Question about LG LDF6810ST Stainless Steel Built-in Dishwasher
I'm getting a code "LE".
I'm geting an error code "LE" and the machine stops in mid cycle. This code isn't listed in the book. Can anyone help?
I've always loved LG and Goldstar products but this will probably end my loyalty. This was a $898 dishwasher and it lasted 3 months beyond the warrantee!
  • 51 Answers
LE IS A LOCKED MOTOR CODE CHECK FOR OBJECTS IN PUMP BUT THE HAD THAT PROBLEM IS THE PAST
Posted on Sep 27, 2009
What does Code F on washer mean?
Hi. Some of the Error Codes for Cabrio Starts F. So Look at the number coming after F. e.g. F81 -> lid opened.
Here is the a list of Error Codes on some site for troubleshooting.
Troubleshooting Cabrio Bravos Oasis Washer Problems
Aug 01, 2014 | Washing Machines
LG dishwasher error code after 2 minutes
fault with the programe as it has stoped in mid cycle
Aug 01, 2012 | Whirlpool Dishwashers
There is an EE code. The machine just beeps.
EE
Remove your washer from the power source if you see an "EE" error code, where the first E is missing the top part of the letter. Your washing machine has a serious malfunction, and you must contact a technician.
A bit odd that as error code EE does not exist for washing machines, it's a refrigeration error code. Unless of course part of the display (led) has been damaged and the code isn't displayed properly.
Hope helps.
Jun 27, 2011 | Washing Machines
It stops mid cycle and at the digital display it flashes " LE " . What is wrong????
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped.
Motor lock can be caused by several things from a loose connector, to a bad motor, or even the hall effect sensor failing or dislodging from it's mount. Any one or more of these components could have caused this error.
This error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Apr 11, 2011 | LG WM1812C Front Load Washer
Le light on stops mid cycle
'le' stands for Lock Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Mar 29, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WM3677HW combo unit sets a LE code and stops in mid cycle. Motor was replaced but still does it.
Sensor maybe???
Here is a tip about the LE code that gives other thoughts also...
heatman101
Apr 23, 2010 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Stops Mid-Cycle: Error code is blinking ?H? then ?F?
FH, in mid cycle most likely your pump is blocked, hit drain/spin and see if water drains, if not clean pump
Dec 17, 2009 | Kenmore Elite 45986 Front Load Washer
Error code LE
Suggestion: Your wash could be overloaded; put in clothes within machine's capacity. What is written in your manual's max clothes capacity. If your heater is on; switch off machine and wall plug. Reset the machine with the heater on minimum & resume your normal cycle.
May 27, 2007 | LG WM2077CW Laundry XL Front Load...
LG LDF6810ST Stainless Steel Built-in Dishwasher Logo
588 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
