Question about Maytag Washing Machines
Our Maytag top loading model MAV3700 will not operate and the display shows the following message flashing LE Can you please help With thanks Pauline and Alan Plumb alanplumb@gmail.com mobile 0414 482 255
  • alanplumb Sep 30, 2009
    None of the above were relevent to my problem which I had to self diagnose as until now I was unable to open your reply
    However you might like to add another option to future complaints of a similar nature.
    THE PLASTIC LEVER MOUNTED ON THE LEFT HAND SIDE OF THE LID WHICH PROTECTS AGAINST THE MACHINE WORKING WITH THE LID OPEN WAS BROKEN. THIS MEANT THE SAFETY SWITCH COULD NOT BE RELEASED
    I trust this helps you and your colleagues
    Alan Plumb
  • alanplumb Oct 01, 2009
    Yes Taran, my problem has been fixed with a tube of Supa Glue
    Regards
    Alan Plumb
  • 10,515 Answers
First thing to check is the connections to the new pcb you fitted. Ensure they are all made correctly and that they are secure.
LE indicates a lock error on the motor.
The normal cause of this error code is sensor within the motor, Hall Sensor.
However, there are a few possibilities for the LE error other than the hall sensor itself.
The connector in the lead wire assembly is not connected to the connector of the the Stator Assembly. Check the 3 pin lead to the Stator.
The electric contact between the connectors, 3 pin male, in the lead wire assembly and 4 pin female in the main powerboard assembly is bad or unstable. Check the connection of the same wire at the main pcb.
The lead wire assembly between stator and main powerboard is open circuit. Unlikely as this would give a permanent LE error.
The hall sensor is out of order/defective. Replace the Stator assembly.
Here are the instructions on replacing the sensor.
The part to repair is a Hall Sensor and can be obtained from various suppliers, search for part number 6501KW2002A. (This is a common one but check with the supplier that it fits your motor).
1) Unplug the machine and remove the back cover. There are 4 phillips head screws. Take them out and remove the cover.
2) You're now looking at the back of the motor, which is mounted to the back of the drum. In the middle is a large hex bolt which holds the stator cover (the big metal cover with the vent flaps in it). Get yourself a 17mm socket and a ratchet and remove this bolt. It's easier if you have someone else stick their hands inside the drum (through the front door) to hold the drum still from inside. It can be done without, though. Once you're at this step, you'll see what I mean. Remove the stator cover and place aside.
Watch your fingers when replacing this cover as the motor is just a huge magnet.
3) Toward the bottom-left, you will see a couple of wire bunches held to the motor by three screws. One holds a metal bracket, one actually holds a ground wire, and the last is through a plastic bracket toward the bottom. Remove these three screws and don't lose them.
4) Through the motor (the big ring with all the copper coils around it), there are 6 bolts holding it onto the back of the drum assembly, remove these and you will now have the motor off the back of the drum. The wires that the screws/brackets were holding in place will be attached to this motor by two little harnesses. Disconnect both of them. You don't have to remember which direction they go in. If you try to put them back together the wrong way, they won't fit together.
5) Looking at the surface of this motor that was facing the DRUM (not the outside), you'll see two small parts clipped onto it toward the bottom. One of these parts is the sensor that you are about to replace.
6) Replace the Hall Sensor, reassemble the appliance and try it out. Hopefully it will now work correctly.
Should you still get LE after this you would be possibly looking at replacing the motor assembly.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 26, 2009
  • taran_2005
    taran_2005 Sep 30, 2009
    Thanks for your response!!
    We really appreciate your response and we would keep a note of this. The solution that i offer is a Generic one for most of the models, so adjustment is always there. We can make an intelligent guess what we have seen in our life keeping in mind the same error. For the same error, there might be 100 of reasons but we always start from 1 to 100 and i hope you would agree.
    But, honestly i am really happy that you are providing us with such a valuable information. So, kindly let me know, Have you fixed your problem or yet to fix it so that we can help you in the most efficient manner ?
    Thanks!!
  • taran_2005
    taran_2005 Oct 01, 2009
    We really appreciate your feedback. We would appreciate if you can close this thread by accepting solution or if you have any further Questions, let us know.
    Hope you would have a wonderful day!!
    Take care!
What does E2 error mean
Generic pump error
Error Code-control panel display "Err2" (Error 2, Error2) ' question ...
www.haier.com/za/help.../washing_machine/.../question/.../t20140313_209219.shtml
  1. Cached
  2. Similar
Mar 13, 2014 - Error message:Drain error, water can be not drained fully within the required drain time (controlled by PCB software). Reason 1. Pump filter is blocked. Solution 1. Please open and clean the pump filter. (Filter access door is on the bottom right, at floor level of the washing machine). Step 1.Push a flat blade ...
How To Fix Maytag Washer Beeping And Error Codes E2 and F3 Front ...
