/Sound you need to update this driver.
Go to;
Download and install/update this driver, reboot your system and check audio output. Hope this will work for you.
Best of Luck,
Jul 27, 2009 | Compaq Audio card Sound Card
How can i find the sound card manufacturer name ?
Please try to check your audio by right click (mouse) My Computer icon (on the desktop screen) > click Properties > select Hardware tab above > click Device Manager tab > click +Sound, Video & Game Controllers > double click your selected Audio Controller device- wherein you can see if the device status is working properly as well as if the Device Usage is Enabled, if not click Troubleshoot tab.
Or you can also check your Sound / Control device thru Start > Contol Panel > Sounds, Speech & Audio Devices > Sound & Audio Devices - wherein you can adjust the volume & test your sound. best regards
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Windows Media Player cannot play the file because there is a problem with your sound device. There might not be a sound device installed on your computer, it might be in use by another program, or it might...
You might encounter this error message for one of the following reasons:
  • Your sound device is in use by another program. Quit other programs that might be using your sound device, and then try to play the file again.
  • Your sound device requires an updated driver. To determine if an updated driver is available, see Windows Update, or see the sound device manufacturer's Web site.
  • The selected sound device does not support Secure Audio Path (SAP). If you have multiple sound devices installed on your computer, try using a different one.
  • Your sound device is not functioning properly. To troubleshoot the problem, see Windows Help and Support or refer to your sound device's documentation.
  • You do not have a sound device installed on your computer. Install a sound device (such as a sound card), and then try to play the file again. If you can't install a sound device in your computer, you might be able to resolve the problem by attaching USB-based headphones or USB-based speakers to your computer instead.
Apr 26, 2009 | Razer BARRACUDA AC-1GAMING SOUNDCARD 7.1...
No sound from speakers. in sound and audio it says no audio device. another site said i needed a snd volume control.
You need to download your drivers sound.
Go to the manufacturer of your computer, and then to supports >> software and drivers
Follow this link:
Get your sound drivers there.
Then go to "My PC" >> Properties >> Hardware >> Device Manager >> Audio
And Update the sound driver there.
Oct 12, 2008 | Gateway Computers & Internet
I have no sound on my computer i tried everything ????
try to uninstall the all the sound drivers in your device manager.
click on start then go to control panel then click on system then select the hardware tab then click device manager then click the + sign beside the audio video game controller then highlight each driver then right click mouse and select uninstall. be sure to uninstall them all. after all has been uninstalled restart your computer. windows will reinstall all the drivers then check if you get to hear any sound. try to check also your sound and audio devices in the control panel and select the audio tab and see if the driver listed is the correct driver for you audio if not click the dropdown box and select the correct driver.
to know what are the devices in your computer go to and enter your service tag number. this is normally on a white label at the back of your computer.
in the page click the option which will allow you to see what are the current device specifications that is connected to your computer to give you an idea of the right driver for such device
Jul 11, 2008 | Computers & Internet
Edirol UA-4FX External Sound System Logo
851 people viewed this question
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
Ben Armstrong
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
