Question about Linksys Wireless-N WRT150N Router
How do I increase the IP range in a Linksys WRT150N?
  • Linksys Master
  • 32,281 Answers
Get a surge protection power board and connect your computer equipment and wireless router to this power board.
You can configure the wireless router to a different channel, one that is not used by your neighbours so that the wireless signal won't interfer with each other.
Have a look at the signal strength to your computer, if it is weak then move the router away from concrete walls and/or raise it higher to improve the signal strength.
Posted on Sep 26, 2009
Linksys wireless N WRT150N Router showing limited or not connectivity
Hi.
If you have a cable modem or DSL modem, try to unplug power on it and your router too. Then plug the power back to the modem and wait until you see almost all the lights on. If your unsure just wait about 1 min and it should be ok. Next plug power back to your router. This will create an new IP address which could resolve your problem.
Feb 08, 2011 | Linksys Wireless-N WRT150N Router
How do I Access the router’s web-based setup page?
Hello
you need to know the routers ip address or have the software. For most things the ip address will be 192.168.1.1 . You simply type that in your web browser and a page will come up.
you may need to go to the linksys site to find the default ip address of your router. But I would try "192.168.1.1" first.
Have a great day
Nov 25, 2010 | Linksys Wireless-N WRT150N Router
I can not change router ip
You need to change the router's IP to avoid conflict with the modem's IP address. You just need to access the router's setup page , default is 192.168.1.1. Default username should be left blank and default password is admin. Once logged in , first page you will see is the Basic Setup page. Just look on themiddle part of this page and there you will see the IP address of the router. Most of the time, if the user has DSL connection , Linksys' IP should be changed to 192.168.2.1. Dont forget to click on Save Settings at the bottom of the page. It will then say Settings are successful. Now click on continue. You can then power off then power back on the router for the changes to apply
May 15, 2010 | Linksys Wireless-N WRT150N Router
IP-address to my linksys WRT150N (192.168.1.1) doesn't responde any more. Does it men, that my router is finished or what else can I do? With best regards Tadeusz Sienkiewicz
If the router's IP doesn't respond, you can simply do a hard reset. Press and hold the reset button at the back of the router for 30 seconds then unplug the power. Wait for 30 seconds before you plug it back in. Try to check again if the IP will going to reply. You might as well try to restart your pc after doing the hard reset.
Oct 06, 2009 | Linksys Wireless-N WRT150N Router
I am installing my new wrt150n router and no internet
Turn off modem and router. Connect router to computer. Turn router on. Connect router to modem. Power up modem. When it discovers the modem it will assign to it the new IP address.
Hope it helps.
Sep 25, 2009 | Linksys Wireless-N WRT150N Router
How do I remotely reboot a Linksys WRT150N Router?
Try loging into the router's user interface and do a restore factory settings, but don't try if the wan ip was configured through static or pppoa
Aug 08, 2009 | Linksys Wireless-N WRT150N Router
Desktop/labtop - want to use internet with both at same time
check to see what your router setting is for "IP range" under the DHCP section. If it is NOT setup as a DHCP server, then enable this and put in a range of for example : 192.168.1.2 through 192.168.1.10
This will give you the availability of 9 connections. Also,.. be sure that your computers are setup to have their IP assigned automatically ( unless you NEED a static IP )
You should be able to access these settings by opening a browser and typing in the address 192.168.1.1 ( linksys default )
Hope this helps,.. I only came here to find range specs of wireless N routers :-P
Feb 23, 2008 | Linksys Wireless-N WRT150N Router
Linksys WRT150N
I only have 3 suggestions.
1st one is to make sure the ssid is not similar to other routers you are using on your profile. ie.(change it to a unique name)
2nd is to make sure you check the box that says broadcast your ssid.
3rd check to make sure you select the router as an access point and not adhoc or infrastructure option. Finally you can try to change the channels eg. i like channel 3 b/c it doesnt interfere with any phone lines.
good luck
smeags.
Jan 06, 2008 | Linksys Wireless-N WRT150N Router
Linksys Wireless-N WRT150N Router Logo
177 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