9k=? 5:23 https://www.youtube.com/watch?v=by94vOVmmhQ
  1. Similar
Mar 18, 2017 - Uploaded by Nancy Gurish How To Fix Maytag Washer Beeping And Error Codes E2 and F3 Front Load Washer Stopped, Repair Of ...
Washing Machine Error Codes - Front Load and Top Load Washers ...
https://removeandreplace.com/.../washing-machine-error-codes-front-and-top-load/
  1. Cached
  2. Similar
May 5, 2015 - F9 followed by E1 - (drain pump system error) F5 followed by E2 - (door will not lock) F7 followed by E1 - (motor drive error) "rL" - (remove load) Washer making error beeps - Door has not been opened and closed for at least 3 cycles. Washer beeps when HOLD TO START is touched - Door not closed
Mar 22, 2018 | Washing Machines
ERROR CODE07 ON MAYTAG DRYER
I went to the following URL and chated with a rep directly, but they said your listed model number was invalid. You'll have to chat with them directly:
http://maytag.custhelp.com/app/answers/detail/a_id/2885/~/display-shows-an-error-code---front-load-washer
At the top left of the MAYTAG logo in the center of the screen is a "chat" link. click on it, fill out the required fields with a red * and a rep will assist you. Let me know how it turns out for you!
Apr 30, 2012 | Maytag Dryers
Change the price on maytag top loading washer
Price change for a model MAT12.
Remove the access plate above the coin acceptor with a key. The display should show code 6 and two numbers. Code 6 is the regular cycle and the number of coins required to start. Press the perm press button to advance the number of coins. 06 equals 6 quarters, 08 equals 8 quarters, etc.
Reinstall the access door when finished.
Stephen
Feb 19, 2012 | Maytag MAT12CSD Top-Load Coin Operated...
Washer is not spinning and washing
I’m an Owner like you I own the FAV6800AW and have helped many folks on this and other forums with FAV6800A and FAV9800A machine issues.
Let’s do a positive ID on your machine so there is no guessing as to a repair diagnosis. I can’t post pic’s in the clarification section so I have to post as solution. Is your machine is one of these models please let me know which one?
Do you take any error codes or screen message to the display such as dC, uC or a unbalance message.
Here the machine types supported in this forum; Neptune FAV6800AW Top Load Washer
If your machine is not one of these please disregard my comments…..Rich
Jan 31, 2010 | Maytag Neptune FAV6800AW Top Load Washer
LE message, will not lock the door - Daewoo front load
Hello there:
This is a fairly common problem with these newer machines Here are the 2 most common fault codes on these machines I have listed below this post.
If the machine is still under warranty i would suggest using it normally they will repair this for free
and some of these have a recall on these machines
so i would contact the appliance center where you got this from and see if you can get it repaired ok?
"LE " persists in washer display Lid lock failure Replace switch, linkage, lock solenoid or control board. 1E persists in washer display Lid lock failure Replace lid lock switch or control board.
Dec 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
I am the owner of a DVD-SH871M/XEU, S/N: Y03B6SEQ600559N. I had an issue with the electronic program guide operating slowly, so after searching for product support on your website, I found a firmware...
Sorry, but this is something which only Samsung can now resolve.
Contact their customer care team directly, you'll need to make sure that you register the product online first to be able to benefit from their assistance.
Nov 06, 2009 | Televison & Video
LG WM2277HW - ERROR CODE "LE"
Hello remrama,
Please use this link to access the service manual on your display code message ( page 18 ) elaborates on the cause of that message. You should be able to determine which of the few causes may be the culpret,... http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf
Hope this helps you..
Regards,
Rick
Feb 22, 2009 | LG WM-2277HW Front Load Washer
Problem with LG washing machine Model number wm1480fhd. The machine drum reluctantly turns and in about a few minutes it displays error code LE (flashing).
LE error code: This indicates a locked motor condition. Please check the following conditions. Large loads of laundry can put a strain on the motor causing the LE error code. Try removing some clothing and restart. Excessive suds can cause the LE error code. Make sure the customer is using an HE (High Efficiency) detergent. They should decrease the amount of detergent until the machine washes without suds. A few bubbles can be expected. Areas that have �soft� water will usually need to use less detergent. If you suspect that excessive suds are the problem, let the machine stand for 30 min (motor cool down) and then run a rinse and spin cycle before restarting the load. If these directions are followed and the code persists, the machine will likely need service. .
Aug 22, 2008 | LG Washing Machines
Error message displayed on LG tromm washer model # wmt2778w
Flashing UE - The display shows:
• Load is too small.
• Load is out of balance.
• The washer has an imbalance detection and correction system. If individual heavy articles are loaded (bath mat, bath robe, etc.) and the imbalance is too great, the washer will make several attempts to restart the spin cycle. If an imbalance is still detected, the washer will stop and the error code will be
displayed.
Possible Solution
• Add 1 or 2 similar items to help balance the load.
• Rearrange items to help balance the load.
• Control error.
Nov 07, 2007 | LG WM-2277HW Front Load Washer
Washing Machines Logo
29 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
